GBP Battery Co / 48V 20Ah Li-ion
Postby marty » Mon Jun 18, 2007 8:34 pm
Ypedal wrote:You sent them money, but have no idea what you ordered or how much you paid ??? :?: Dude..... :lol:
Can not tell what I paid. Top secret. If I did tell you. I would have to kill you. Can not tell what I will sell batteries for, because I have no batteries to sell. You get nothing for nothing at VoltEV.com OK.... Dude..... :lol:
ebikes.ca
Online resource for electric bicycle conversions
http://www.ebikes.ca
MARTY
Volt Electric Vehicles
http://www.voltev.com
marty
Postby marty » Mon Oct 15, 2007 5:48 pm
Got battery many months ago. Its been sitting on the floor. One of my many unfinished projects. OK.... Here's the report. Size and weight is almost exactly as stated. [See first post this topic] Came wrapped with some sticky brown cardboard. Think Xyster could do better with duct tape. See pictures.
ebikes.ca
MARTY
marty
Postby marty » Tue Nov 06, 2007 7:54 pm
TESTING! Fabrication guy is almost done with battery tester. 100W 50 Ohm resistor, and 55V bulb mounted to a sheet of aluminum.
Look at picture of the BMS. There are 4 gismos in it. See picture of gismo. [Gismo pictured is not mine] Did not take BMS apart because if it's not broke don't fix it. Rest of electronic stuff in BMS is covered with black goo.
Got questions about voltages? After charging, voltage of 13 cells should be about 54.6V Right? According to http://www.gbp-battery.com web site, each cell should be 4.2V at full charge. 4.2 x 13 = 54.6 Will BMS shut down when a certain low voltage is reached? What voltage would that be?
Will monitor voltage with meter while battery is discharging. Anything else I should know?
BMS
There are 4 gismos in BMS
ebikes.ca
MARTY
marty
Postby xyster » Tue Nov 06, 2007 8:32 pm
marty wrote:...Came wrapped with some sticky brown cardboard. Think Xyster could do better with duct tape. See pictures.
I'll put my duct tape up against anybody, anywhere, anytime. Oh, that sounds a little weird.... :wink:
Nice antique scale, btw.
Don't trust the BMS's cut-off. If it doesn't cut-out before 48.1v -- 3.7v/cell -- stop the power there. Depending on the BMS cell balance function, some cells could be substantially lower, and well into permanent damage territory by that point.
Ebike: 5304/20", 72V 35A controller, 33AH 80V 20s15p (18650 sized cells) DIY lithium-ion pack
http://endless-sphere.com/forums/viewto ... 47&start=0
Scooter: '06 Stealth s1000, 48V 30A, 4x10ah SLA
http://endless-sphere.com/forums/viewtopic.php?t=148
Ebike: '06 Currie Mongoose, 32V 35A, 32V 22AH hybrid SLA/Li-ion pack
http://endless-sphere.com/forums/viewtopic.php?t=1010
xyster
1.21 GW
1.21 GW
It's hot - Not smoking :-)
Postby marty » Sat Nov 10, 2007 7:01 pm
Battery tester is done. We testing. Battery load tester is real HOT! [portable battery powered oven?] Don't try this at home kids. After charging voltage was 54.8V It's slowly going down now.
xyster wrote:Don't trust the BMS's cut-off. If it doesn't cut-out before 48.1v -- 3.7v/cell -- stop the power there. Depending on the BMS cell balance function, some cells could be substantially lower, and well into permanent damage territory by that point.
Sorry Xyster, I would rather sleep then watch battery discharge. Do have voltmeter hooked up. Keep looking at voltage. Don't have time for battery baby sitting. According to chart on page 1 of this topic. BMS cut off is around 2.75V per cell or about 35 volts for 13 cells. Will hope and pray that it does stop around 35V ?
For those of you who care? Here is parts list for battery tester. WARNING! it gets HOT!
3/16" x 12" x 12" aluminum sheet
RESISTOR Alcol 100W 50 Ohm, part # HS100 50R 1%
LAMP HOLDER SPC Technology, Miniature Bayonet socket, part # 21722
BULB SPC Technology, Miniature Bayonet lamp 55V, part # 1835
FUSE HOLDER Cooper Bussmann, 1/4 x 1-1/4, Panel Mount, part # S-8002-1-R
FUSE Cooper Bussmann, 5A, 1/4 x 1-1/4, part # AGC-5
CABLE CLAMP Thomas & Betts, Catamount, .125 Diameter, part # N4NY-002-0-M
FEET Plastic Bumper, 5/8" McMaster-Carr part # 9405K18
Anyone wana buy 98 small cable clamps, or 96 plastic bumper feet? Will give you good deal!
ebikes.ca
MARTY
marty
Re: It's hot - Not smoking :-)
Postby TylerDurden » Sat Nov 10, 2007 10:19 pm
marty wrote: ...Don't have time for battery baby sitting.
Too bad... it's a great opportunity to learn more about your pack.
:roll:
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby magudaman » Sun Nov 11, 2007 2:36 am
Isn't that 50 ohm resistor only consuming something like 50 watts? You could do low load testing with the CBA and get a nice curved graph with a shut off that won't be so hard on your batteries.
Lightning Moto Prototype:
4100w BMC 2 Stage Reduction
16s2p Headway 10ah
70a Ecrazyman Custom
magudaman
Postby xyster » Sun Nov 11, 2007 9:34 am
No skin off my nose, but if there's a problem with the BMS as is not uncommon, you'll pay through the nose later for not taking a second or two while riding to check the voltmeter.
xyster
1.21 GW
1.21 GW
Postby marty » Sun Nov 11, 2007 5:46 pm
Testing is done. Next step is go buy a bicycle.
magudaman wrote:Isn't that 50 ohm resistor only consuming something like 50 watts?
Don't know? My electrical design guy tell me to buy 100W 50 Ohm Resistor. Aluminum plate got hot. Think it was hot enough to cook a egg slowly? Test went for 12 to 20 hours? Don't know exact time, because I went to sleep. Could have cooked enough eggs to feed a small army?
magudaman wrote:You could do low load testing with the CBA and get a nice curved graph with a shut off that won't be so hard on your batteries.
What's a CBA? Computer Battery Analyzer?
xyster wrote:No skin off my nose, but if there's a problem with the BMS as is not uncommon,...
Voltage went to 0V :? According to what I read on this forum, discharging lithium batteries to 0V is bad :? Luckily.... I don't believe everything I read. Did I do Permanente damage? Hope not. From now on I will not call that electronic thing with multi colored wires on the side of battery a BMS. Suspect it does regulate charging?
After testing / killing? battery voltage was 0V. Charged it up. Red and Green lights on charger worked fine. Total voltage is now 53.7V Measured each cell.
8 at 4.2V
3 at 4.1V
2 at 4.0V
Hope to go bicycle shopping this week.
ebikes.ca
MARTY
marty
Postby magudaman » Sun Nov 11, 2007 5:55 pm
If it read a flat zero then the BMS may have shut it down. There most likely would still be a little voltage if you had destroyed your pack like you said. Draining a lithium battery to zero pretty much destroys it, so I would hope you didn't really do that either. The BMS will usually cut the power off way before that point to prevent damage. You really should watch the pack on a first discharge. But I guess if you you really don't have time for that then you could be out making money that you would need to replace that pack if the BMS didn't work.
Yes the CBA is computer battery analyzer and can be purchased here: http://www.westmountainradio.com
16s2p Headway 10ah
magudaman
Postby marty » Sun Nov 11, 2007 6:09 pm
magudaman wrote:If it read a flat zero then the BMS may have shut it down.
Duh.... Now I understand. Thanks for explaining that to me. Do wish I knew the voltage when BMS shut down? CBA would be nice.
ebikes.ca
MARTY
marty
Postby Yesa-battery » Mon Nov 26, 2007 2:30 am
Hello,marty,
48V 20AH li-ion battery (13 cells) ,
48/13=3.7V
So the battery is not LiFePO4 , LiFePO4 cell should be 3.2V , maybe LiMn2O4. Just guess, not sure.
Yesa Battery proud to introduce you the finest LifeP04 battery supply.Interested parties please visit our website or email to us for further enquiry !!we provide excellent sales service to all our clients.
Message from William sales service
http://www.yesa.com.hk
Yesa-battery
Postby marty » Tue Nov 27, 2007 5:43 pm
Hello Mr William, Yesa-battery Man,
You can call my battery LiMn2O414789632?????? if you want? Just to let it be known. I call my battery, Marty-Battery. Model Li1. My battery is number one!
Would like to see some pictures of your battery. Naked please. Tear off that shrink wrap! I show you mine. Now show me yours. Please start a new topic. Click on button that say [new topic] Tell us all about your batteries? I like to look at pictures. Do you have 48V 20Ahr? What is size weight? What is price? Got pictures of charger? Got any colorful graphs?
ebikes.ca
MARTY
marty
Postby fechter » Tue Nov 27, 2007 11:06 pm
Yes, please show us the insides.
Show us the factory where they are made.
Show us test results
Tell us how much they cost and what sizes are available.
and on and on....
You can post pictures on the forum by using the browse and Add Attachment buttons under the text box.
fechter
Re:
Postby marty » Sun Apr 22, 2012 6:56 am
fechter wrote:Yes, please show us the insides.
and on and on....
Here's your pictures Fechter. Only took me 5 years to upload these. I've been busy. Sorry about that.
48V_20Ah 001_side.jpg (63.81 KiB) Viewed 263 times
48V_20Ah 002_top.jpg (78.1 KiB) Viewed 263 times
48V_20Ah 003_ruler.jpg (55.86 KiB) Viewed 263 times
4
48V_20Ah 004_scale.1.jpg (58.47 KiB) Viewed 263 times
6
48V_20Ah 005_scale.2.jpg (52.03 KiB) Viewed 263 times
48V_20Ah 006_charger.1.jpg (51.15 KiB) Viewed 263 times
48V_20Ah 007_charger.2.jpg (65.1 KiB) Viewed 263 times
ebikes.ca
MARTY
marty
Re: GBP Battery Co / 48V 20Ah Li-ion
Postby fechter » Sun Apr 22, 2012 10:55 am
Well, then you should have long term test results by now :wink:
I love the rusty scale!
fechter
Postby cwah » Sun Apr 22, 2012 6:48 pm
My battery (Limn2O4 or Li(NiCoMn)O2) has lost 40% of its capacity in 6 months.
Have done around 70-100 cycles on it.
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby nechaus » Sun Apr 22, 2012 7:09 pm
Thats some nice old looking scales.
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Postby Kin » Mon Apr 23, 2012 1:46 am
cwah wrote:My battery (Limn2O4 or Li(NiCoMn)O2) has lost 40% of its capacity in 6 months.
That's insanely high. What C rating are you running it at? Does the pack get hot after using it?
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby cwah » Mon Apr 23, 2012 3:50 am
Yeah, that's really bad. I'm only running at 1.2C rating continuous.
Not very high.. Very often I leave my bike outside, on the cold (0 Celcius outside) and the heat (25 Celcius outside). Maybe sometime the sunlight damaged the batteries as the decay is extremely fast over 50 Celcius. I can't tell thought.
cwah
Postby Hugues » Mon Apr 23, 2012 5:49 am
I compared the 100ah type of GBP to a Winston cell,
Winston comes out much better in term of energy density in weight and volume.
Hugues
Switzerland
Mountain bike
XC-204 -> Crystalyte HT3525/Infineon ctrlr 40 A EB712XC board/LiPo 88 V 10ah
All Terrain Vehicle
Hanebrink -> Crystalyte HS/Infineon ctrlr 20 A/Allcell Li-ion 36 V 10ah
Motor bike Cruiser
My build thread here
Hugues
Postby Ypedal » Sat Apr 28, 2012 7:31 pm
I got 2 of the 36v 20ah packs made from these cells just about the same time Marty got his ( a few months before ) .
I just ran a capacity test on one of the 2 packs ( I've let a local friend use it for the last 2 years. )
I fully charged the pack, cell by cell to 4.20v via the ballance leads. let sit overnight..
cell no.9 of 10 is bad from day 1.. had a big dent in it on arrival.. falconev was not honoring any warranties so it's been used as is since..
I got 8.0 ah before cell.9 dropped to 3.1v, all other cells holding 3.6v ..
Marty, are you using that pack ?
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby marty » Sun Apr 29, 2012 7:47 am
Bought this battery for Electric Bike Project #2. This is one of my unfinished projects. Hope to complete it real soon.
Back in 2007 I charged and discharged a few times. After that battery just sat. Now the charger that came with battery will not charge. I charged each cell separately with Hyperion EOS 1420i NET3 Charger. Cell number 8 is dead and swollen. Cell number 7 is swollen a little on the bottom.
I need to buy 2 cells. Ypedal, do you got any cells for sale?
Test with CBA III - Computerized Battery Analyzer
Attached please see PDF file 48V_20Ah_test1
48V_20Ah_test1.pdf
(74.17 KiB) Downloaded 7 times
cel01:
Description: 1 Li-ion cell, 20.0 Ah @ 20.00A
Started At: 4/15/2012 9:44 PM
Discharge Rate: 20.00 A
Starting Voltage: 4.00 V
Ending Voltage: 2.80 V
Total Time (hh:mm:ss): 00:31:06
Tested Capacity: 10.423 Ah
cel02:
Started At: 4/15/2012 10:34 PM
Total Time (hh:mm:ss): 00:40:47
Tested Capacity: 13.665 Ah
cel03:
Started At: 4/16/2012 7:49 AM
Total Time (hh:mm:ss): 00:37:04
Tested Capacity: 12.419 Ah
cel04:
Started At: 4/16/2012 8:40 AM
Starting Voltage: 4.02 V
Total Time (hh:mm:ss): 00:39:54
Tested Capacity: 13.369 Ah
cel05:
Started At: 4/16/2012 9:39 AM
Total Time (hh:mm:ss): 00:35:20
Tested Capacity: 11.837 Ah
cel06:
Started At: 4/16/2012 5:57 PM
Starting Voltage: 3.97 V
Total Time (hh:mm:ss): 00:34:23
Tested Capacity: 11.519 Ah
cel07:
Started At: 4/16/2012 6:43 PM
Total Time (hh:mm:ss): 00:27:54
Tested Capacity: 9.344 Ah
cel08:
:cry:
cel09:
Started At: 4/16/2012 8:18 PM
Starting Voltage: 3.99 V
Total Time (hh:mm:ss): 00:31:22
Tested Capacity: 10.507 Ah
cel10:
Started At: 4/16/2012 8:57 PM
Starting Voltage: 4.03 V
Total Time (hh:mm:ss): 00:44:16
Tested Capacity: 14.833 Ah
cel11:
Started At: 4/17/2012 8:48 AM
Starting Voltage: 4.01 V
Total Time (hh:mm:ss): 00:34:38
Tested Capacity: 11.602 Ah
cel12:
Started At: 4/17/2012 9:34 AM
Total Time (hh:mm:ss): 00:34:42
Tested Capacity: 11.625 Ah
cel13:
Started At: 4/18/2012 8:36 AM
Total Time (hh:mm:ss): 00:39:18
Tested Capacity: 13.168 Ah
ebikes.ca
MARTY
marty
Postby heathyoung » Mon Apr 30, 2012 7:21 pm
You could run it as a 12S, just need to determine if the BMS can be reconfigured. Most of the people running LIPO are counting 12S at 44V.
Your pack is also only as strong as the weakest cell - so you have a 10AH pack now.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby Ypedal » Mon Apr 30, 2012 7:27 pm
Well.. i'm either making a 9S pack from mine if the rest will deliver 15+ ah, but if the remaining cells follow the capacity curve of yours and i cant get more than 13ah from a 20ah cell.. it's retirement time... if that's the case you can have anything i retire !! :wink:
Ypedal
Next
Return to Battery Technology
Who is online
Users browsing this forum: dnmun, Google [Bot], kortas, peterperkins and 8 guests
