Each packs are 5P12S for a total 5P24S when both packs are connected together.
Let me know your opinions
SlyCayer wrote:Let me know your opinions
rwaudio wrote:Nice pack, well designed and assembled.
/snip
johnrobholmes wrote:Very nice! What size copper bar did you use?
deVries wrote:What are the outside dimensions of your polycarbonate battery box?
adrian_sm wrote:then I would be a bit worried about vibration, and what sharp edges might do to your cells.
neptronix wrote:ssooo... what car is it going into?
rwaudio wrote:It will give you much better clamping over the tab surface area.
EDIT... as I look closer, the heavy cables coming off of the blocks to put the groups in series should be connected directly to the tabs and not have a nut in between and NOT have the very small ring terminal between. That tiny ring terminal + the bolt (I assume brass?) will be carrying the full current of the pack, you should rely on direct surface contact of the high current parts without anything in between.
SlyCayer wrote:deVries wrote:What are the outside dimensions of your polycarbonate battery box?
560mm X 230mm X 280mm
SlyCayer wrote:No Worries, the white plastic you see is a very very soft plastic, and it will not "Scratch" the cells, I have tested it properly before doing it, but from your suggestions, I am thinking of buying some simple foam to put all around the cells.
SlyCayer wrote:The bolts are Silicone Bronze, very close to same conductivity has Copper. The Bolts and Nuts will carry a 450A current for short period of time and from my estimation, the nut/bolt conductivity is as much as a 1/0 or 1awg Cable and it's only 1/4" thick...
adrian_sm wrote:I'm actually worried about your white plastic spacers. These spacers are *not* providing uniform pressure or support to your stacked cells. It is my opinion with the high vibration & turning forces driving a Go-Cart at high speeds that you will damage your battery unless you provide uniform pressure & support over the *entire* surface area against your "end cap" stacked cells. The white plastic spacers will do just the opposite of providing uniform pressure & support.
Use a good foam with minimal "soft" compression to act as a spacer and "compressor" between the polycarb & your entire surface of these end cap cells, that foam compressor could still be removable, otherwise I think you will damage your cells w/o that additional support over the entire surface area.
The A123 professionally manufactured modules with multiple cells *specify* that these modules provide *Uniform Pressure* against the entire cell surface area. Your module with white plastic is doing just the opposite of that specification, imo. This will likely damage your cells, imo.
Quoting from one of these A123 modules, perhaps used for the Chevy Volt, it states the module has: "• Uniform compliant compression system"
acuteaero wrote:SlyCayer wrote:The bolts are Silicone Bronze, very close to same conductivity has Copper. The Bolts and Nuts will carry a 450A current for short period of time and from my estimation, the nut/bolt conductivity is as much as a 1/0 or 1awg Cable and it's only 1/4" thick...
Again, I'm with RW-
http://www.eddy-current.com/condres.htm
Bronzes range between 48% and 7% of the conductivity of copper, the silicon bronzes listed are lower, either 12% or 7%. Might want to recalculate your equivalencies there-
Seems to me that moving the lugs to be directly adjacent to the tab stack and adding a load-spreader to the outside tab instead of having it flying, clamped just under the washer and bolt would be easy things to do to eliminate the worst weak points in the design. Depending on the resistance of these spots in the pack you may be able to determine that they need attention by running some discharge and checking it afterwards with an IR thermometer or thermal camera- or you might blow it up on the first run!
Good luck- please consider making these simple modifications- I think they will be well worth it!
SlyCayer wrote:deVries wrote:I'm actually worried about your white plastic spacers. These spacers are *not* providing uniform pressure or support to your stacked cells. It is my opinion with the high vibration & turning forces driving a Go-Cart at high speeds that you will damage your battery unless you provide uniform pressure & support over the *entire* surface area against your "end cap" stacked cells. The white plastic spacers will do just the opposite of providing uniform pressure & support.
I will be using foam for sure, what foam do you recommend?? The foams need to be have some sponger but not to much, so it's hard to gauge what foam I should use... Foam that is used in high school gyms should work?
Users browsing this forum: Google [Bot] and 6 guests
