Hi-
I wanted your help to check my diagram for the LiPo 8s2p setup.
When you look at my diagram, The bottom-left corner picture is the balancer 8S <> 2 of 4S balancer connectors wiring, I am using Turnigy hardcase 4s 5000mAh and I am using the iCharger 3010B 1000watt which capable support up to 10S. You see the LVC boards (green color) made by Geoff, I bought couple from him in past so I am recycle the lvc boards and put on new LiPo battery setup.
Is this correct the balancer wiring between 8S to 2 of 4s balancer connectors (A and B LiPo) for the proper balancing and charging the 8S.
PS. sky blue line is the balancer wiring connect to the LVC board in case if you want know.
Let me know thanks!
Let me know thanks!
