bottleworks
10 µW
- Joined
- Feb 10, 2012
- Messages
- 6
Hi,
I'm mid into rebuilding two Segway batteries. I've got one taken apart to see what cells are needed. The OEM cells are Valence Saphion 3.2V 1400 mAh IFR-18650EC. I'm going to need just under 200 cells for the rebuild. I called and talked to valence, but they won't sell the cells to anyone but Segway. It would appear I can get the exact replacement via China. That comes with risks. The alternative is buying an equivalent cell in the US. Batteryspace.com sells an apparent equivalent (http://www.batteryspace.com/lifepo418650cell32v1500mah45arate432whullistedunapproved.aspx). Is this a quality cell? Anyone here running these?
Suggestions?
Should I go with the selection from battery space ($663 total)? Is there better domestic pricing available?
Is there a supplier in China that someone here has used and recommends?
I don't want to spend close to $700 on batteries and end up with junk.
Thanks for your feedback!!
Suggestions?
