evb wrote:That's my battery. I use split pins to connect cells, 3mm aluminium plates to constrict it.
36v 20Ah, 260x180x92mm, 7.5kg
dnmun wrote:what is a split pin to you? is it what some would call a cotter key? or a roll pin? have close ups?
dnmun wrote:also what is the BMS you have there? pictures inside?
docnjoj wrote:Did you solder to sense wires to the cotter pins? If so what material are they made out of?
dnmun wrote:for space at the top?
pgt400 wrote:[quote="evb
I bought this BMS from Linda, Headway's manager. Headway installs it to their batteries.
I guess Paul (Cellman) sells it too. http://www.emissions-free.com/catalog/i10.html
docnjoj wrote:Here are some interesting ones made of brass.
http://www.amazon.com/1-3-Cotter-Pin-pi ... 28&sr=1-16
A lot are stainless but there are some zinc plated ones in millions of sizes. Kool!
otherDoc
potatorage wrote:How strong are these pin connections? I'd like to find a relatively easy way to hook my batteries up.
liveforphysics wrote:docnjoj wrote:Here are some interesting ones made of brass.
otherDoc
You do not want any conduction through the pin itself. For long-term function it would be best to even put a little layer of kapton where the pin sits just to avoid the chance of carrying any current through the pin itself.
The pin is there to make clamp load.
evb wrote:This connection resistance is 0.06-0.08mOm
Then folding tabs several layers and strong press by jaw vice, and fix by cotter pins with washers.
deVries wrote:Hi Evb, I watched your video. Thanks.![]()
You make good videos in English.
deVries wrote:Can you make a video that shows how you clamp the tabs and the two 3mm aluminum plates to the cotter pins too?![]()
deVries wrote:The video does not show what I quote above.![]()
no problem, I will try to explain you by picturedeVries wrote:Are you pressing in the vice only the layers of tabs?In other words, do you press the two 3mm aluminum plates and/or the cotter pin in the vise press too?
I still do not understand clearly. Thank you for your help.![]()
Users browsing this forum: Google [Bot], Punx0r and 11 guests
