fechter wrote:The alarm output is rated for 500mA. If your throttle pull down circuit uses a 1k resistor, the maximum it will take is less than 5mA. Many piezo alarms will be well under 500mA, but check the ratings.
heathyoung wrote:For the more adventurous there are some 'interesting' hacks that can be done - I modified an 8S unit for checking the balance across 8S 12V batteries - its pretty simple to do, just some resistive dividers and some unity gain opamps.
EBJ wrote:fechter wrote:The alarm output is rated for 500mA. If your throttle pull down circuit uses a 1k resistor, the maximum it will take is less than 5mA. Many piezo alarms will be well under 500mA, but check the ratings.
Thanks, but I just decided to run the alarm off the relay I was already using for the throttle pull-down.
(which is something like 25mA) It's a sure-bet this way since I know my cell-logs are able to power these relays.
heathyoung wrote:Its an external circuit. I'll find the schematic and post it up. Very simple, I used it to help out someone trying to find a battery that was dying under load. He had 8 12V batteries in series.
heathyoung wrote:Sure, I have a version on the PC here I think.
For 7 cells, you just wouldn't connect to the cell 8 tap.
Pir wrote:heathyoung wrote:Sure, I have a version on the PC here I think.
Thanks for your schematics. But IMHO must be interconnections zeners 18V anodes with 100k and 5v1 anodes with output lines, or I'm wrong?
heathyoung wrote:The zeners are reversed biased - they form a voltage clamp when their rating is exceeded, basically forming a shunt ( that is a low impedance path) to protect the op amp input circuitry and cell log inputs if the voltage exceeds normal limits. In theory they aren't needed in practice they likely are.
You could omit them if you like but they are a protection mechani from spikes produced by motor emf etc.
heathyoung wrote:I have a PCB design around here somewhere as well.
whatever wrote:can i confirm something mentioned earlier, you can put an on/off switch on the negative wire to cell log to cut all power to it?
anyone done this?
dumbass wrote:whatever wrote:can i confirm something mentioned earlier, you can put an on/off switch on the negative wire to cell log to cut all power to it?
anyone done this?
That's the way I've been doing for more then a year with no problems. Some say there is still a slight power draw but it's very small if any.
Bob
whatever wrote:thanks for confirming the neg off switch works,
another question for da gurus:
the graph that show voltage as bar graphs does anyone know if it represents the high and low voltage settings?
I mean lets say one bar goes right down to the bottom does that represent the low voltage alarm point or does it go right down to zero volts?
Users browsing this forum: No registered users and 9 guests
