A123 AMP20M1HD-A Battery pack kit
Postby agniusm » Sun Apr 08, 2012 6:07 am
I do not sell cells and they are not included!
Configurations available:
4S, 6S, 12S, 16S, 18S, 24S, 30S. Other configurations might be available on larger quantities (20pcs)
Balancing connectors and traces capable of 6A continuous (rev2), so it could be charged through it using BC168, Hyena's balance charger etc.
The dimensions of the kits:
4S - 34x160x14mm, packaged weight 241g.
6S - 48x160x14mm
12S - 90x160x14mm, packaged weight 357g.
16S - 118x160x14mm, packaged weight 373g.
18S - 132x160x14mm
24S - 174x160x14mm, packaged weight 535g.
30S - 216x160x14mm
Pricing on the kits:
4S - Price, 70USD + shipping
6S - Price, 77USD + shipping
12S -Price, 105USD + shipping
16S -Price, 121USD + shipping
18S - Price, 138USD + shipping
24S -Price, 168USD + shipping
30S - Price, 197USD + shipping
Shipping to US is about 30USD insured, tracked
Shipping to other locations vary, please ask.
Payments PayPal
Product Design:
Product images:
Customer pack's:
Tutorials, testing:
agniusm
Re: A123 AMP20M1HD-A Battery pack kit
Postby docnjoj » Sun Apr 08, 2012 10:43 am
I think I replied to another thread but yes! Do you have price and availability yet?
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby ohzee » Sun Apr 08, 2012 10:48 am
Sign me up.
ohzee
Postby neptronix » Sun Apr 08, 2012 10:51 am
Not interested since i'm not a lifepo4 fan, however i think the idea is quite brilliant and you should go for it.. :)
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby agniusm » Sun Apr 08, 2012 10:53 am
Thanks. I dont have the price at the moment mainly because i am negotiating block price with companies. It would be not a big deal if i ordered 2000pcs but on smaller quantities the price goes up (up to 4$per block) which makes the kit totaly unatractive. After i will negotiate the price, will post it here and then its a matter of couple weeks till shipping. cheers
P.S. Moumting plates will have copper pads for blocks on the cell side (not visible on the drawing) and builder will have a possibility to solder blocks on to the board further easing buid proces.
agniusm
Postby Spacey » Sun Apr 08, 2012 2:50 pm
Interested for sure.
Spacey
Postby ambroseliao » Sun Apr 08, 2012 4:59 pm
Add me to the interested list. This would make building a pack drop dead simple.
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby agniusm » Sun Apr 08, 2012 5:51 pm
Forgot to mention (did not included in the sketch), there will be threaded brass rod going through top plate and sticking out 5mm. This will make things easy. The Builder will acquire 2 bullet connectors desired gauge but not less than 4mm (75A) and solder those strait on to the rod. After the pack is finished and top plate is on, they will be screwed in and you have easy unplugging neat terminals. Those who need beefier terminals will be able to use these:
with 4mm nut.
agniusm
Postby 999zip999 » Sun Apr 08, 2012 6:56 pm
Looks good, interested. Like to hang under my top bar ? How's your running ? And your setup ?
999zip999
Postby agniusm » Sun Apr 08, 2012 11:11 pm
999zip999
Mine is running fine so far. Its couple of days yet so early to say. Mounting options is up to you:)
If possible state configuration you need the kit for , i will run perhaps 4 kits at first and ship them to lucky once, and then everybody will get feedback from them, after there is satisfaction, i can start making larger quantities.
agniusm
Postby spkpn » Mon Apr 09, 2012 6:23 am
Id be interested in a 2p set up..
spkpn
Postby texaspyro » Mon Apr 09, 2012 6:37 am
A 4S config would also be highly useful. 4S of LiFePO is a perfect match for replacing 12V lead acid batteries.
texaspyro
Postby Timmey » Mon Apr 09, 2012 6:41 am
Nice kit, we've been doing something similar to build our 102s1p A123 pack for a Formula Student Electric race car.
Timmey
Postby docnjoj » Mon Apr 09, 2012 6:49 am
I am interested in 12S configuration please. Thanks
otherDoc
docnjoj
Postby adam78 » Mon Apr 09, 2012 4:17 pm
I would be interested in 8s and 10s config.
thx
Adam
adam78
100 µW
100 µW
Postby agniusm » Tue Apr 10, 2012 2:15 am
OK, so i can tell that standart sizes are not standart at all:) I will include 4S in the availability list, so if you need 10S you could get 6s and 4s, 8s - 4s+4s, 16s - 12s + 4s etc if that works. Remember that all that custom stuff ads to the price and i cant make infividual stuff in one peace quantities unless someone wants to pay top price. Friday going to firm to negotiate PCB prices. cheers
agniusm
Postby Frank » Tue Apr 10, 2012 6:14 am
This sounds like a good idea - have you actually built a prototype yet?
Frank
Frank
1 W
1 W
Postby agniusm » Tue Apr 10, 2012 7:03 am
Partly yes, i used similar on my e scooter, link in signature. This thou will be more advanced, easy to build with all parts included. Tidy BMS connectors etc.
agniusm
Postby agniusm » Tue Apr 10, 2012 10:34 am
Layout for different configurations. Sizes are:
4S- 34x160
6S-48x160
12S-90x160
18S-132x160
24S-174x160
30S-216x160
Same size top cover with cutout on the right side for connector.
agniusm
Postby ohzee » Tue Apr 10, 2012 10:39 am
Where do I send my money. Be happy to be a guinea pig :)
Looks great here personally id like 3 or 4 6s kits.
ohzee
Postby agniusm » Tue Apr 10, 2012 10:47 am
ohzee wrote:Where do I send my money. Be happy to be a guinea pig :)
You wont be a guinea pig!! All will be checked before shipping. Me risking big time on this :) Changing thickness of blocks to reduce weight and cost: 45x6x3
Those interested, please PM me configuration and how many units you will need, i will try to reduce my risk in buying material i need. I will list unit and shipping prices when arranged with 3rd parties.
Thank yo
agniusm
Postby cassschr1 » Tue Apr 10, 2012 10:49 am
How about one for 28 s . Thats 100v charged for the a123 packs. Will 100v caps and fets take the 30s version, I wonder.
I personally would like one for 40s also.
cassschr1
Postby Doctorbass » Tue Apr 10, 2012 10:58 am
Timmey wrote:Nice kit, we've been doing something similar to build our 102s1p A123 pack for a Formula Student Electric race car.
Interesting, is this project you talk about with teh ermax motor? http://www.diyelectriccar.com/forums/showthread.php/batterys-formula-student-racing-car-60574.html
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby agniusm » Tue Apr 10, 2012 1:32 pm
cassschr1 wrote:How about one for 28 s . Thats 100v charged for the a123 packs. Will 100v caps and fets take the 30s version, I wonder.
You will get 28s by using 24s+4s, 40s using 30s+6s+4s.
You cant possibly make a product for everyone, sorry about that.
And please, keep it on topic. Cheers
agniusm
Next
Return to Battery Technology
Who is online
Users browsing this forum: Bing [Bot] and 9 guests
