SamTexas said:
Ypedal said:
dogman said:
Stubbornly determined to use a crappy battery eh?
+1 !
Don't even bother to waste your time with those..
- nimh is too fragile, considering available options in lithium
- canot parallel nimh/nicad, you need to charge individual strings..
- C rate too low.. will not cope with ebike power levels
- Assembly nightmare..
In the end I might give in and use Lithium. Lithium is superior in terms of energy density and higher discharge rate, but its weaknesses are too great to ignore:
- disastrous consequence when overcharged
- total loss when overdischarged
Nickel based batteries don't share those characteristics.
The order of powerful battery explosions in my experience has been as follows:
#1. Lead Acid. By a huge margin. Datacenter battery rooms have exploded entire facilities to rubble just from a ventilation fan control error. The best couple battery explosions on this board have also been lead-acid batts.
#2. NiMH. The cans dont normally have vents (and often it seems the types with vents (which by design have to be VERY high pressure) don't function anyways). Anytime something causes them to off-gas (over-charge etc), they explode like mini-gernades. Shrapnel, cans shot like shotgun slugs into walls and things, total mechanical destruction of things around them.
#3. Lithium round cells. Lithium cans must have vents by design, but like NiMH, vents in cans are a sketchy thing as best. Overcharge causes electrolysis in the electrolyte, it off-gasses, builds pressure, and vents with a BANG that can rival NiMH.
#4. Lithium Polymer. Virtually impossible to explode, however, it can vent a gnarly fireball out of the pouch that can encompass and burn objects near it. The fire only lasts for about 5 seconds, but it's powerful enough to melt, burn, damage, or catch on fire flammable objects near them. It would be tough to be life threatening (because it happens rather slowly and you get a big hiss of white smoke as warning to get away), but if you couldn't get away from them and you had enough of them, you could burn to death (like in a car with a giant LiPo pack).
