Zenid wrote:
Now I've put the extra main MOSFET on, should I be okay with a 15A or 20A charger? I built it solidly with nice thick gauge wire everywhere. Are there any issues I should be aware of before I try it with anything more powerful (apart, of course, from making sure the EOC is stable and works okay now)?
Gregb wrote:Still not terribly impressed with the instructions. In the Charge Control section Test It says use a current limited PS set to 100mA but no mention of initial voltage. It then says turn voltage up to 20V... From what ???.
Gregb wrote:when you charge money for things, you have to keep it up to date
Gregb wrote:"also will the failsafe mode eliminate the effect that seems to occur on the negative end of the pack where the end 4 cells seem to be slightly lower than the rest?"
Could you elaborate on this? Do they measure a lower voltage? and by how much ? and does this effect come in after standing for a while or are they cutting off early ?
None of mine are exactly the same particularly after an hour or so. and are you leaving something like the cell log across them ? It does consume power
Users browsing this forum: etriker, Google [Bot], GPM, Icewrench, JennyB, Sancho's Horse, triggeraa and 11 guests
