Portable lightweight 360W LiFePO4 battery charger
Postby avandalen » Sun Apr 10, 2011 5:09 pm
Because I want to fast recharge the LiFePO batteries during a trip, I need a lightweight mobile charger. Special lightweight battery chargers for ebikes don't exist. So I made one myself. I used the battery charger E-400 from BMSbattery in China. I have done modifications to the housing and the electronics.
See my website here:
http://www.avdweb.nl/solar-bike/electronics/portable-lightweight-lifepo4-ebike-battery-charger-800g.html
This is the original E-400 battery charger from 1400g:
This is the new lightweight battery charger from 815g:
Advantages of the battery charger
    The weight, inclusive mains cable, is reduced from 1400g to 815g.
    The charge current is adjustable from 1A to 8A instead of a fixed charge current of 8A.
    Integrated anti spark circuit (coming soon…)
Further weight reducement
In the feature I will reduce the weight to 500g (see website). Who can tell me if my weight reducement assumptions are correct?
avandalen
Re: Portable lightweight 360W LiFePO4 battery charger
Postby Icewrench » Sun Apr 10, 2011 9:14 pm
Nice project. I really like the current adjusting feature.
Icewrench
Postby Holocene » Tue Apr 12, 2011 4:21 pm
Very nice work, excellent design goals. A couple of questions:
1. Will this charge work with North American 110V 60Hz AC;
2. Will the voltage be adjustable for SLA, LiFe, and LiPo chemistry?
Cheers!
2000 ZAP DX electric bike kit on chromoly MTB - retired
2007 Strong GTS-210 electric bike - melted solder in hub
2007 Giant Revive, Crystalyte 405 20" fr, 35A/72V + Cycle-analyst 2.1
Holocene
Postby avandalen » Mon Apr 18, 2011 4:15 am
Holocene wrote:Very nice work, excellent design goals. A couple of questions:
Cheers!
Hi
The AC Input Voltage is 90Volts~132Volts or 200Volts~264Volts.
Order the E400 charger with the right voltage.
You can adjust any output voltage you need!
So you can use LiFePO4 / Lithium Ion / Lead Acid etc.
Albert
avandalen
Postby Kepler » Sun May 15, 2011 10:00 pm
I have the 900W version that am going to use for a 30S Lipo bulk charging. I got the 120V version but would like to be able to trim the voltage to better suit. 125V would be preferred. Also like to be able to bulk charge 24S so a voltage of close to 100V would be great also.
There are 7 pots in this charger. Any clue on how I would identify the voltage adjust?
Current Rides
Carbon Super Commuter: ON ROAD http://endless-sphere.com/forums/viewtopic.php?f=6&t=47139
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
75 Volt 2.5 kW Stealth Fighter: OFF ROAD http://www.stealthelectricbikes.com/
Kepler
Postby Alan B » Sun May 15, 2011 10:15 pm
Nice work. I've been looking at that charger. May have to get one and hack it.
Alan B
1.21 GW
1.21 GW
Postby avandalen » Mon May 16, 2011 9:54 am
Kepler wrote:I have the 900W version that am going to use for a 30S Lipo bulk charging. I got the 120V version but would like to be able to trim the voltage to better suit. 125V would be preferred. Also like to be able to bulk charge 24S so a voltage of close to 100V would be great also.
It is a complete different charger. What is the manufacturer? Can you make a larger high resolution image of the whole board? Which SMPS IC is used?
The V pot should be in the Vout feedback loop to the SMPS IC.
Don’t adjust pots when you don’t know what it is.
Albert
avandalen
Postby silentflight » Mon May 16, 2011 11:29 am
Thank you so much for sharing your knowledge in such a clear manner. Your website is also fantastic.
Considering that some recently designed power adapters (for example Apple ipod and Macbook) are so small and light, I imagine we could have small, lightweight, powerful and robust chargers if our market were big enough to justify the engineering and production. Maybe someday! Until then it's highly entertaining to follow along with people like you who are creating better solutions on their own.
silentflight
Postby Kepler » Mon May 16, 2011 5:07 pm
Albert
Thanks for the reply Albert.
I will take some High res photos of the boards. The manufacturer is http://www.emchargers.com I tried to find a schematic but no luck. I know enough about electronics to dangerous but hopefully with a bit of guidance I can identify the V pot.
I certainly wont adjust any pots until I know what they are :)
Current Rides
Kepler
Postby sn0wchyld » Wed Sep 07, 2011 4:47 am
hi albert,
Im planning on buying one of these chargers from BMSbattery, I wanted to ask if the Vout is adjustable? Im running 20s lipo now (~82V for 4.1 per cell) but im planning on switching to 24s in the near future. is it possible to adjust to ~98V output?
thanks mate
sc.
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby avandalen » Wed Sep 07, 2011 5:44 am
sn0wchyld wrote:hi albert,
thanks mate
sc.
Yes, you can adjust the voltage too. For Higher voltage, order a charger 84V3A / 84V5A etc.
avandalen
Postby adrian_sm » Wed Sep 07, 2011 5:58 am
Ooops. I made that mistake I orderd a 600w charger but got it initially set to suit my 16s LiFe pack, with the plans to adjust it when I go to a 24s LiFe pack, but it has a 63V cap @ C17 on your schematic. :( Damn.
Can I just swap this cap then make the other mods you outlined? Or am I stuffed?
Regards,
Adrian
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby avandalen » Wed Sep 07, 2011 6:10 am
adrian_sm wrote:Ooops. I made that mistake I orderd a 600w charger but got it initially set to suit my 16s LiFe pack, with the plans to adjust it when I go to a 24s LiFe pack, but it has a 63V cap @ C17 on your schematic. :( Damn.
Regards,
Adrian
I suppose that also the SMPS transformer is different, just order a new one to be sure.
avandalen
Postby adrian_sm » Wed Sep 07, 2011 6:13 am
I was afraid of that. Thanks.
adrian_sm
Postby sn0wchyld » Wed Sep 07, 2011 8:12 am
thanks mate
sc.
should I order a 98V model first and then change the Vout down to 82V, that way I know the internal components will be able to handle the 98V when I do end up switching to 24s? Or should I do it the other way around?
cheers.
My builds:
sn0wchyld
Postby avandalen » Wed Sep 07, 2011 12:46 pm
thanks mate
sc.
cheers.
Yes, don't order a charger with too low voltage, to be sure. Adjusting the voltage a lower value is always possible.
avandalen
Postby alsmith » Mon Oct 10, 2011 7:27 pm
Are VR1 & VR2 linear (or log) pots?
I'm looking at modifying one for 36V LiFePO4 and low capacity 37V LiIon, and then include for 48V LiFePO4 early next year- probably a 600W one used at 3 - 5 Amps most of the time with the possibility of faster charging if needed.
Thanks.
alsmith
Postby dnmun » Mon Oct 10, 2011 11:02 pm
@adrian "Can I just swap this cap then make the other mods you outlined?"
i assume the C17 was the output cap so you should be able to swap to 100V but you need to be sure the schottky diode that keeps the charge in the back end will handle the 24S lifepo4. usually the voltage is stamped on the surface of the schottky diode, and the current rating too. the transformer should work with the higher voltage but you need to adjust the current down to keep the power going through the transformer within the transformer spec, and even below it for continuous output. imo
dnmun
Postby adrian_sm » Tue Oct 11, 2011 12:06 am
@dnmum
Thanks a lot. I was pretty annoyed when I realised, and haven't even touched the charger since. Now I will crack it open and have a look see. Cheers.
adrian_sm
Postby adrian_sm » Tue Oct 11, 2011 7:30 am
I have the 600w model and the board is a bit different. It appears to have two caps (C17 & C18) on the output. But I need to remove the board from the case to check properly.
The shottky diode is labelled as 6A10 MIC, so should be fine. So I guess I just have to swap out the caps, and tweak the current/voltage with the POTs.
adrian_sm
Postby dnmun » Tue Oct 11, 2011 8:27 am
that black diode is a zener on the output to protect it from reverse polarity. it protects the caps on the output.
the schottky diode will be connected to the output of the transformer, usually two outside legs connected to the same trace and the middle leg going to the output, where that cap is. maybe someone else has opened this power supply too and knows.
dnmun
Postby sn0wchyld » Tue Oct 11, 2011 9:06 am
hey kepler, I just got the exact same one as you, I need to ask though, does yours have a voltage output once everything is turned on? Mine doesn't, even though the display shows 100V, which makes me worried that something is stuffed, and makes finding which wire is + and - near impossible. Im hoping its just some sort of protection circuit, though im not betting on it...
My builds:
sn0wchyld
Postby adrian_sm » Wed Oct 12, 2011 5:41 am
dnmun wrote:that black diode is a zener on the output to protect it from reverse polarity. it protects the caps on the output.
Okay thanks. Take 2. I found D15 & D16 which are heatsinked directly to the charger shell, appear to be between the transformer, and L2. They are FMG36S's.
adrian_sm
Postby dnmun » Wed Oct 12, 2011 8:49 am
looks good, did you google the specs? those diodes need to be able withstand a higher voltage than your output voltage. and a little bit more, but if they are adequate you can get away with just upping the output caps. they get hot so that's why they get heat sinked to the case. really hot.
dnmun
Next
Return to Battery Technology
Users browsing this forum: Bing [Bot], miyafumi617 and 13 guests
