GBP Battery Co / 48V 20Ah Li-ion
Re: GBP Battery Co / 48V 20Ah Li-ion
Postby fechter » Sun Apr 22, 2012 10:55 am
Well, then you should have long term test results by now :wink:
I love the rusty scale!
fechter
Postby cwah » Sun Apr 22, 2012 6:48 pm
My battery (Limn2O4 or Li(NiCoMn)O2) has lost 40% of its capacity in 6 months.
Have done around 70-100 cycles on it.
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby nechaus » Sun Apr 22, 2012 7:09 pm
Thats some nice old looking scales.
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Postby Kin » Mon Apr 23, 2012 1:46 am
cwah wrote:My battery (Limn2O4 or Li(NiCoMn)O2) has lost 40% of its capacity in 6 months.
That's insanely high. What C rating are you running it at? Does the pack get hot after using it?
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby cwah » Mon Apr 23, 2012 3:50 am
Yeah, that's really bad. I'm only running at 1.2C rating continuous.
Not very high.. Very often I leave my bike outside, on the cold (0 Celcius outside) and the heat (25 Celcius outside). Maybe sometime the sunlight damaged the batteries as the decay is extremely fast over 50 Celcius. I can't tell thought.
cwah
Postby Hugues » Mon Apr 23, 2012 5:49 am
I compared the 100ah type of GBP to a Winston cell,
Winston comes out much better in term of energy density in weight and volume.
Hugues
Switzerland
Mountain bike
XC-204 -> Crystalyte HT3525/Infineon ctrlr 40 A EB712XC board/LiPo 88 V 10ah
All Terrain Vehicle
Hanebrink -> Crystalyte HS/Infineon ctrlr 20 A/Allcell Li-ion 36 V 10ah
Motor bike Cruiser
My build thread here
Hugues
Postby Ypedal » Sat Apr 28, 2012 7:31 pm
I got 2 of the 36v 20ah packs made from these cells just about the same time Marty got his ( a few months before ) .
I just ran a capacity test on one of the 2 packs ( I've let a local friend use it for the last 2 years. )
I fully charged the pack, cell by cell to 4.20v via the ballance leads. let sit overnight..
cell no.9 of 10 is bad from day 1.. had a big dent in it on arrival.. falconev was not honoring any warranties so it's been used as is since..
I got 8.0 ah before cell.9 dropped to 3.1v, all other cells holding 3.6v ..
Marty, are you using that pack ?
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby marty » Sun Apr 29, 2012 7:47 am
Bought this battery for Electric Bike Project #2. This is one of my unfinished projects. Hope to complete it real soon.
Back in 2007 I charged and discharged a few times. After that battery just sat. Now the charger that came with battery will not charge. I charged each cell separately with Hyperion EOS 1420i NET3 Charger. Cell number 8 is dead and swollen. Cell number 7 is swollen a little on the bottom.
I need to buy 2 cells. Ypedal, do you got any cells for sale?
Test with CBA III - Computerized Battery Analyzer
Attached please see PDF file 48V_20Ah_test1
48V_20Ah_test1.pdf
(74.17 KiB) Downloaded 7 times
cel01:
Description: 1 Li-ion cell, 20.0 Ah @ 20.00A
Started At: 4/15/2012 9:44 PM
Discharge Rate: 20.00 A
Starting Voltage: 4.00 V
Ending Voltage: 2.80 V
Total Time (hh:mm:ss): 00:31:06
Tested Capacity: 10.423 Ah
cel02:
Started At: 4/15/2012 10:34 PM
Total Time (hh:mm:ss): 00:40:47
Tested Capacity: 13.665 Ah
cel03:
Started At: 4/16/2012 7:49 AM
Total Time (hh:mm:ss): 00:37:04
Tested Capacity: 12.419 Ah
cel04:
Started At: 4/16/2012 8:40 AM
Starting Voltage: 4.02 V
Total Time (hh:mm:ss): 00:39:54
Tested Capacity: 13.369 Ah
cel05:
Started At: 4/16/2012 9:39 AM
Total Time (hh:mm:ss): 00:35:20
Tested Capacity: 11.837 Ah
cel06:
Started At: 4/16/2012 5:57 PM
Starting Voltage: 3.97 V
Total Time (hh:mm:ss): 00:34:23
Tested Capacity: 11.519 Ah
cel07:
Started At: 4/16/2012 6:43 PM
Total Time (hh:mm:ss): 00:27:54
Tested Capacity: 9.344 Ah
cel08:
:cry:
cel09:
Started At: 4/16/2012 8:18 PM
Starting Voltage: 3.99 V
Total Time (hh:mm:ss): 00:31:22
Tested Capacity: 10.507 Ah
cel10:
Started At: 4/16/2012 8:57 PM
Starting Voltage: 4.03 V
Total Time (hh:mm:ss): 00:44:16
Tested Capacity: 14.833 Ah
cel11:
Started At: 4/17/2012 8:48 AM
Starting Voltage: 4.01 V
Total Time (hh:mm:ss): 00:34:38
Tested Capacity: 11.602 Ah
cel12:
Started At: 4/17/2012 9:34 AM
Total Time (hh:mm:ss): 00:34:42
Tested Capacity: 11.625 Ah
cel13:
Started At: 4/18/2012 8:36 AM
Total Time (hh:mm:ss): 00:39:18
Tested Capacity: 13.168 Ah
ebikes.ca
Online resource for electric bicycle conversions
http://www.ebikes.ca
MARTY
Volt Electric Vehicles
http://www.voltev.com
marty
Postby heathyoung » Mon Apr 30, 2012 7:21 pm
You could run it as a 12S, just need to determine if the BMS can be reconfigured. Most of the people running LIPO are counting 12S at 44V.
Your pack is also only as strong as the weakest cell - so you have a 10AH pack now.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby Ypedal » Mon Apr 30, 2012 7:27 pm
Well.. i'm either making a 9S pack from mine if the rest will deliver 15+ ah, but if the remaining cells follow the capacity curve of yours and i cant get more than 13ah from a 20ah cell.. it's retirement time... if that's the case you can have anything i retire !! :wink:
Ypedal
Previous
Return to Battery Technology
Who is online
Users browsing this forum: shorza, Teh Stork and 10 guests
