"Zephyr" - Finally, the "v4" Fechter/Goodrum/Hecker BMS...
Re: "Zephyr" - Finally, the "v4" Fechter/Goodrum/Hecker BMS.
Postby fechter » Mon Mar 19, 2012 10:27 pm
SamTexas wrote:I'm sorry to hear that. I hope things will work out for both of you. I assume that this is mainly caused by the general declining home value in California, right?
Well, in my case, it's mainly due to having 3 kids in college at the same time combined with a very high cost of living in my area (Marin county, CA). If I survive working 3 jobs, I can probably get the kids through college.
fechter
Postby 999zip999 » Mon Mar 19, 2012 10:28 pm
What you pay for gas in texas ? Bay area is the most expense for everything.
999zip999
Postby SamTexas » Mon Mar 19, 2012 10:54 pm
I understand what you're going through. My two kids just finished college, one in May 2011 and one in December 2011. Hang in there, things can only get better.
SamTexas
Postby Alan B » Mon Mar 19, 2012 11:12 pm
Then they move back home and still need support. :(
Alan B
1.21 GW
1.21 GW
Postby Tom_D » Sun Mar 25, 2012 2:16 pm
fechter wrote:" both of our wives have prohibited us from working on the project anymore after wasting so much time and money with little hope of recovering it."
350 + pages on this BMS topic, then ANOTHER 350+ pages on the same topic, then ANOTHER 40+ pages of "Finally" pages,
enough already ?
here's where to order:
http://www.tppacks.com/products.asp?cat=26
enough already ?
Bike: wally world 26" Roadmaster mtn
Trailer: Bob
Motor: front Clyte 5305
Controller: LYEN 124115 HV
Charger: Soneil 4808 SRF (onboard), parallel charging (4) 48V blocks, NO BMS
Batt: 84s2p Toyota Prius Gen III
Dashboard: Cycle Analyst
Tom_D
1 W
1 W
Postby Gregb » Sun Mar 25, 2012 7:48 pm
Nobody is forcing you to read them.............do you have a compulsion???????? :wink:
Gregb
Postby gge5 » Mon Apr 02, 2012 5:07 pm
Tom_D wrote:here's where to order:
I was just going to place my order, but the TP Packs website is selling old printers, software, and movies from the mid 1990's?
gge5
1 W
1 W
Postby ohzee » Mon Apr 02, 2012 7:46 pm
Yea from what I can tell this venture is not atm cost worthy and the guys are doing their real jobs.
Web page has not worked for some time.
ohzee
Postby iconoclast » Tue Apr 03, 2012 1:39 pm
@Fechter/Goodrum:
Are any of the latest Zephyr boards still available? If not, how much would it take to make a small production run worthwhile?
I understand they would be unsupported.
Electric Car Insider - http://www.electric-car-insider.com/
iconoclast
Postby fechter » Thu Apr 05, 2012 8:34 am
I hope to get a run of boards done at some point. I need to revise and check the most recent version very carefully before submitting a run, as mistakes are too costly. Once the layout is 'validated' with a successful test, a larger batch could be done. Right now, time availability is more of a limiting factor than money.
fechter
Postby IBScootn » Fri Apr 06, 2012 7:13 am
Maybe the thread name should be edited to " Zephyr BMS - Good Idea but Boards Are Not Available". The current title tends to imply that "finally" something is available when it isn't.
Motorcycle: ZEV 6100, 77V, 40AH, 60+mph; CA, halogen head lights, and faster charger added
Cost to date: $1730, MSRP $6550 - $4120 tax credit - $1200 referrals + $500 mods
Big EV Grin. :)
IBScootn
Postby dnmun » Fri Apr 06, 2012 8:09 am
not really. the 'finally' means they have gone through several iterations of optimizing the BMS design to meet all the increased expectations they developed as they learned more and more about how to design one. i actually think their design is right up there with the very best offered in the world, just no money in it for them when they have so much other work to do.
when you are young you have lotsa time and little knowledge. when you are old you have little time and lots more knowledge.
maybe you need a facebook type BMS where you can 'friend' it in order to make it valuable to you. others appreciate what they are doing for the elegance of the design and it's effectiveness.
you can build up one of the previous iterations too. if you post up a request on 'items wanted' for an old V2 board you could build that.
dnmun
Postby chxs » Sun Apr 29, 2012 7:30 pm
i have BMS v4.4 and i get problems with ... i can't get the fet activating by itself ... if i bypass it the charge cycle is fine and the led switch from orange to red at hvc ... but if i don't bypass the fets the charger don't detect anything !but i can read the voltage at the pole of charger and all cells is shunting well ... !! what is the problems .... what i have to check ??? tank you very much !!
chxs
1 W
1 W
Postby fechter » Sun Apr 29, 2012 11:52 pm
chxs wrote:i have BMS v4.4 and i get problems with ... i can't get the fet activating by itself ... if i bypass it the charge cycle is fine and the led switch from orange to red at hvc ... but if i don't bypass the fets the charger don't detect anything !but i can read the voltage at the pole of charger and all cells is shunting well ... !! what is the problems .... what i have to check ??? tank you very much !!
You can PM me. You would need to measure some points on the board to figure out what might be going on. I assume by 'bypass' you mean install the EOC disable jumper.
If the charge current is too low, it won't stay on. What is your charge current? Also, you could try turning VR1 all the way down and see if that works.
fechter
Postby TheWizard » Sun May 20, 2012 3:05 am
fechter wrote:I hope to get a run of boards done at some point. I need to revise and check the most recent version very carefully before submitting a run, as mistakes are too costly. Once the layout is 'validated' with a successful test, a larger batch could be done. Right now, time availability is more of a limiting factor than money.
I found this little blurb today about using an inkjet printer to lay masks directly to copperclad board so you can etch your own prototype PCBs
http://www.instructables.com/id/Convert ... /?ALLSTEPS
the v4.5 BMS has a hell load of through-hole drillings that one would have to knock-out, but I still think a DIY PCB beats the cost and wait of a PCB service.
And you could make the pads extra wide on the prototype in case you need to add/cut/reroute things, so it can be like a breadboard.
some drilling and etching tips are here
http://www.mentby.com/Group/piclist/ee- ... board.html
I'm thinking the cost of retrofitting a salvaged printer is about the same or less than ordering a prototype batch of _anything_, and it gives the ability to make lots of validation boards. I have a bunch of little projects I want to make where high-power/frequency rules out breadboards and wirewrap so I'm going to try and build a printer.
I've seen the layout thats been posted of the v4.5 BMS but not the parts list. smaller shunts and resistor arrays are the major changes, right?
TheWizard
Postby fechter » Sun May 20, 2012 11:51 am
To make DIY boards like that, it would probably be much easier to use surface mount parts as much as possible to minimize the number of holes needed. Drilling tiny holes by hand would be pretty challenging.
fechter
Postby thedarlington » Thu Jul 12, 2012 5:37 am
well drillings nothing compared to soldering well all those tiny bits, what if we messaged some of those open source nano pc(smoke pack size) guys who does the boards for them? they already sell a $25 700mhz mini pc -raspberri and theres plans for a $15 1ghz one soon -rhombus, thats with CPU, RAM, and plug sockets usb, hdmi phones etc, i bet they wouldn't mind helping us out atleast with tips or maybe take us under the wing to get some prices from whoever makes their stuff, after nano scale mobos im sure these boards are cake
by the way, are you guys still integrating off the shelf stuff like Cell Logs? i found a nicer $10 copy that comes with a large external alarm module probably makes for a nicer trigger,
also an already boosted Battery Medic (like garys old one?) $12 50w & $17 150w, using a light bulb & circuit to bleed-balance, these 2 are pretty much 80% of the the brains & triggers aka the complex bug prone stuff, maybe they could even make for a lite BMS? good enough for now with a more plug and play approach vs extra soldering
http://www.ebay.com/itm/3-in-1-li-polym ... 836wt_1198
http://www.ebay.com/itm/BVM-8s-1-8-cell ... 1e6ed2992f
thedarlington
Postby andrew.box » Wed Sep 26, 2012 2:18 pm
Found this thread and project way later than I should have, looks awesome. I could use one of these, the main drawback of DIY lipo packs is still battery management. I understand the predicament you're in - to finish development to the point of a polished product that can be sold at a profit, or even break-even, at a reasonable number of units, is tough if not impossible given the niche market of DIY electric bikes and small electric vehicles.
In the meantime, are there any plans to make up and sell some bare boards with a parts list and basic instructions for assembly/testing that people could populate and assemble at their own pace? Seems like the margin per unit could be MUCH higher, since labor would be significantly reduced. Maybe a good stop-gap way to recover some costs before proceeding with more development?
I agree that a plug-and-play solution in a nice, pretty case would be sweet, but I for one wouldn't' mind taking care of the connectors, case and details on my own if I had a good quality PCB generated from a well thought out circuit like this.
I'll be subscribing to the thread, this is neat stuff.
andrew.box
Postby Tommy L » Sun Sep 30, 2012 11:08 am
Nice work here!
Subscribed!
Tommy L sends.... \\m//
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
viewtopic.php?f=4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
Tommy L
Postby mj2412 » Sat Nov 03, 2012 4:28 pm
Hello, i'm still trying to solder this BMS. Beause of bad experience i have little concerns about connecting the cell cables one by one to the battery. Is it possible to add a small fuse into the cell cables? I'm thinking about a small fuse to solder into the cables.
What kind of fuse could be used for this?
Thanks, Martin
mj2412
Postby fechter » Sun Nov 04, 2012 12:51 am
Yes, I've used small 2A pico fuses that have legs on them. Another approach is to attach one wire at a time through a 6v or 12v light bulb. If the bulb does not glow, then connect directly and go to the next cell until they're all hooked up. If the bulb lights up, something is wrong.
fechter
Postby alternety » Sun Nov 04, 2012 1:50 am
I am just curious. I have followed this topic through I think two different threads, and found it very interesting and potentially useful. I have a battery powered tool using a 36V NiCad pack. I was looking at making a Lithium replacement in the long term using this device. As it turned out, the battery pack failed after something less that 10 charge/recharge cycles. So I am back at looking at this solution.
My question (as in just curious) is has anyone looked at doing this with microprocessors rather than assorted analog solutions. Microcode is much easier to update than an analog implementation. I would think a digital solution would have less probability of circuit layout changes and could reduce power dissipation in some areas by using switching power regulation. Just a thought. It could possibly reduce component count and make it easier to tune performance. A simple microprocessor may cost less that a power resistor. It would also allow a diagnostic code display vs lots of LEDs. With an LCD display, much more operational information could be available.
alternety
100 µW
100 µW
Postby heathyoung » Sun Nov 04, 2012 6:48 pm
Yeah, there are microcontroller solutions out there, have a look for peter perkins BMS. The biggest problem with micros is noise, lockups and power consumption.
The Cell-Log was used as a BMS for a while by GGoodrum/Fletcher IIRC (I have the board images here somewhere).
Its not a bad idea, the problem is though the unbalanced consumption between the pins. This is solvable, I've done it with external modification, rather than modifying the internals of the unit (yuk). Everyone complains about the cell-log unbalancing their cells if used permanently - the answer - rail to rail opamps set up as voltage followers (ie unity gain). But I digress.
I did like the original design, use it for LVC, delta V and HVC (with a simple shunt reg) - it appeals to the geek factor, plus you can have an indicator of your cells health all the time.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby megacycle » Mon Nov 05, 2012 4:21 am
Unlike an ebike, were generally guys want to maximize charge on larger packs, i was lead to believe power tool lithium packs often dont have much in the bms, basic, so you can fast bulk charge and terminate below the max recommended voltages, so practically they are slightly undercharged.
Please correct me if Im wrong.
Iron Horse SGS Pro DH.
72V 16AH lipo. 3kW charging system.
Modded Crystalyte 72V/50A, regen, 3 stage overcurrent.
4060 ☆/\, 20mm cover holes.
Hyena supplied motor (much appreciated Onya mate)
5404 next build giant strata, A123 20Ah, 72/large.
megacycle
Postby circuit » Mon Nov 05, 2012 6:09 am
if you don't mind large connector on the battery pack, it can contain only an LVC circuit (for each cell). The balancing and OVC should be in the charger then.
If large connector with many contacts is not a solution, then a proper BMS must be integrated in the battery pack, doing LVC, OVC and balancing.
Anyway, some sort of 'advanced' electronics is needed in the pack.
Visit my blog, check out personal projects: ebike v2 | e-scooter | ebike v3
Also visit company's website for a High-end BMS.
Notice: whatever I say here on forums is my own opinion and may not represent my company's position. However, no commercial use of my post content is allowed.
circuit
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: Bing [Bot] and 11 guests
