JimW wrote:I think perhaps my question got lost in the shuffle..
auraslip,
Can you tell me the significance of the Red, Yellow and Green on your spreadsheet. I understand that they represent the cell voltage, but what conclusions do you draw from the voltages. Does red indicate a bad cell, or just a low voltage one? How low a voltage would you consider to indicate a bad cell? Or what kind of voltage and discharge curve would you like to see to confirm a good cell.
Sorry for all the newbee questions.
Thanks,
Jim.
auraslip wrote:I think it's a rule set up to show weak (red), not as weak (yellow), and not weak cells (green)
jana wrote:Ok, thanks for answering. I now also tested my 3 other packs and they also put out nearly the same amount of Ah from 4,1v-->3,5v. 4,17AH 188Wh
Is it a way to calculate how much of the full capacity of a battery there should be between to specific cell voltages?
Like 4,15 --> 3,6 should give 85% of max capacity? If that was understandable.
Users browsing this forum: No registered users and 9 guests
