A123 20AHr Pouch Cell Battery Build & Info Thread
Re: A123 20AHr Pouch Cell Battery Build & Info Thread
Postby agniusm » Wed Jun 27, 2012 10:58 pm
jonescg wrote:
agniusm wrote:Hi. I would reconsider using brass. Have you calculated resistance on brass? I did and it is less than aluminum. Second is weight, trust me it adds a ton to the pack, bad for EV use. If you going to use brass flat bar to connect cells in 3,4,5P configuration which i bet is meant for cars and bikes you will have problems regarding conductivity. I tested mine with 211amps and my blocks which are just clamping tabs get worm. Solitons and zillas go beyond 1k amps ;) Just my point of view.
The brass won't be taking any of the current - the 1.6 mm copper plate goes on top to clamp the tabs down - this is what will be taking the current. The brass is simply there to provide good tension when tightening the copper down. Brass is a pain to work with, but that's why I'll get a fabrication shop to do it for me. The other benefit of brass is that it can be soldered down onto the pads on the PCB to hold it in place. Then, traces can be run from the pads to serial sockets.
As for weight, yes, I know it gets heavy, but the brass component of my car battery will really only be adding 3 kg to the whole 25 kWh pack. The copper will be an additional 7 kg, so 10 kg all up. I don't think it will matter much on a 950 kg car.
Ok, missed that part, was looking at the image :). Copper will be best for this and 10kg is nothing for sure.
agniusm
Postby 999zip999 » Thu Jun 28, 2012 12:11 am
I order from McMaster for the Drutledge build tuesday 2pm and got it 4pm wed. Wow. Charging 6s with 4 voltfreacks 3.65v2a. Have a hyperion but love those little things for A123 and headways voltage. See how long this takes.
999zip999
Postby 999zip999 » Thu Jun 28, 2012 7:27 pm
I found 1/4 od x.170 poly tube I think for ice cube maker. Perfect even fit's thru the punch hole in the tabs ( paper punch ) one peice.
999zip999
Postby ohzee » Thu Jun 28, 2012 7:29 pm
Yea I used the same stuff for my build worked pretty good for me.
ohzee
Postby 999zip999 » Thu Jun 28, 2012 11:32 pm
My fluke 113 won't pickup the 3.32v, But my free ( coupon ) H.F. m.m. does ? ? Can't wait for those voltfreaks and hooked up the 1420 for 11a on 6s to 3.62v. An old 10in. carbide 40t on a chop saw cuts the 1/4in. alumiun bar just fine.
999zip999
Postby 999zip999 » Thu Jun 28, 2012 11:47 pm
Drill the holes in the tabs a little bigger as to free them up. Do I use the grease ? What grease ? local hardware stuff or home depot or forget it ?
999zip999
Postby docnjoj » Fri Jun 29, 2012 3:32 pm
I'm waiting for my agniusm kits to arrive but in the meantime I;'ve used my No-Ox ID-A on all my plugs and outlets outdoors and by the pool. It seems to really help conductivity since when I do a before and after with a Killowatt meter the current draw seems to be about 1 amp in 10 lower. Maybe a fluke but I will swear by this stuff and use it on my 12S battery when the kit comes. Seems like good stuff.
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby ambroseliao » Fri Jun 29, 2012 3:40 pm
I bought some Noalox in preparation for my A123 build. Has anyone else used this stuff?
http://www.idealindustries.com/prodDeta ... dId=noalox
Ambrose
http://www.ebikes.ca/ for the best in ebike knowledge and equipment.
Tidalforce S-750, TidalForce iO Cruiser, 2x TidalForce M-750. Crystalyte HS3540 sensorless, 72V 45A Crystalyte SL controller, ebikes.ca DrainBrain & Cycle Analyst meters. GoPro HD Hero2 camera. A123 20Ah batteries. 88.2V 10Ah LiPO. My blog: http://ebikerider.blogspot.com
Remember LiFEPo4 HVC is 3.65V and LVC is 2.7V
ambroseliao
Postby 999zip999 » Fri Jun 29, 2012 9:18 pm
Yes Ambro i think that's the stuff from home depot. Is there some high temp. or something ?
999zip999
Postby 999zip999 » Sat Jun 30, 2012 1:20 am
O.k. the drills don't work for the tabs even the drill point, but from dewalt little different center drill. I use a 3m paper pouch wit the two outer punches taken out, perfect. The bule plastic the drill drifted even in a dril vise with 3/32 pilot hole ? No problem. The 3/32 drill for the 4/40 is small so ream the hole with the drill or find the right drill. Put a wooden cloths clip on 6s parelle at 3.6v for balance.
999zip999
Postby josh786 » Sat Jun 30, 2012 1:57 am
Here is what I have been working on. I have to give thanks to all the people that contribute to this forum I got all my ideas from others builds. (Long time lurker) The green stuff is urethane with copper inserts. I plan on putting a tube thru the holes before I put the bolts in. There will be a wire that will exit into the middle from the series bus bar for BMS. With this I think I will have every possible configuration covered. Feed back is welcome will start making molds next week. Still having a hard time with copper vs aluminum for the bus bars.
(106.95 KiB) Downloaded 3 times
(79.73 KiB) Downloaded 3 times
josh786
10 µW
10 µW
Postby bigmoose » Sat Jun 30, 2012 6:49 am
Josh your design was so elegant, I thought the pixs should show in line.
4S2P complete 2b.jpg (28.42 KiB) Viewed 1233 times
4S2P completeb.jpg (34.04 KiB) Viewed 1233 times
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby docnjoj » Sat Jun 30, 2012 7:28 am
Hey Josh! That is an interessting and clever design. Will the urethane be cast, like the kind for making model railroad parts?
otherDoc
docnjoj
Postby josh786 » Sat Jun 30, 2012 10:16 am
The parts will be made from urethane adhesive (I build the equipment at work) we have alot of left over product. Once the molds are made the cost will be just the copper + time. I am not sure about the compression strength of the modeling urethane, the stuff we have will set hard enough to thread.
josh786
10 µW
10 µW
Postby docnjoj » Sat Jun 30, 2012 10:17 am
Thanks Josh it sounds quite solid!
otherDoc
docnjoj
Postby bigmoose » Sat Jun 30, 2012 12:53 pm
Josh, just a thought to not forget the balance wires. That may be what the hole for is on top of the conductor in your green molded piece. If not, we should figure out how to elegantly attach a balance wire.
bigmoose
Postby josh786 » Sat Jun 30, 2012 1:28 pm
Big, My though was to solder a wire to the S plates that will exit into the V on the top. I have some 6061-T6 aluminum (1/2 X 2 should be good to 700-1000amps?) that I can use to build the prototype but the wire attachment is what is holding me up. Might just drill and tap a hole and use a plated ring terminal but I am not sure about longevity there will no way to fix it later. I have no problem with using copper for the final product just that I have the aluminum and I am getting antsy. I am trying to extend the end plates down to contain the cells but it is getting very bulky. May need to rethink how the cell terminal sits so the end plate can be thinner. Ideas?
Josh
josh786
10 µW
10 µW
Postby 999zip999 » Sat Jun 30, 2012 1:51 pm
If it's 2p can you get rid of the buss between the parelle's with it being tab to tab ? Will this srcew of the spacing ? Yes alumiun is hard to think of over copper. As in houses ect. and how hot it can get ? I guess it's all about mass. To a point of to to much heat.
999zip999
Postby josh786 » Sat Jun 30, 2012 1:59 pm
Here is what I have currently. If the pic shows up inline.
(82.28 KiB) Downloaded 3 times
Mod Edit: I resized your pix. It has to be below 800 pixels in width to show up in line. (one of the boards little quirks!)
4S2P complete 3-600px.JPG (82.28 KiB) Viewed 1235 times
I added the holes for the balance wires. The lines in the top of the plates are to mark the connections. This would have plastic or steel shipping bands wrapped around to hold the cells. Maybe getting to heavy for a bike?
josh786
10 µW
10 µW
Postby josh786 » Sat Jun 30, 2012 2:43 pm
Zip, Removing the bus from the 2P makes the S plates wider, may have to think about it more. My plan was to be able to reconfigure this to any size pack by changing out the plates. What about terminals stud vs. taped hole I can see advantages to both.
Josh
josh786
10 µW
10 µW
Postby 999zip999 » Sat Jun 30, 2012 10:54 pm
I mean in a 2p pack the cells at 2p will fit togethere in one taps pressed togethere and fit in your buss bar? Only maybe. I find they fit togethere very easily as 2p. But I would like to have one in hand as to help as would you.
999zip999
Postby megacycle » Sun Jul 01, 2012 5:31 am
docnjoj wrote:I'm waiting for my agniusm kits to arrive but in the meantime I;'ve used my No-Ox ID-A on all my plugs and outlets outdoors and by the pool. It seems to really help conductivity since when I do a before and after with a Killowatt meter the current draw seems to be about 1 amp in 10 lower. Maybe a fluke but I will swear by this stuff and use it on my 12S battery when the kit comes. Seems like good stuff.
otherDoc
Been through this on agenius kit thread, viewtopic.php?f=14&t=38545&start=135
They ac outlets around the house :?:
Can anybody please proof this stuff decreases resistance to dc
Other than provide corrosion protection is it that much better than vaseline.
Iron Horse SGS Pro DH.
72V 16AH lipo. 3kW charging system.
Modded Crystalyte 72V/50A, regen, 3 stage overcurrent.
4060 ☆/\, 20mm cover holes.
Hyena supplied motor (much appreciated Onya mate)
5404 next build giant strata, A123 20Ah, 72/large.
megacycle
Postby 999zip999 » Sun Jul 01, 2012 5:48 pm
O.k. Vaseline it is. Stiil charging for days. They just look so sleepy.
999zip999
Postby megacycle » Sun Jul 01, 2012 8:51 pm
Aka snake oil
megacycle
Postby 999zip999 » Sun Jul 01, 2012 9:35 pm
When I took apart my ping I put a set of extra balance wires and if i put a bms on these packs I still will have a set of balance wires for checking and balance as probing the bms will mess up the wires and.
999zip999
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: Google [Bot], Judoka, privateidaho, serisman, stingray17, wesnewell and 3 guests
