rolf_w wrote:great to see new faces in the attempt to master the OZ890 (which still is my preferred BMS chip) and the SmartBMS (which still is the best value for money). I would like to understand a bit better what you did, my russian is a bit rusty
If a Russian is bad, you can use http://translate.google.com/translate?s ... 507.0.html
rolf_w wrote:us__007 wrote:I do cascading 2 SmartBMS. Charge and discharge switches allow you to turn it on 100V. I replaced two of the transistor in the circuit current shunt 100 volt.
you replaced the FET on the high side SmartBMS with resistors?
see Fig. 2
rolf_w wrote:us__007 wrote:Conclusion SCRL chip zener protected at 58B. in the chain of the legs of the resistor R31 replaced with a face value of 2k 30k.
please explain further
see Fig. 1
rolf_w wrote:us__007 wrote:EFETC connected to the output optocoupler, the leg is configured to turn off the charge.
you followed the AN#16 from O2Micro? 'EFETC-Out' on high side SmartBMS > optocoupler > 'EFETC-In' on the low side SmartBMS ?
I'm just busy looking for the source I have almost determined.Output EFETC can not serve as a source of signal off the charge. I'll be taking a signal from the point of CG, handle and serve on the transistor optocoupler.
rolf_w wrote:us__007 wrote:Thanks to a colleague Mevial http://electrotransport.ru site for the monitoring program, the configurator and advice.
looks like an interresting and busy site - what about this 'monitoring configurator' program - is it made for the OZ?
r
Colleague Mevial wrote the console program for Linux to query information from the BMS, download and dump configurator http://mevial.ru/oz/. ty program can be found in the theme of the first link or here http://translate.google.com/translate?h ... 3msg156763
The program eliminates the need for expensive cable for $ 100 http://www.paintyourdragon.com/?p=43
