safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Features and Benefits
(18650 Size)
High quality 4/3 AF size 1.2 V, 4200 mAh rechargeable Nickel Metal Hydride (Ni-MH) battery
High capacity (4200 mAh) and high discharge rate (9C-12C) for super performance
Make your own battery pack in any combination of shape and voltage with easy soldering
Ideally suitable for making mini battery pack for remote controlled (RC) aircraft.
Ultra high capacity, 40% more running time than Ni-Cd battery.
Very long cycle life and Rapid battery charge up
Ideal for building battery pack for laptop, portable DVD etc.
Battery tested based on International Electronic Commission (IEC) standard to ensure capacity, quality and life time.
6 months warranty.
Technical Specifications
Dimension: Height 65 mm, Diameter 18 mm
Weight: 2.2 Oz. or 62.4g
Capacity: 4200 mAh
Voltage: 1.2V
Standard Charge: 15 hours @ 100 mA
Rapid Charge: 1.2 hours @ 1000 mA
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=1036
Quantity Discounted Price
1-5 $4.53 (Per Item)
5-20 $4.23 (Per Item)
21-50 $3.93 (Per Item)
51-100 $3.63 (Per Item)
101-500 $3.53 (Per Item)
I think that Tenergy doesn't want to give up and allow LiFePO4 to take over.
This is good for us... brutal competition is a good thing for consumers!
