dogman wrote:Yes, people will go on and on how you can save money with lipo, yadda yadda. It's lighter. It's smaller.
It just depends on how much range you want. If you want about 20 miles range, then a 48v 15 ah ping remains a good choice.
It's very safe, you really don't hear of pingbattery fires. The only one I recall in many years was a guy who let a sharp edge in the battery box short one.
It should last. My first one took me 7000 miles, and only died because I finally made a dumb mistake.
48v 15 ah is small enough to fit in many bikes frame triangle, or if not, carries pretty good on rear racks. 15-16 pounds
It will run a "typical kit" just fine. A 20 amp controller will not harm one.
What kit to buy? Well, there are cheaper options for sure. But on a firt bike customer service might be more important that cheapest. E-BikeKit has a very complete kit, very well thought out, and very good CS. You'll be dealing with a USA company, shipping from the USA. I like the direct drive motors. If you put 48v on one, you get real world 1200 watts. It's a motor that is a clone, or at least very very similar to a 9 continent motor. Generally rear motor is best, but front is fine for street use, particularly on a beach cruiser or other non suspension bike.
Ypedal wrote:Going lipo requires you factor in the cost of an RC charger, Power supply, Ballancers or various gizmos for voltage monitoring.. time and effort in making your own pack and wire harness.. learning the ropes and all that jazz...
There are ways around the complexities but the end user has to.. i repeaat.. HAS to learn about the specifics.. some people do not, and are not willing, or able to do this. for those people a Ping makes perfect sense.
staft wrote:What are the best choices for a beginning LiPo kit, as regards charger, power supply, balancers, etc.? I am not too intimidated to consider going this route, but there is clearly much more to learn. I will now go research pack construction, but what would you all recommend for # of cells to power a 36V/48V DD motor, and what kind of controller would then be necessary?
wesnewell wrote:staft wrote: So how fast do you want to charge, and hiw do you want to charge the pack? Parallel, all in series balanced, bulk?
staft wrote:wesnewell wrote:staft wrote: So how fast do you want to charge, and hiw do you want to charge the pack? Parallel, all in series balanced, bulk?
I would be open. How slow is slow charging? Is it better for the battery, like I have heard for other batteries? Would I be up all night chaperoning the charge? If so, something faster would need to happen. Or back to Lifepo4's.
choices choices choices.
Users browsing this forum: cheys03, migueralliart and 11 guests
