Noob Lipo Dummy (need a Lot of help)
Postby TopCat » Fri Dec 03, 2010 1:10 pm
Hi Guys,
Im ready to make the jump from heavy sla to lipos but am at a loss as where to start. :oops:
I know there are lots of lipo threads/posts/topics on the forums but reading through these just gets me all confused and makes my head hurt. Volts - Watts - Amps are all greek to me.
This is the motor and controller that I have...
36V 500Watt motor.
36V 800W YK31C Electric Scooter LBD14 Controller 038
http://cgi.ebay.co.uk/36V-800W-YK31C-Electric-Scooter-LBD14-Controller-038-/160463657764?pt=UK_Sporting_Goods_Scooters_LE&hash=item255c611b24
It was suggetsted to me on another forum - http://motorbicycling.com/f55/feedback-request-these-blue-lipo-batteries-23402.html that I go with these batteries and charger...
Batteries.
Turnigy 5000mAh 5S 25C Lipo Pack.
Charger.
iCharger 1010B+ 300W 10s Balance/Charger. - Not in stock at moment at hobbyking.
Reading through a good few of the lipo threads/posts I came across this link - http://www.rchelicopterfun.com/rc-lipo-batteries.html it was here that I read this...
All this said, RC LiPo packs are coming down in price all the time. If you find a 30C pack for the same price as a 20C when that is all you need, go for the 30C pack - it will run cooler and most likely last a little longer. Like most things, pushing a Lipo pack hard close to its limits will wear it out in short order. Having wiggle room on the high side will ensure that won't happen.
Having read this I went looking on hobbycity in the battery section and found these Turnigy 5000mAh 5S 30C Lipo Pack which now leads to more confusion!
Having been recomended that I buy the Turnigy 5000mAh 5S 25C Lipo Pack, then finding the Turnigy 5000mAh 5S 30C Lipo Pack, which one do I buy? remembering that I'd need to buy a few to hook up together for range.
Next up is the wiring?
I'd like to know what type/guage is on these Turnigy batteries, that way when I order the RIGHT batts I can also order up some wire to connect them all together.
Then theres connectors for hooking everthing together. The EC3 connectors mentioned on http://www.rchelicopterfun.com/rc-lipo-batteries.html look like a solid connector but are these the type i'd need to connect all my batts in series to make a 36V pack.
If I havent already got enough to confuse me It was suggested that I goto GGoodrums site - http://www.tppacks.com/products.asp?cat=26 and buy some of his stuff to help make/monitor and charge my pack.
No idea what to buy or what any of those boards do except that there for helping charge your batts.
I have only been used to working with SLA batteries which were relatively simple. Get 3 12V batts and wire them up in series, charge them up with a 36V charger and away we go. Where as with these lipo batteries there seems to be an endless shopping list of things you need to buy to get and keep them working.
Regards
Tom
TopCat's Spoiler
http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=19663
I started off with nothing and I still have most of it left.
TopCat
Re: Noob Lipo Dummy (need a Lot of help)
Postby Jeremy Harris » Fri Dec 03, 2010 3:09 pm
First off, you're only looking to use 500W at 36V nominal (more like 37 to 38V with LiPo) so the current that you're going to be pulling from the cells will be quite modest, around 500 / 37 = 13.5 amps.
If you were to buy 4 off 5S LiPo packs and wired them up as 10S, 2P, then you'd have a 10Ah pack with a voltage of around 37V. 10Ah discharged at 13.5A is a discharge rate of just 1.35C, so trivial in comparison to even the lowest rated LiPo cells.
It's true that higher rate cells are generally likely to last longer if cycled to full depth of discharge frequently, but at this low rate I doubt they'd be a measurable difference.
If it were me, then I'd go for some of the 5000mAh Zippy packs from HK rather than the Turnigy packs, but that's just based on my limited experience. 4 off of the 5S packs will run the bike at 500W for around 40 mins to about 80% discharge, longer if you don't run at full power the whole time.
Jeremy
Jeremy Harris
Postby neptronix » Fri Dec 03, 2010 3:33 pm
Sounds like you're on the right track so far.
I am using 5s batteries at 37v too. Charging them with the 1010b+ is quite convenient.
Don't bother with ec3 connectors, i went that way the first time because there were pre-made parallel /serial harnesses and i thought that was cool, but lemme tell ya, they can be on the flimsy side if you do a lot of connecting and disconnecting.
Buy a bag or two of the ec4 connectors and some 12ga. wire. Make your own battery interconnects from that. That's good up to about 50a before you start seeing any real voltage drops. 50a is a hell of a lot of power, so you have room to grow there.
You won't need 30c packs at all.. you can get away with 15c. ( many LiFePo4 guys have batteries that only put out 1c-2c and they manage!! ) I buy the 25c turnigy packs now though because they're at the USA warehouse. Zippys from China to USA are very expensive to ship.
Those turnigy batteries have 10ga. wire coming out of them and 24ga. balance lead wires. That is super overkill for an eBike application, but consider that RC guys pull like 4x more amps outta these than we do O_O
Also.. order one extra pack in case you get a bad one. trust me on this one; out of 8 packs i already got one dud.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby TopCat » Fri Dec 03, 2010 11:06 pm
Thanks Jeremy and Neptronix. Looks like I have the Batteries and Charger sorted out once Hobbyking gets them back in stock.
As to the connectors Neptronix, iv'e searched HK & the net and cant find any refrence to these EC4 connectors that you mention?
Regards
Tom
TopCat's Spoiler
TopCat
Postby AussieJester » Fri Dec 03, 2010 11:35 pm
TopCat wrote:Thanks Jeremy and Neptronix. Looks like I have the Batteries and Charger sorted out once Hobbyking gets them back in stock.
Regards
Tom
Whats wrong with using the same connectors that come standard on the batteries?!
http://www.hobbycity.com/hobbycity/stor ... pcs/set%29
You must have seen these in your 'search' of the net and HK
If you have read all the info on lipo in the battery section and are still struggling to come to terms with basics, it worries me a little you buying lithium polymer, perhaps lifepo4 would be more suited in this case, a Lifp04 Ping pack would suit yur setup and be alot easier to manage. ;-) lithium polymer can be dangerous if you don't have at least some basic knowledge and understanding of their requirements.
KiM
AussieJester
Postby neptronix » Sat Dec 04, 2010 3:06 am
AussieJester wrote:Whats wrong with using the same connectors that come standard on the batteries?!
:oops: Those are EXACTLY the connectors i was referring to, but i called them ec4.. thanks for correcting me for the sake of the OP.
KiM
Agreed.. if this sort of electrical/electronic talk is greek to you and you don't have a drive to learn about it, you might want to stick to the pingbattery. It offers that 'plug it in and forget about it' kind of functionality. If you are looking for under 25aH, it will only cost you a bit more than a full on LiPo setup and the convenience advantage will be worth it.
but make sure you buy a pack that is suited to the watt rating of your motor / controller combination!!!
neptronix
Postby TopCat » Sun Dec 05, 2010 8:32 am
neptronix :oops: Those are EXACTLY the connectors i was referring to, but i called them ec4.. thanks for correcting me for the sake of the OP.
Yes I had seen these type of connectors while searching but as Neptronix called them EC4's I thought he ment something different!
neptronix
Anyway its all sorted now. Nep made a little mistake in the name, no problem. We all make mistakes thats why they put rubbers/erasers on the end of pencils :)
If you have read all the info on lipo in the battery section and are still struggling to come to terms with basics, it worries me a little you buying lithium polymer..........
KiM
Being a noob to all this electrical jargon, I have to start learning at some point. Im more of a hands on/practical person, its when I see stuff like this...
....How about a 20C rating on a 2000 mAh battery? 20 x 2000 = 40,000 milliamps or 40 amps. Time wise, a 40 amp draw on this pack would exhaust it in about 3 minutes (2000/60= 33.3 mA minutes multiplied by 20c = 666 mA per minute - divided into the packs capacity of 2000 mA = 3 minutes). As you can see, that is a pretty short flight and unless you are drawing the maximum power for the entire flight, it is unlikely you would ever come close to those numbers.
...my head hurts. I was never any good at math.
Dont go worrying Kim, your quite safe from any fires/explosions being as your on the other side of the planet.
As HK doesn't have the charger in stock at the moment so im just going to make up a list of all the stuff I need and order it up after Xmas once the postal congestion has calmed down a bit.
Plus do a lot more reading on lipos.
Regards
Tom
TopCat's Spoiler
TopCat
Postby neptronix » Sun Dec 05, 2010 2:36 pm
Yeah, the math can be confusing, especially when you don't have a full understanding of the terms mentioned in the first place. This was a big barrier for me too. There are a lot of big brains on here who are beyond our level so many times over that it it ludicrous.. but feel free to PM me if you need help setting up the charging system, etc.
neptronix
Postby dogman » Mon Dec 06, 2010 7:12 am
Jester is right that for noobs, a ping can be much easier to deal with. But as always, it depends on many things.
I see a scooter motor, is this for a scooter? If so, a ping might be a bit bulky and hard to mount compared to the size and shape of the lipos. But if you are running that motor on a 15 amp controller, a 10 ah ping might fit. If this is going on a bike, and you will use a larger controller, you need a larger ping, or you need a battery with a higher discharge rate capability like the lipo. A 36v 20 ah ping is pretty close to being as simple to use as the 3 sla's and just about the same size physically. Plug, charge, ride.
Hunt the site if you go for the HK stuff, and buy what's in stock, and affordable. 15-20c will be fine for that motor. But if higher discharge rate is on sale, fine to get that too. Just don't spend a lot more for c rate you don't need.
Keep reading in the tech reference section for the basics, like paralell vs series, volts x amps = watts etc. If it sunk into my brain, I assure you it can sink into yours. They don't get stupider than when I was a noob. For lipo, see the lipo noob thread links for the threads that helped me a lot.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby TopCat » Mon Dec 06, 2010 9:24 am
dogman wrote:I see a scooter motor, is this for a scooter?
The motor is on my chopper....
Link in my sig.
...that im doing up. As you can see theres plenty room for lipo's. I eventually plan on making a batt box like this one...
Image Image
dogman wrote:Keep reading in the tech reference section for the basics, like paralell vs series, volts x amps = watts etc. If it sunk into my brain, I assure you it can sink into yours. They don't get stupider than when I was a noob. For lipo, see the lipo noob thread links for the threads that helped me a lot.
Iv'e already been browsing your sticky - Lipo noob thread links and others, fingers crossed that some of it will eventually sink in :roll:
Today HK got some new stock in so I ordered up...
Icharger 1010b+ - I'll need to get a power supply for this.
2 meter of 12AWG - red. Black is out of stock :roll:
2 packs of HXT 4mm Gold Connectors.
I'll order up some batts - Turnigy 5000mAh 5S 25C Lipo Pack after xmas, once funds allow.
Regards
Tom
TopCat's Spoiler
TopCat
Postby dogman » Mon Dec 06, 2010 5:41 pm
Ahh, lots of room for battery, but lots of room to expand to faster stuff later if you go lipo. Nothing wrong with that.
dogman
Postby spinningmagnets » Mon Dec 06, 2010 11:12 pm
I am a LiPo noob too. The RC shop nearby said that my Turnigy 5000mAh 6S 30C battery had 8-AWG wire and 5.5mm connectors (they arrived with the tips covered with a snippet of heat-shrink for safety, extra heat-shrink removed for pic). Of course, you can cut the connectors off and solder on any connector you want:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=2087
(105.64 KiB) Downloaded 140 times
Last edited by spinningmagnets on Tue Dec 07, 2010 10:19 am, edited 1 time in total.
spinningmagnets
Postby AussieJester » Tue Dec 07, 2010 1:03 am
30c Turnigys might do...I can vouche the last lot of 20C Turnigys dont they have 10AWG
HK lists the bullets on the 25c Turnigys to be 4mm which would fit
10AWG wire would it not? I might be wrong though often am...least i'm
consistent :mrgreen:
KiM
AussieJester
Postby neptronix » Tue Dec 07, 2010 1:25 am
Those 4mm connectors do fit 10awg very well.
My 25c batteries do have 10awg on them.
My setup needs like 2c, lol.. but i buy 25c batteries because those are the high-volume ones that sometimes go on sale.
neptronix
Postby AussieJester » Tue Dec 07, 2010 1:28 am
neptronix wrote:My setup needs like 2c, lol.. but i buy 25c batteries because those are the high-volume ones that sometimes go on sale.
Not often I get above 250amp but when I do its good to know the batteries can takez it
i use the 20C myself, always cheap have a burst rate of 25c -30C IIRC which is more than needed for my whimpy setup.
KiM
AussieJester
Postby neptronix » Tue Dec 07, 2010 1:31 am
250amp?!!?
What kind of hell-beast motor-controller setup draws that kinda juice? :lol:
neptronix
Postby AussieJester » Tue Dec 07, 2010 2:03 am
neptronix wrote:250amp?!!?
Castle Controller HV160 on high settings when hooked to Turnigy 80-100 130kv or Astro 3220 motors.
KiM
AussieJester
Postby neptronix » Tue Dec 07, 2010 2:46 am
damn....
how fast can you go?
neptronix
Postby AussieJester » Tue Dec 07, 2010 3:32 am
neptronix wrote:damn....
Depends on the chain rings/sprockets i run :wink: one of the advantages imo of a non hub drive is being able to change gear ratios at the drop of a hat to suit your needs ;-) Currently i have it geared low to tackle the hilly terrain where i live whilst towing my wheelchair behind the bike and thus have it gear limited at ~60km/hr acceleration is outstanding :mrgreen: ...would be well capable of 75-85km/hr maybe more i think if geared for it..(i cant realistically go above 45km/hr with wheelchair in tow as it starts bouncing around and flips on its side, rather scary the first time it happened) I thinkz we should getz back on topic before this thread gets totally derailed /OT discussion my end apologies OP ;-)
KiM
AussieJester
Postby spinningmagnets » Tue Dec 07, 2010 10:31 am
Kim, just read what you posted about 4mm bullet-connectors, so I had a quick look. I didn't know what connectors came with the battery I ordered because at the time, the info posted was thin. I notice now that "some" of the listings have more information, so I guess "Sum Yung Guy" is typing as fast as he can to update the web-catalogue.
If you are only going to run a single brick of LiPo, get the 30C, but if you will parallel several bricks to get better range, I recommend to get all 25C packs, 10/12AWG wire, 4mm bullets...
edit: heres an alternate wire supplier based in the US that was posted recently:
http://www.rcdude.com/servlet/the-1511/10-AWG-Silicone-wire/Detail
I was interested in the 6S 5000mAh packs, and they now actually do list the 25C pack connectors as 4mm, and they also do verify the 30C connectors AND the 5800 size pack connectors are 5.5mm
(5800/25C = 5.5mm, 5000/30C = 5.5mm,...5000/25C or smaller = 4mm)
edit: if you are ordering these connectors from Hobby King, might as well throw in some Heat-Shrink-Insulation (HSI). The comments section seems to indicate that 6mm HSI (available in black/red) works well to cover the 4mm female bullets.
http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?catname=Shrink+Tube&idCategory=375&ParentCat=58
Last edited by spinningmagnets on Wed Dec 08, 2010 5:51 pm, edited 1 time in total.
spinningmagnets
Postby TopCat » Tue Dec 07, 2010 8:52 pm
Hi Guys,
Been looking into a power supply for the Icharger1010b+ and am wondering would any of these be suitable?
Propeak Power Supply 240>13.8v 20A Auto
The ProPeak 13.8v power supply is a high quality switch mode power supply with a particularly smooth output current, making it suitable for use with almost all 12v input chargers available today. Using switch mode technology gives greater efficiency and reduces the weight and size of the power supply compared to older units. The maximum 20 Amp output allows fast charging of even high voltage battery packs.
Technical Data:
• Input voltage range: 190~240v AC
• Output voltage: 13.8v DC regulated
• Current rating: 0~20 Amps
• Output connections: 4mm Banana/Clamp type.
Fusion 200W Adjustable Power Supply.
The PS200 Adjustable is a regulated 5~15V power supply with current limiting from 0~15A. With an LCD readout showing the voltage and current being supplied, it can also be used to charge Lead Acid batteries.
Features
* Input Voltage: 220~240V AC
* Output Voltage: 5~15V DC Regulated
* Current Rating: 0~15 Amps
* Output Connections: 4mm Banana Sockets / Clamps.
Regards
Tom
TopCat's Spoiler
TopCat
Postby AussieJester » Tue Dec 07, 2010 9:23 pm
Got links to website for these please i might be interested in one of these myself, to use
for my anodizing psu!!!
KiM
AussieJester
Postby TopCat » Tue Dec 07, 2010 10:06 pm
Here ya go kim,
http://www2.ripmax.net/item.asp?itemid=O-IP2000&Category=070
Fusion also do a twin Power Supply.
http://www.cmfhobbies.com/Chargers-and-Power-Supplies/Power-Supply/C46-41-1-0.htm
Iv'e also seen a few on ebay.
Here's another...
The new ProPeak dual output 13.8v power supply is a high quality switch mode power supply with a particularly smooth output current, making it suitable for use with almost all 12v input chargers available today. The dual outputs allow easy connection of two chargers, to take advantage of the exceptionally high maximum current of 20 Amps, and the LCD readout gives at a glance an exact reading of the current being supplied by the power supply.
Technical Data:
• Output connections: Twin 4mm Banana/Clamp type
• LCD Amperage readout
http://www.rcmodelcentre.co.uk/Power-Supply-20A-13-8V-Twin-Output/prod_6088.html
Regards
Tom
TopCat's Spoiler
TopCat
Postby AussieJester » Tue Dec 07, 2010 10:46 pm
Cheers bookmarked ...GGoodrum has just done a review on the new Hyperion 1420i chargers, much better than the Icharger your buying IMO and he is doing a 25 dollar discount for ES members on them on his website tppacks.com so $US180-25 bucks= $155 If you want to charge your lipos fast and safely he has a full easy to follow write up on it
in this section of the forum. viewtopic.php?f=14&t=23362 I will be using this exact setup on my new bike... Meanwels are ~50 bucks off ebay new to power the Hyperion, you want safe and fast bulk Lipo charging/balancing theres your answer..
KiM
AussieJester
Postby TopCat » Tue Dec 07, 2010 11:48 pm
Sadly Iv'e already ordered/bought the Icharger101b+ from HK :roll: so i'll make do with that for the time being. Further funds are now going into a power supply - batteries more wire and anything else i'll need to keep an eye on my batts while I ride.
I still have a lot I could be getting on with but with 2ft of snow covering everything in my area...well :(
Any news on your missing seat Kim?
Regards
Tom
TopCat's Spoiler
TopCat
Next
Return to Battery Technology
Who is online
Users browsing this forum: No registered users and 7 guests
