steveo
Hi
So i've recently purchased a set of a123 cells; and gotten a free used pack. I've in the middest of testing the cells on the road managed to drop 2 cells per pack below 2.5v; i think it was something to do with my original setup; i had 2 packs in parrell 36v/4.8hr. I was using 1 bms & spliced all the balance leads to accomidate charging 2 36v packs at the same time; While riding not even 1 amp hour on my c/a i managed to bring 2 cells per pack below the 2.5v mark damaging the cell, the cells still functional but now only charge to 3.34v mark. I was bypassing the bms & obtaining the current directly from the cells. The cells i managed to drop below the 2.5 mark where the 2 cells on each pack used for both + & - lead. i've managed to rebuild one of the packs & put all near matching cells that fully charged showing 3.42 v, the other pack thats in pieces have cells with voltages all over the place; some 3.6 some at 3.34 fresh of the charger. I'm really upset that i've managed to mess of the packs.
Could you please advise how i can match the cells to try & rebuild the second pack. i've read
Match by internal resistance ? what do i use thou ohms, kohms mega ohms?
voltage - i don't agree with this part; even thou some cells after charge are at 3.6v & another at 3.34v once on load they all start to drop around 3.35 - 3.30v on a stead load with 3 100 v bulbs.
capacity- How could i measure this? what tools would i need?.
any info or fyi you could give would be much appriciated
please advise
thanks In advance
please advise
thanks In advance
