New 10S Zippy packs from HobbyCity
Postby andreym » Mon May 31, 2010 11:11 am
Have you seen this?
What do you think?
It seems nice price for that pack.
10S will give about 37v most of time and 41.5 hot of right e-biker charger )
could be just paralleled for required capacity.
Or 20S for really crazy guys.
Gary, is it possible to make 10s HVC/LVC boards? or it could be easier to use 2 of 5S boards with correct connectors?
ps. just noticed - it has 2 balance leads connectors, so i assume they are 5S each - much easier to use battery medic (boosted) to balance them.
Avanti D8 CroMo frame, CroMotor :) + MAX-E controller. 18s10p zippy compact in Pelican 1300 case. 1.8kwhrs total usable capacity.
fast 1.2kw charger old GT iDrive e-bike
andreym
Re: New 10S Zippy packs from HobbyCity
Postby torker » Mon May 31, 2010 12:12 pm
So cool that they are making larger packs. And that one pack has as much range as my 21 lbs. of lead and only 40 dollars more. I think it is just about time to upgrade. :mrgreen:
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 10s Lipo 30+ amps
Specialized FSR Comp 9C 6*10 15s x 50A 3300 W :)
torker
Postby andreym » Mon May 31, 2010 12:40 pm
I have just calculated Wh/dollar and it seems nothing can beat These
but 10S is really convinient!
and i hope someday they will start to offer 12-16S packs.
BTW why they does not sell packs for e-bikes?
I think those first 100 8S packs was sold mostly to e-bikers :D
I ordered myself 4+6+6 = 16packs for me and 2 of my friends who want crazy 100v bikes (Thanks to Lyen`s Controllers!)
andreym
Postby torker » Mon May 31, 2010 1:18 pm
I want a single 48 v pack for simplicity. Maybe 2 of the 6s in series would work good. Not sure if I can just hook them in series without a problem. I've read some of the Turnigy lipo thread but not enough to really have it figured out. I am a little scared that I might hook something up wrong and BOOM :oops: Maybe Mike will compile that in a book too. :mrgreen:
torker
Postby dogman » Mon May 31, 2010 6:14 pm
2 6s in series would get you close to 48v. No problem except the usual one of having to make up plug systems for breaking them apart to charge 6s since 12s chargers aren't common. To get a 10 ah pack, you'd paralell connect two 6s packs to make a 10 ah 6s block, and then series connect those two to get bike voltage.
They need to make ebike packs, but the 10s packs are a start, providing a one pack 36v 4.5 ah battery. There is a 10s charger to go with it.
http://www.hobbycity.com/hobbycity/stor ... ce/Charger
Good charger I suppose, but ouch! $190
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby andreym » Tue Jun 01, 2010 10:31 am
dogman wrote:2 6s in series would get you close to 48v. No problem except the usual one of having to make up plug systems for breaking them apart to charge 6s since 12s chargers aren't common. To get a 10 ah pack, you'd paralell connect two 6s packs to make a 10 ah 6s block, and then series connect those two to get bike voltage.
it`s actually 159 for platinum members ) or you may also get it here for the same price but with free shipping of you are in US
still quite expensive but should be good for 10S accurate balancing
or you can get cheap meanwell supply and 2of Gary`s 5s boards to get complete hvc/lvc control on them.
andreym
Postby dogman » Wed Jun 02, 2010 6:13 am
Just wanted other noobs to know the cheaper 6s chargers won't charge it. At first, I thought they hooked to the balance leads to charge, so I nearly bought some 10s packs thinking you could just charge half the pack at a time.
dogman
Postby lespuff » Wed Jun 02, 2010 8:51 am
Yeah I was eyeing those pack too. Since i'm a newbie and tab bit unsure about wiring up a serial connected pack to raise the voltage to 48v. I have a few questions though.
1. I was planning on getting the Mini motor from Conhis, Golden or just the Cute motor @ 350 watt. Is there a big different with 48v and 36v when using a 350 watt motor? I know the motor spins faster with a higher voltage but, is it worth me getting 48v and having to wire up a big 48v pack.
2. If I get 2 of these 10s 4500mah pack and wire them parallel to 9000mah. Would that be enough to run a 36v 350 watt fairly flat terrain about 10 miles? Would this battery be to strong for the motor? etc...
I think I know the answers but, just wanted to confirm.
Also, It seems to be better for a newbie with lipos to just use these packs since I don't have to wire it up serial and parallel. That should make charging the batteries a little easier. Just want to confirm.Thanks in advance.
lespuff
100 µW
100 µW
Postby dogman » Wed Jun 02, 2010 2:12 pm
I don't know about the motor and 48v. For starters, you'd need the controller to be able to do 48v. Most can on the bigger direct drive motors, but smalller 350 watt controllers may not have 63v caps in them.
BTW, these 10s packs are 36v nominal voltage. So the normal controllers would be fine, and the discharge capacity won't matter to the motor or controller. It won't put more amps through the motor than the controller allows. For 48v you'd need 14 or 15 s to have about 56-60v hot off the charger.
My rule of thumb for 36v bikes that go 25 mph is 1 ah per mile range. This rule means your 9 ah pack would go 9 miles, and still have about 15-20 % left in reserve. At 20 mph, you'd have plenty of range if the bike is not able to go 25 mph on 36v.
This would make a good setup for a 36v bike. You could run most motor kits easily on one pack, and then add packs later as range is needed. Since they would be paralelled, a 10s charger could still charge them all together, paralelled. You'd paralell connect the main wires, and paralell connect the balance taps, and then just connect them to the charger. Above 10s, then it would get more complicated.
dogman
Postby neoplasticity » Wed Jun 02, 2010 2:36 pm
does anyone know if the 22.2V lipos will run a 24V EV global ebike? or will the controller refuse to run because of the missing 2 V?
neoplasticity
1 W
1 W
Postby John in CR » Wed Jun 02, 2010 6:01 pm
andreym wrote:Or 20S for really crazy guys.
20s is for girls. The name of the game now is 30s till I have a way to charge an odd 5, and then it will be 35s. :mrgreen:
John
John in CR
Postby dogman » Wed Jun 02, 2010 6:25 pm
They should run an evg, but it will be even slower than usual. Fully charged, sla's would be about 27v so more than 3v short.
But you could series a 10s pack and a 1 s pack and be just right, or a 5s and a 6s. Even better, go to 12s, chances are the controller can go to at least 30v with no problems. Then you'd have a 15 mph bike instead of an 11 mph bike.
But really, cheap lifepo4 like a ping would run that evg great. So just get a much simpler and eaiser to charge 24v 15 ah ping, and have huge range.
dogman
Postby maydaverave » Sun Jul 18, 2010 6:40 pm
Anybody know if there is a small 5s charger that could charge these through the balance leads? If I understand correctly to charge through the power wires you have to have a 10s capable charger but it has two 5s balance leads.
e-bikekit 50v 9.2ah cellman pack
maydaverave
Postby icekreme1002 » Sun Jul 18, 2010 7:00 pm
maydaverave wrote:Anybody know if there is a small 5s charger that could charge these through the balance leads? If I understand correctly to charge through the power wires you have to have a 10s capable charger but it has two 5s balance leads.
I am also curious as to if this will work???
Not that It will suit everyone, but I wonder if you could charge a 5s pack through balance leads and charge plugs, and charge the 10s through some parallel balancing leads at the same time?
Of course balance leads wont take more than 5amp, recommended less, around 2 or 3ish.... But maybe this is an easy way to slow charge for those after 15s setups?
Not really willing to risk 100usd to check though... lol
1st build - Norco Hardtail, 18s Lipo, HS3540, Lyen 18fet 45/120amps
http://endless-sphere.com/forums/viewtopic.php?f=6&t=32041
icekreme1002
Postby maydaverave » Sun Jul 18, 2010 7:03 pm
I was thinking about something like this http://hobbycity.com/hobbyking/store/uh ... 240v_Input
only 5s capable. Two per battery. It would be a cheap easy lipo option for us noobs lol.
maydaverave
Postby icekreme1002 » Sun Jul 18, 2010 7:16 pm
Not sure if you will be able to do 2 chargers per battery though? You may end up with a different balance between both lots of 5 cells.
If it is possible probably better to use one charger so you get a better and easier balance.
I'm thinking something like this...
http://www.hobbyking.com/hobbyking/stor ... duct=11060
Have you seen these?
http://www.hobbyking.com/hobbyking/stor ... 6S_w/_XT60
Maybe something like that but set for 5s-5s would do the trick? It seems that has the main power cord and 1 balance spit into 2.
But as you can see it plugs 2 3s packs into a 6s balance. Not sure how to build it 2 lots of 5s to one 5s with the main plug in there but that makes me think it is possible.
More info on parallel charging here....
http://www.rcgroups.com/forums/showthread.php?t=932319
icekreme1002
Postby mwkeefer » Sun Jul 18, 2010 8:31 pm
You CANNOT PARALLEL CHARGE a 10S Zippy Pack!
They have 2 5S balance taps yes but hook them together in parallel and BOOOM, fizzle bye bye balance taps!
You could use (in theory) 2 chargers set to 5S each and hooked in series but you would also need 2 power supplies for them...
The easiest answer by far is get a 36-48v meanwell S-350 (so a -36 or -48)... tune it all the way down (should get around 41.5 on a 48v) for a 48v or up for a 36... Target voltage is 41.5v flat... 41 is ok, 42 is ok, 42.x is not ok!
Connect that supply to a paralleled (9AH) 10S pack and let er rip, for extra measure 2 battery medics (one for each 5S in series) will balance them independently and show you if any of them creep too high.
Total cost to charge:
1 x meanwell S-350-48 @ 31 + 15.00 s&h = $36.00 / 48 for EMS
2 x Any 6S balancer like the Battery Medics @ 25.00 ea = 50.00
Total: 86.00 for a 12-15A charge rate (the Zippy can handle up to 2C according to the website but I've charged them at 4C many, many times)..
Regards,
Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
mwkeefer
Postby icekreme1002 » Sun Jul 18, 2010 8:42 pm
mwkeefer wrote:You CANNOT PARALLEL CHARGE a 10S Zippy Pack!
Well there ya go.... Cheers Mike!
icekreme1002
Postby maydaverave » Wed Jul 21, 2010 1:01 am
Regards,
Mike
the 3s balance tap charger I linked to is 11.95 and it plugs directly into an outlet with no need for a power supply. even if a 5s version was a bit more you would be looking at about $130.00 for a battery and chargers. Double that and you would have 37v 10ah for $260.00. A great budget setup or spare pack. Only problem is no 5s balance tap charger that I know of :( .
maydaverave
Postby sharkmobil » Thu Jun 30, 2011 8:02 pm
Let's say I connected four of those long bricks in a 2s2p configuration.
Can I put them on a 84v 12a charger and forget about fidgeting with connectors?
sharkmobil
Postby neptronix » Thu Jun 30, 2011 9:17 pm
If you don't want them to be balanced while you are charging, sure.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Return to Battery Technology
Who is online
Users browsing this forum: Google [Bot], zerogee and 9 guests
