999zip999 wrote:Wesnewell there's 33 pages and when is the last time you heard from Gary.
wesnewell wrote:Yes, that's too low for a 12s pack. It should be a minimum of 42V and that's lower than you should take it.
Oops, it's saying your input voltage is too low to charge at the rate you want to charge at. Either get a bigger power supply or drop charge amps rate lower.
fractal wrote:so i tried charging at 12s. everything is plugged in perfectly but i get a battery connection error. the input voltage is 13 volts. is it possible that its too low for 12s. the manual dosent say shit!!!! (tried charging eac 6s packs separately and it works)
Sacman wrote:fractal wrote:so i tried charging at 12s. everything is plugged in perfectly but i get a battery connection error. the input voltage is 13 volts. is it possible that its too low for 12s. the manual dosent say shit!!!! (tried charging eac 6s packs separately and it works)
The "battery connection error" doesn't come up if your power supply is too small. If it charges your 6s packs fine it should charge your 12s packs too but just at half the amps. Remember these 1420i chargers were made for use largely by the RC guys who power their chargers with their 12v car batteries while they are out in the field flying their RC planes and helicopters.
I think something is still wrong with your connections when you series charge your two 6s packs. Can you take a pic and post it up?
The easiest way I can tell people to make the connections correct is to make sure pin #1 on port A (black wire) is connected to the same battery pack that also connects to the thick black (-) charge lead.
999zip999 wrote:I fill better with Sacman holding my hand. Thanks. Sucess 12s A123 20ah is charged on the hyperion. One more to go.
mistercrash wrote:....
When I stopped the charge today, the one cell showed 4.03V while all others were at 4.14/4.15V. I checked the voltage of that low cell with a Fluke 113 and it said 4.23V. Is my charger defective or is something wrong with that cell that makes the charger give false readings?
mistercrash wrote:When I stopped the charge today, the one cell showed 4.03V while all others were at 4.14/4.15V. I checked the voltage of that low cell with a Fluke 113 and it said 4.23V. Is my charger defective or is something wrong with that cell that makes the charger give false readings?
