CellLog 8 hacking
Re: CellLog 8 hacking
Postby NeilP » Sat May 12, 2012 7:59 am
I was going to start a new thread for this, but came across this thread
I just did a stupid thing... :oops: yes, OK another stupid thing..
Anyway. I came across a link for the firmware upgrader for the celllog ..so though I would give it a try.
http://www.jun-si.com/UploadFiles/Upgrader.rar
you guessed it, I screwed the cellog. The upgrader says it completely, but when ever I plug that celllog in to a pack I get this:
Err: Flash Memory.
Seems to fire up OK other wise, but have not tried any cell loggin yet.
Is there a way to fix this?
Neil
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Postby NeilP » Sat May 12, 2012 10:58 am
Got it working myself in the end.
I checked the other cell logs I have, and noted that the Upgrader
was not upgrading..it was downloading and installing the same firmware as was already isntalled.
SO I though I would see if it was possible to donwgrade to earlier if I manually d/loaded the firmware
From the address in teh donwloader, I took guesses at what the older firmware was called..not difficult to guess
http://www.jun-si.com/UploadFiles/CellLog(8S)_V208.bin was the same firnmware as I had on originally, and the others have.
I tried V206, V205 , and got d/loads for them all.
I then tried V208...and ended up with newer firmware. which flashed and worked with no errors.
strange though that the upgrader software does not find this later firmware.
Can't immediately notice any changes in it though
180mm disks
100V 20Ah LiPo
NeilP
Postby EVPowers » Sat May 12, 2012 9:41 pm
heathyoung wrote:I have a PCB design around here somewhere as well.
First, thank you so much for the pdf. I knew it must be possible, but didn't know how.
If you do come across the pcb design someday, I'd love to see it.
Great work and thanks again for sharing!
EV Powers
A green-vehicle workshop in Madison, WI
http://www.EVPowers.com
608-729-4082
EVPowers
Postby whatever » Fri May 18, 2012 12:43 am
can i confirm something mentioned earlier, you can put an on/off switch on the negative wire to cell log to cut all power to it?
anyone done this?
whatever
Postby hillzofvalp » Fri May 18, 2012 12:45 am
i just saw a go kart team who had 4 cell logs on each of their 4 battery packs... that's a lot of loggin'
hillzofvalp
Postby dumbass » Fri May 18, 2012 1:25 pm
whatever wrote:can i confirm something mentioned earlier, you can put an on/off switch on the negative wire to cell log to cut all power to it?
anyone done this?
That's the way I've been doing for more then a year with no problems. Some say there is still a slight power draw but it's very small if any.
Bob
dumbass
Postby EBJ » Fri May 18, 2012 4:13 pm
anyone done this?
Bob
yeah, I have a main on-off switch running to a relay that will interrupt the cell-log negative (turning it off).
I did some real-world testing w/ cell-level voltage readings, and my 20Ah pack would take something like 60 days to drain when left "off" and at about 65%-charge (storage charge).
And I think w/ everything left "on" it would take something like 6 days to drain. But I also have an alarm that would be triggered at LVC... so if you hear the alarm you know you screwed up and left the thing "on". I don't know what the exact #'s were since I did the calculation a while ago, but I do know I found no problem w/ that method of "turning off" the cell-logs.
EBJ
Postby whatever » Tue May 22, 2012 6:13 am
thanks for confirming the neg off switch works,
another question for da gurus:
the graph that show voltage as bar graphs does anyone know if it represents the high and low voltage settings?
I mean lets say one bar goes right down to the bottom does that represent the low voltage alarm point or does it go right down to zero volts?
whatever
Postby dumbass » Wed May 23, 2012 8:12 pm
whatever wrote:thanks for confirming the neg off switch works,
Good question. It represents the true voltage of each cell but the value (height of the line) at a given voltage will change based on the max voltage setting. But I'm not sure what it does for the low voltage.
Bob
dumbass
Postby whatever » Wed May 23, 2012 9:53 pm
thanks bob, instead of being lazy i'll check in the next day or two about low voltage and post
whatever
Postby EBJ » Wed May 23, 2012 11:16 pm
ok, I've got a question.
Does the Celllog still trip its LV alarm when it is in "Sleep Mode" ?
I ask because the last 2 times I "thought" the pack was low, I switch OFF / ON the cell-logs and then they started tripping the LVC only moments later.
(It could just be coincidental though...)
EBJ
Postby dumbass » Thu May 24, 2012 8:29 am
EBJ wrote:ok, I've got a question.
I had a simular problem but on HV alarm. The CellLog would go into sleep mode while charging and I had cells going over 4v (lifepo4). When I would touch a button on the CellLog the screen would light and the alarm would go off. I actually did correct the problem but damn if I can remember how I did it. But it was in the settings that I made a change and it's been fine from then on. In any case I would do a trip test on it by setting the HV just above the highest cell. Then let it go into sleep mode and start the charger. It shouldn't take long for it to activate the alarm if it's working correctly. I've never had a reason for a LV alarm but I'm guessing if it works for HV it will work for LV too.
Bob
dumbass
Postby EBJ » Thu May 24, 2012 10:45 am
Bob
Interesting. Maybe someone else can chime in and we can figure out what is happening. I could have sworn they worked fine previously, but now I think I am experiencing the same you were: A lack of detection in "sleep mode".
EBJ
Postby dumbass » Thu May 24, 2012 3:24 pm
Yeah, it was strange because I gave detailed instructions to another guy how to wire the CellLog and set it up. I gave him all my setting to copy which he did. He never had a problem but I did. I remember just resetting everything and making a small change here and there on some odd settings that normally would have nothing to do with the problem. Bottom line it worked on both my units.
Bob
dumbass
Postby EBJ » Thu May 24, 2012 4:21 pm
dumbass wrote:Yeah, it was strange because I gave detailed instructions to another guy how to wire the CellLog and set it up. I gave him all my setting to copy which he did. He never had a problem but I did. I remember just resetting everything and making a small change here and there on some odd settings that normally would have nothing to do with the problem. Bottom line it worked on both my units.
Bob
Perhaps I will ditch the "sleep mode" and instead turn down the screen brightness.
I also noticed that the cell-logs have a "time-out alarm". I haven't tested it yet, but I imagine it is used to sound an alarm when you leave the thing powered ON for too long? (In which case that could be a nice feature if you have it hooked up to trip a BUZZER.... It could warn you when you leave your ebike ON)
EBJ
Postby dumbass » Thu May 24, 2012 7:51 pm
I will need to take a look at how mine are setup again. I know I have the screen saver activated but I may have turned off the sleep mode. It's hell when ya get old........anybody seen my pants?
Bob
dumbass
Postby EBJ » Sun May 27, 2012 10:35 am
I just pulled open the battery box and switched over from sleep mode to "backlight off" mode (after 3-min).
I imagine that will solve my problem.
EBJ
Postby dumbass » Sun May 27, 2012 4:43 pm
EBJ wrote:I just pulled open the battery box and switched over from sleep mode to "backlight off" mode (after 3-min).
As I mentioned I would recommend setting the HV to just above the highest cell voltage. Allow it to go into the backlight off mode. Then charge it and see if the alarm activates now.
Bob
dumbass
Postby auraslip » Sun May 27, 2012 9:48 pm
anyone have the fun problem where the screen gets flipped upside down? all it takes is a flick to make it go back. it's kinda like in star wars where han solo has to hit something to make it work.
auraslip
1.21 GW
1.21 GW
Postby megacycle » Mon May 28, 2012 1:37 am
Yeh what weird kinda firmware issue makes it do that, or the wackiest gremlin, having to do headstands to view the screen.
Iron Horse SGS Pro DH.
72V 16AH lipo. 3kW charging system.
Modded Crystalyte 72V/50A, regen, 3 stage overcurrent.
4060 ☆/\, 20mm cover holes.
Hyena supplied motor (much appreciated Onya mate)
5404 next build giant strata, A123 20Ah, 72/large.
megacycle
Postby whatever » Mon May 28, 2012 8:41 am
i've checked the graph function in respect to whether the graph goes down to zero volts or just down to the low voltage alarm point, it seems fairly obvious it goes only down to the low voltage alarm.
below is a pic, its a 7 cell ( lilo - cobalt pack), cell no.7 has a voltage of 3.529v, I adjusted the low voltage alarm point to
3.5v ( normally its 2.5v) and its quite obvious the graph only displays down the the low voltage point.
( the graph high voltage point was 4.1v and the tops of the cells with high voltage has spread up a bit far but no problem)
whatever
Postby EBJ » Mon May 28, 2012 10:52 pm
Bob
yeah, that's a good way to test it.
But I just did a "real-world" test because I didn't wan't to open up the battery box twice.
In "backlight off" mode everything functioned as it should. LVC tripped many times w/o any problems.
I guess mine were either (1. not working, or 2. a little delayed) when in "sleep mode".
EBJ
Postby dumbass » Tue May 29, 2012 3:58 pm
Like I said I'm not sure if I have mine set in the screen saver mode or sleep mode. And considering I screwed up my knee again and can't ride for several weeks again I'm not likely to check it for a while. Most likely it's in the screen saver though.
Bob
dumbass
Postby EBJ » Tue May 29, 2012 11:11 pm
ok, new question:
Does anyone know how the "time-out" alarm works ?
Because I was under the impression it would cause the cell log to alarm-out after "x" amount of time.
I tested it today, and I couldn't get it to alarm.
Any ideas ?
EBJ
Postby auraslip » Tue Aug 14, 2012 10:42 pm
Just a heads up. The even drain mod doesn't appear to work over a period of weeks. After roughly a month the cells are know 100 mv off.
My setup is to leave them constantly plugged in, but to have the 1 ground pin broken on each unit via relays. Works great and is a fantastic setup, but it looks like I'll have to be balancing every month if i want to use them like this :( :( :(
Another issue I'm having is a "phantom cells" that pop up on my 6s pack showing .3v for cell 7 or 8. I believe this is an issue with the even drain mod.
auraslip
1.21 GW
1.21 GW
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: No registered users and 9 guests
