fredtr said:
I see the NiMH C and D cells, 9 AH, 10 AH are cheap, so I am wondering if it is worth building up a pack and trying it. Have read some of the posts and looked at the specs. Doesn't look like they typically spec NiMH at high discharge rates. So I expect they don't do well at high discharge, but my riding habits are only high discharge for the very end of the ride. So my question is, has anyone had good luck with NiMH? I am specifically thinking of building a 9 AH 36 volt pack for an Iacocca bike.
Thanks,
Fred
Your high discharge rate at end of ride will cause an increase of temp in low cost cells, and delay the charger turning on, and when it does, it will be charging a warm pack. In the summer this will cause problems that you need to compensate for, like charging on a timer in the middle of the night.
The lower the voltage to power ratio, or put differently- the lower the current demand-pak or otherwise, the better NIMH performs.
I have worked with and used NIMH for quite a few years. If you are going to go 24v on a 400w peak motor with low cost cells, you will need to run 2 paks in parallel.
But if you want to avoid that, try running at least a 48v system. this will give you 500 watts at ~10 amps, easier on the cells. A 72v system with a 8 amp current limit would be nice, with two 36 volt chargers. that would last a long time.
Good chargers are also important, and knowing what you are doing.
there has been lots written here about NIMH, and if the cost is going down, some good price/performance can be be had. but understand that you have to keep the current down and you have to keep them from getting too warm , during charge, discharge or storage.
I met a fellow in Orange county this winter, he had 30 ah of NIMH on his 24v ebike. It was going on its 7th year. But he had packs in parallel and he used 1/12C over nite charging , he did not use the delta temp over time charging, just the overnite trickle on a timer. So it can be done.
Due some serches on NIMH, and be sure to design you system for minimum current and tempertures for true low cost cost of operation.
your Iacocaa ebike will Low voltage trip on cheap NIMH voltage sag unless you give it two packs in parallel.
my two watts worth
d
