auraslip
- Joined
- Mar 5, 2010
- Messages
- 3,535
Ping said this bms is bad and he'll send me a new one..... do you think I can fix it?
This light stays on -
After I fully charge the bms it 58v coming from the BMS.....and then I plugged it in to the controller. It immediately drops down to 7v. When I disconnect it from the controller it goes to 42v.... plug it back in and it drops down to 7v again.. unplug it and it goes back up to 42v.... Bypassing the bms and everything works fine.
All cells measure fine....except cell 1.... when measuring from ground to the first sense wire (cell 1) it is at 3.3 compared to 3.6...... weirdness.
