agniusm wrote:the tabs has to be roughly 8mm long from teflon insulation even 7mm should do.
Estimated price for 24S kit is 136.85USD +shipping and 1$packaging.
Cheers
You can check shipping cost here: http://www.post.lt There is english version button top right corner.
Check the conversion rates here: https://ib.swedbank.lt/private/d2d/payments/rates/currency
gensem wrote:Agniusm could you make 7s modules?
I know it sounds like an odd number but im thinking about using 28s A123 wich would end up being 100.8v (same as 24s lipo)
I would also like to know the dimension of a mounted 7s battery kit.
Thanks
These are continuous loads (see above).agniusm wrote:I was looking to calculate exactly but it is too complicated. I guess if 20x6.3mm (126mm^2) copper bar is good for 320amps, if i would use 6mm round bar, meaning A=pi r^2=28.26mm^2, i would think that it would be good for 40amps brass or 70amps copper. I might be wrong but then again i am looking more at the clamping of the cells in to the pack and Builder should decide which way to terminate the pack. It is just not viable to design something to individual needs. I need to check current draw in my setup, and i use 14AWG on terminals, BMS and controller are rated at 30A.
agniusm wrote:
Well 28S you can get combining 24S kit with 4S kit. At the moment i am stuck with block fabricators. No one seems to want to make them. A full headache..
deVries wrote:These are continuous loads (see above).agniusm wrote:I was looking to calculate exactly but it is too complicated. I guess if 20x6.3mm (126mm^2) copper bar is good for 320amps, if i would use 6mm round bar, meaning A=pi r^2=28.26mm^2, i would think that it would be good for 40amps brass or 70amps copper. I might be wrong but then again i am looking more at the clamping of the cells in to the pack and Builder should decide which way to terminate the pack. It is just not viable to design something to individual needs. I need to check current draw in my setup, and i use 14AWG on terminals, BMS and controller are rated at 30A.
What about peak amps & for about how many seconds?Just for estimate purposes.
agniusm wrote:Here is the 6kW tester for end terminals i knocked up today. Possible testing at 45A; 90A; 135A; 180A; 225A; 270A:
agniusm wrote:deVries wrote:These are continuous loads (see above).agniusm wrote:I was looking to calculate exactly but it is too complicated. I guess if 20x6.3mm (126mm^2) copper bar is good for 320amps, if i would use 6mm round bar, meaning A=pi r^2=28.26mm^2, i would think that it would be good for 40amps brass or 70amps copper. I might be wrong but then again i am looking more at the clamping of the cells in to the pack and Builder should decide which way to terminate the pack. It is just not viable to design something to individual needs. I need to check current draw in my setup, and i use 14AWG on terminals, BMS and controller are rated at 30A.
I have made my test rig that goes in 45 increments up to 270amps, when i get rest of the stuff made i field test it with temps and timing. I see little point in theoretical estimate as in true life it could be far different.
Doctorbass wrote:What purpose are these bulbs made for ?.. 1000W at 24V seem requiring really high current and i can't find wich purpose are for 1000W at 24V.. and 45A !!
Doc
CamLight wrote:Awesome.
I'm worried about the base plate, and whatever surface the rig is placed on, overheating but testing will show if that's a problem pretty quickly. Have you tested what the initial current surge is for these bulbs? It's typically 5 to 10 times the rated current but I was curious since I've never seen these bulbs before.
docnjoj wrote:Sounds good to me!
Users browsing this forum: dm9876, Google [Bot] and 12 guests
