Signalab 12 cell BMS
Postby docnjoj » Sun Mar 18, 2012 12:14 pm
Hi-Tek bikes website states that they no longer sell BMS. Where can I get one in this country these days?
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Xiongda 2 speed motor broke so Cute 100 going on: Whoops, Cute wheel broke
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now powering my trike
new 10S4Px2 for wife's bike giving 20ah @ 40 v0lts
My wife and I ride the trikes
docnjoj
Re: Signalab 12 cell BMS
Postby dogman dan » Sun Mar 18, 2012 12:41 pm
I have no idea, in country. Battery space would have something, but not signalab I bet. Ping will sell you a bms. Just email and ask.
For those that still don't know, I work online, for E-bikekit.
See battery technology section, FAQ thread at the top of the page for battery noob info.
See the frankenbike longtail at the thread below.
viewtopic.php?f=6&t=28389&hilit=bouncing+betty
Trashrunner longtail here. viewtopic.php?f=6&t=66005
dogman dan
Postby 999zip999 » Sun Mar 18, 2012 1:40 pm
He has a high amp. 60amp 48v. I don't know about a 12s high discharge. But would like to know. The plug side is the same size just doulble the fets in lenght. I'll go look. Is this for your A123 pack ? How is that headway headguarters bms 50-100amp. ?
999zip999
Postby docnjoj » Sun Mar 18, 2012 3:51 pm
Thanks dogman amd Zip. Actually all-battery has some but they are out of stock. I guess I'll write to Ping and wait. Yes it is for the new A123 stack but I just want them for reliability not for high amp draw. The other possibility is for 10 more Voltfreaks chargers or a Hyperion charger. I do have a good power supply to power the Hyperion 14S type charger. Decisions, decisions. I guess having choices is a good thing, but I have had good success with Signalab BMS and it would make the battery plug n'play.
otherDoc
docnjoj
Postby 999zip999 » Sun Mar 18, 2012 8:33 pm
Those led,s are so pretty and they make me fill good when they all dance. I'm going 24s if it fit's. So it would be best as two 12s I think. But would like a high discharge. Or go bareback.
999zip999
Postby Lemlux » Sun Mar 18, 2012 10:32 pm
I noticed a while ago that Headway Headquarters no longer offers Signal Lab BMS's because of customer issues. You might determine what their issues were before making your replacement choice. (I think the issues might have related to higher discharge current useage.)
Lemlux
Postby 999zip999 » Sun Mar 18, 2012 10:59 pm
40amps on those is a little signalab is what I think is the problem is. ?
999zip999
Postby darkshirikens » Tue Mar 20, 2012 1:55 am
Headway headquarters stop selling the signalabs due to the high failure rates and the money spent and lost during customer support ( shipping back and forth to customer replacing dead cells the signalabs bms destroyed etc..) also they were weren't handling current that well within their specs and malfunctioning when you apply throttle to use them you get the red light of death
Schwinn Sidewinder Crystalyte 7240 controller, X5305 motor, Headway 72v 12ah 50/100 bms done !!!
Next project on way: Crystalyte Ht rear 3525
darkshirikens
Postby dogman dan » Tue Mar 20, 2012 6:42 am
Better off to not have a bms designed for lowish amps on hot rods imo.
dogman dan
Postby joe tomten » Tue Mar 20, 2012 10:07 am
joe tomten
Postby docnjoj » Tue Mar 20, 2012 12:26 pm
Unfortunately they list the 12 S BMS as "out of stock".
otherDoc
docnjoj
Postby docnjoj » Tue Mar 20, 2012 12:28 pm
dogman wrote:Better off to not have a bms designed for lowish amps on hot rods imo.
I'm about the furthest thing from a "hot rodder"! I generally ride "Myrtle the turtle" speeds.
otherDoc
docnjoj
Postby Spacey » Tue Mar 20, 2012 1:59 pm
I've had the charging FET on a 16 cell Signalab BMS start melting the solder at an 8 A charge.
I hate BMS's as it is so hit and miss if they work or not. I love the ones Cellman uses as they just work and cut off the cell before it gets to 2.0v unlike some others.
The big metal heatsink stops them from over heating as well.
http://www.custom-ebikes.com is my new Ebike company serving the Uk and Europe
Free Uk shipping over £49.99
Spacey
Postby 999zip999 » Tue Mar 20, 2012 10:17 pm
Where's the pretty led's ? Looking at cellman's High discharge. No blinky led's oh. Love those things.
999zip999
Postby auraslip » Wed Mar 21, 2012 1:45 am
headway-headquarters can get any signalab bms you need
American company. Been very nice to me every time I've contact them.
auraslip
1.21 GW
1.21 GW
Postby docnjoj » Wed Mar 21, 2012 8:08 am
auraslip wrote:headway-headquarters can get any signalab bms you need
Thanks auraslip I will look into them.
otherDoc
docnjoj
Postby docnjoj » Wed Mar 21, 2012 12:53 pm
As usual Ping comes through. He can get one to me in a week or so. I will order the BMS as soon as the Cell sale for A123 is confirmed.
otherDoc
docnjoj
Postby dnmun » Wed Mar 21, 2012 2:18 pm
yep, just do like doc did and solder the copper tab on the end where the drain tabs are soldered down. i think that just using a big wire like i did is able to soak up a lot of heat, into the wire, because the metal conducts heat so fast then just the density of the wire gives you a big heat sink without much soldering and along the edge.
dnmun
Postby docnjoj » Wed Mar 21, 2012 2:32 pm
Thanks for the tip, Dnmun. I have never in 4 Ping batteries had a Signalab BMS fail. Well, except for the one I forgot to disconnect and left the battery in storage over the winter. It drained down 4 cells and forced me to rebuild the pack. Oh, well.
otherDoc
docnjoj
Return to Battery Technology
Who is online
Users browsing this forum: jaunty, liveforphysics, Tomdb and 11 guests
