No such thing as Self-Balancing 18650V (Makita)
Re: No such thing as Self-Balancing 18650V (Makita)
Postby ambroseliao » Tue May 01, 2012 1:55 pm
The ones Doc sells are definitely pre 2011. No worries.
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby 999zip999 » Tue May 01, 2012 10:40 pm
Started out 2p15s sub packs up to 21ah.. Turned over to a 10p3s sub packs for a rack to 18s. 73.7v. After a week 73.7v cells 4.088-4.072v. I ran it to cutoff 62v. at 30a on my 9c 2810 got 8.71ah, 15.68mi. 37.5wh. Then checked it at 65.62v. by time I got it apart one cell ( 10p ) 3.634v then 3.646 - 3.656v all the rest. Charged to 73.7v on a turned up Ping 48v5a charger maybe 3a. all cells 4.079v - 4.089v. 10p18s. With four 4mm bullets sets in the series line to be taken out after every thing checks out. Love them for now. Till the 25 - a123's show up.
999zip999
Postby 999zip999 » Wed May 02, 2012 11:51 pm
Con's It took alot of makita 3.0 packs to get there, lot's of zero 0's. Water damage used and even dented inside the case ?, and the Canadian mail strike ect. Plus $$. The ah is little low so far.
999zip999
Postby flathill » Thu May 03, 2012 12:15 am
John in CR wrote:Dumping the surface charge doesn't make any battery balance. They all do that. Luke explained it, and knows what he's talking about, end of story.
John
I never said burning the surface charge had anything to do with balancing! I'm saying Nasa confirmed the model that the self balacing is related to self discharge vs state of charge for hard carbon cobalt (not spinel) sony batteries, so more could be at play than luke's explaination related to redox shuttling or a loss in charge efficiency nearing full charge
It is interesting to me that other sony batteries also self balance, and I know you dont care
whatever end of story
flathill
Postby 999zip999 » Thu May 03, 2012 11:35 am
This bleeding or self discharge only happens over 4.1v. ? So my charging to 4.085v dosn't allow for this type of self balancing ?
999zip999
Postby JRP3 » Thu May 03, 2012 5:30 pm
I think IBM was marketing a redox additive for cells that would activate at 3.9V and hold a cell at that voltage while others were still charging. Seems like a good idea, don't know if it's being used in some cells or not.
Building the AMPhibian http://amp-phibian.blogspot.com/
JRP3
Postby flathill » Thu May 03, 2012 6:17 pm
Not sure about IBM but 3M offers redox shuttle additives
Here is a paper that lists sony as having a 2 types of redox shuttle additives for LiMn2O4 (konion type cells)
http://escholarship.org/uc/item/39w108nw#page-3
note enerdel was working on Anode (-) Hard Carbon / Cathode (+) Lithium Manganese Oxide
Maybe we'll be able to buy them now that the Russians bought them in bankruptcy after they made a poor investment in Think
I think konion must also have hard carbon anodes as sony was the first to delvelop the hard carbon anode way back...
If so the konion may have all three self balancing mechanisms which makes them so wonderful:
1) redox shuttle chemical balancing
2) hard carbon results in synergistic self discharge vs state of charge behavior (model confirmed by nasa, cells diverge to a state of dynamic equilibrium, equilibrium spread depends on cell SD uniformity)
2) Luke's theory that spinel anodes have a sort of inherent self balance effect due to a decrease in charge energy efficiency (I haven't read this anywhere else on paper or internet but maybe it is related to the voltage plateau vs coulombic efficiencies)
flathill
Postby JRP3 » Thu May 03, 2012 6:26 pm
Right, 3M not IBM :oops:
JRP3
Postby liveforphysics » Thu May 03, 2012 6:35 pm
flathill wrote:I never said burning the surface charge had anything to do with balancing! I'm saying Nasa confirmed the model that the self balacing is related to self discharge vs state of charge for hard carbon cobalt (not spinel) sony batteries, so more could be at play than luke's explaination related to redox shuttling or a loss in charge efficiency nearing full charge
Some mechanism causes them to bleed faster as they increase in SOC, hence decreasing efficiency (more of that energy goes into heat rather than stored charge) as they increase in SOC, and when the sit, the cells with highest SOC decrease in charge the most rapidly.
I don't fully understand the mechanism behind it, but I've observed it carefully in a number of tests and examples, and it sure is nice to have! :-)
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby 999zip999 » Thu May 03, 2012 7:22 pm
O.k. LFP When was the last time you been in the dumpser looking konion cells ? So do I need to go above 4.1v to get this self balance burn off ??
999zip999
Postby liveforphysics » Thu May 03, 2012 7:27 pm
999zip999 wrote:O.k. LFP When was the last time you been in the dumpser looking konion cells ? So do I need to go above 4.1v to get this self balance burn off ??
Yes. The higher you charge the string, the faster the high cells will bleed down. I think around 4v the entire effect is gone (which is great, because otherwise sitting on the shelf they would all be junk in a few months).
liveforphysics
Postby 999zip999 » Fri May 04, 2012 12:04 am
So after ride 73.4v GO to 68.8v 6.565ah, 44.6wh., After 40 min. in kitchen to check.
Cells 3.812-3.822v.
Charghing now.
Older Ping 48v5a. charger
Turned up to 73.3v at 3a. or Help ?
When final charge tonite let you know.
999zip999
Postby pwbset » Fri May 04, 2012 11:41 am
You really should be charging to a minimum of 74.7v if you're uber-concerned about cycle life and preserving the cells or 75.6v if you want to charge them spec at 4.2v/cell. Unless you're running the VT cells and then 73.8v is the spec charge for 18s.
pwbset
Postby pwbset » Fri May 04, 2012 11:59 am
Just saw your post above so can assume you're running V cells if you harvested from the 3ah Makitas. In 10p you should very reasonably be able to pull 11-12ah+ to a 54v LVC of 3v/cell. Every decent used V cell I've ever played with averaged 1.25-1.35ah per cell discharging at 2-3C down to 2.7-3v.
You need to up your charging voltage a bit I think. :)
pwbset
Postby 999zip999 » Sun May 06, 2012 2:01 pm
73.6v. 18s one cell ( 10p ) at 4.074v. all the rest 4.081-4.086v. Yes I will turn it up when I take it apart for balance wires. But don't want to push the old ping 48v5a charger. Every thing works. And if I keep the hvc lower isn't that better on the pack ?
999zip999
Postby parabellum » Sun May 06, 2012 7:08 pm
999zip999 wrote:And if I keep the hvc lower isn't that better on the pack ?
Sure, but being somewhere in the middle is best. Approaching HVC 4.2V is not good, approaching extreme low LVC is even worse. :)
parabellum
Previous
Return to Battery Technology
Who is online
Users browsing this forum: Bing [Bot], dnmun, steelmesh and 5 guests
