megacycle wrote:http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=15093&start=105
Thread were 20ah pouch gets crucified.
Sorry your right there, recommending individual insulating and an aluminum spreader at big amps sorry about that misinformation was a few hundred threads ago of reading![]()
There is a certain spot in particular they say that gets hotter, gee there's a hell of a lot to know.
ohzee wrote:Should get my kit today. Still cycling my pouches though so going to be a week before I can build.. Still look
forward to checking it out.
On my 20s compression battery I did not put anything between the cells and have had no issues.
docnjoj wrote:LFP's test and thermal imaging clearly showed the big increase in heat at the cathode tab only. The rest of the cell got a bit warm but nowheres near the cathode temp. I am considering using heat resistant oven paper (silicone coated for baking) as preventor of rubbing pouches and shorts but I don't believe running at 2C max there will be any problems irrespective of whether the cells press together or not. I do plan to use masonite with holes as my end covers and use filament tape to wrap it. Then perhaps heat shrink, if I can get it big enough to wrap the pack. Should be well protected and not terrible looking. I really do not want to make it ugly after the beauty of agniusms kit. I will aim for professional appearance, unlike my previous aluminum trikes which looked like beavers chewed the shapes.
otherDoc
docnjoj wrote:Well my kit showed up.........................for a brief moment and then the post Office took it back! I wasn't home to sign for it so I have to go get it tomorrow. Can't wait! I think that fiberboard is much easier for me to work with than 1/8 alloy, but it now comes in pretty colors too. Pretty cheap and waterproof in 1/8 in thickness and has a water resistant covering. I am still trying to locate some big enough shrinl wrap; as the batteries are too big for the stuff from ebike.ca. Someone mentioned some about 300mm around but I can't seem to find it.
otherdoc
ohzee wrote:ohzee wrote:Should get my kit today. Still cycling my pouches though so going to be a week before I can build.. Still look
Ok international shipments are a bit slower for my local post office.. TOMORROW it is.. maybe I will have all my batteries cycled by then.
Ordered me a 150amp 24S bms from ev assemble. Wanted a similar high power ping one w/lights , but 20s is the highest they have.. Also
the high power 20s one I have is still lacking in terms of amps it can put out.
megacycle wrote:ohzee wrote:ohzee wrote:Should get my kit today. Still cycling my pouches though so going to be a week before I can build.. Still look
If you don't mind how much was the bms
How are you cycling your pack eg rates.
agniusm wrote:Calculate diameter: perimeter of 6s kis is 48+48+160+160=416mm then diameter is 416/pi=132.48mm, make it 140 or 150mm and you will be fine.
There will be all bolts, blocks, spacers, connectors + pins, heat shrink wrap included.
deVries wrote:I can report the kits are smaller than how these "look" or seem to be on video or pics. So, mine came Thursday, and I did not have to sign. (Must be the package lock box.)![]()
I have two small plastic bags of hardware for each board. Will have to open & examine 16s boards in better light tomorrow, but everything looks good. Though I have a suggestion about shipping packaging...
IMPORTANT SUGGESTION FOR PARTS LOSS PREVENTION: I suggest taping the tiny plastic baggies of hardware to the inside of a much larger sized baggie (or envelope) too, so the tiny baggies can't slide around and get trapped or caught into the seams of the shipping box. The four end-seams of my (book?) box were not sealed by tape and bowed open creating an opening for the tiny parts baggies to slide into, so the tiny baggies might have been caught in those open seams and could have "leaked" & lost the hardware contents of small parts if trapped/caught cut & damaged at one of the four open end seams. It is definitely possible the tiny baggies could have been pulled out of the package or torn open at least partially & the contents lost. I suggest putting the tiny baggies inside a bigger baggie or big envelope inside the package to prevent this.There will be all bolts, blocks, spacers, connectors + pins, heat shrink wrap included.
I didn't get any shrink wrap, which was initially planned to be included in the kits? Is heat shrink available for my kit size of 16s? Is there anything else not included with the original plans for these kits???
Look forward to getting my cells to assemble the battery. This looks like a very good kit design, imo, of course, actual assembly & use will be the "true test" for a solid recommendation.
The conducting material on the circuit board is what grade aluminum or ??? Thanks for offering these kits.
agniusm wrote:I decided not to include heat shrink, page 4, fifth post from the top.
deVries wrote:agniusm wrote:I decided not to include heat shrink, page 4, fifth post from the top.
No problem.(I forgot reading that.)
The conducting material on the circuit board is what specification or grade aluminum or ???
Thanks.![]()
I know Ohzee has cells now to make his kit, so I'm looking forward to otherDoc & Ohzee for their assembly experience & tips.
Ohzee, please take video of assembly & post please!24s needs to be on video.
docnjoj wrote:Went and picked mine up and all parts are accounted for. It looks like the USPS has been taking lessons from UPS as it appears like several large angry men stomped the box. The two corners were open and I agree with DeVries that at least the outside rim of the package needs to be taped all around. It (the kit) is beautiful design and the hardware fits the threads like it is supposed to! Simply a great job,agniusm! I hope you make a fortune on these kits.As I assemble my 2 6S batteries I will take photos.
otherDoc
Users browsing this forum: alsmith, hillyterrain, keokio and 12 guests
