mistercrash wrote:Doc I answered your PM from today but my internet got a little funky so either it went out and you get it several times or it didn't go at all. Anyway the answer is yes 30 packs please.
Thanks
Answered
Doc
Thanks
mistercrash wrote:Does that mean I have to charge all the cells individually to 4.1V before paralleling them?
999zip999 wrote:Hey Ambroseliao you have a batery tester what I.R. did you get on your konion cell ?
mistercrash wrote:Ok thanks guys I really appreciate this but Doc, you're fine explanation puts another little doubt in my mind. You say to group the cells together with voltages that are 300 mv of each other which makes sense. 2.5 to 2.8 and 2.9 to 3.2 and so on. But in your very first post, you say to basically toss any cells below 3V. I hope I can use the cells that show a voltage of less than 3V because after opening 14 packs, I have 12 that were dead (I expected more so that's good) and 58 that are between 2.3 and 2.8 volts. So can I use these cells? My thinking is that if they show a voltage and charge up to 4.1V with no problems than they're good. But of course to know exactly if EVERY cell takes a charge and is good to go, than this brings me back to charging individually
Thanks for your patience, I'm old and presently sick with the flu so brain working at an even lower level than usual.
Electrical Conductivity
Copper alloys are known for their excellent electrical conductivity. Ratings for electrical conductivity use Alloy 101 as the standard. Note: SAE 841 is not rated.
marty wrote:
What material is that strip? Copper? What is the thickness? What is the width? Where do you buy it? Do you cut it to size? Do you cut it with snips?
If building a large battery for a electric vehicle, I know that we need to know how many Amps will be used to calculate the size of the metal strip used to connect the individual cells. Lets just figure slow electric bicycles and scooters that are mostly just dreams in my mind.
Think mcmaster.com might be expensive? They got a lot of information on copper and different alloys.Electrical Conductivity
For that i use BCAE1.com car audio website wich have many great java applet to calculate your data.
Yes i used copper. I got from surplus material at work. But i know that some house are made with copper top so try contacting some guy working in the construction domain that are specialized in house top cover.
but you can also get some on ebay as well
http://www.bcae1.com/wire.htm
to find the number of square mils you need with copper,
Doctorbass wrote:OK,
What I suggest is to make few different groups of voltage ranges. Let say you make a group for the cell from 2.5 to 2.8V, another for the cell at 2.8 to 3.1V, another group with cell of 3.1 to 3.4V etc.. up to 4.2V ( this step is not to make your pack but just for the equalization step!)
So instead of charging all cell individually, make these groups with all these range of cells voltage and than you can charge these group instead of charging each cells, that will save you a lot of time! so proceding to a charge of 5 or 6 groups is faster than charging 100 or 200 individual cells as well!![]()
After all these groups are charged to 4.1V or 4.2V, the final equalizing step would be to parallel all group cells together.
One of the best way I found to parallel cells fast if to use aluminum foil sheet and some smooth packing material. What you do if to place all cells in a sandwich with one top and one bottom layer of aluminum foil sheet. It work perfectly!
Doc
marty wrote:
Degull wrote:
Doc what do you think about bulk charging these batteries in series before creating parallel strings? I was think about purchasing some cheap 18650 battery holders and stringing them together in 16S (4 x 4 bank 18650 battery holders). They are available on fleebay for a couple bucks each. I have a 48 volt 500 watt Meanwell that is variable up to 60 volts. 16 x 3.7 is 59.2 volts, this would allow 16 batteries to charge simultaneously. Would this work or is there something I'm missing?
marty wrote:Marty got copper! Beautiful shinny metal!
Bought from a roofing supply place. 14 inch wide copper flashing. Cost is $12.91 per foot. They call it 16 once. Thickness is .0216 inch. Also called 22 Mils (a Mil is 1/1000 of an inch)
How should I clean the copper before soldering? Tried water to clean off fingerprints. Water don't work. I am thinking to clean it with water and dish soap using a green scouring pad.
Picture does not show how shinny this copper is. Told the wife that it was gold
Users browsing this forum: rasmussen and 5 guests
