A123 AMP20 Battery Pack Build...
Re: A123 AMP20 Battery Pack Build...
Postby texaspyro » Tue May 01, 2012 10:34 am
megacycle wrote:At least if my MJoules go ballistic hopefully i might get a few seconds for a get away before i get a vital part burnt.
Nope, Sir Edsel Murphy will wind up gobbling your dangly bits before you can say "Oh, crap!" :twisted:
texaspyro
Postby megacycle » Wed May 02, 2012 6:09 am
Yep tex who am i kidding, might as well face the truth.
I'm sitting atop of, or strapped onto a bomb, YEEEEEEEHHHHAAAAA!!!!!!!!!!!!!!!! :evil: :evil: :D :lol:
Iron Horse SGS Pro DH.
72V 16AH lipo. 3kW charging system.
Modded Crystalyte 72V/50A, regen, 3 stage overcurrent.
4060 ☆/\, 20mm cover holes.
Hyena supplied motor (much appreciated Onya mate)
5404 next build giant strata, A123 20Ah, 72/large.
megacycle
Postby miro13car » Sun May 06, 2012 8:59 pm
Since it is thread about building A123 20Ah cell pack.
It might help
If you look for tool to make holes in tabs.
I found cheap and very useful.
Bought in STAPLES office supply chain hole puncher by FISKARS brand.
It makes lovely holes in 20Ah pouch cell terminals.
miro13car
Postby megacycle » Mon May 07, 2012 2:22 am
Anyone looked at http://www.te.com/catalog/cinf/en/c/110 ... QS=C~11052.
foil terminators, could be good for tabs termiations.
megacycle
Postby SlyCayer » Mon May 07, 2012 3:01 pm
miro13car wrote:Since it is thread about building A123 20Ah cell pack.
It might help
Hmm, that's what I used...
Let me show you: http://www.amazon.com/Neiko-Power-Punch-Sheet-Metal/dp/B0002T87CW/ref=sr_1_3?ie=UTF8&qid=1336420828&sr=8-3
I built a jig using metal L brackets and wood to make sure all the holes in the cells we're all positioned exactly the same.
http://www.JCCayer.com Where you can find tools and Dewalt(A123) batteries.
SlyCayer
Postby miro13car » Mon May 07, 2012 3:30 pm
Oh maybe itis not clear FISKAR puncher is an office puncher for paper sheets for binder sheets.
I am not sure STAPLES are in USA also?
miro13car
Postby miro13car » Mon May 07, 2012 3:34 pm
SlyCayer
Your's. Is real shop metal sheet puncher.
I don't have time to wait for shipped tools,
I would rather not buy any tools without having them in my hands first.
miro13car
Postby peterperkins » Mon May 07, 2012 3:47 pm
megacycle wrote:Anyone looked at http://www.te.com/catalog/cinf/en/c/110 ... QS=C~11052.
We are looking at those on the http://www.insightcentral.net forum for our A123 builds.
We have spoken to the manufacturer about one type the 51943
Out of all the Termi Foil options listed I think it's best for the general cell interconnects as it offers the biggest surface area cover for the A123 tabs. It also has a simple 1/4" spade connection for the BMS/voltage taps.
The main power connections could be made by soldering a heavy gauge wire to the opposite end of the termi connector from the spade tab before it is crimped onto the cell tab.
It is shown as tin coated copper.
Max tab thickness is 0.76mm so you might just be able to make a 2P connection certainly 1P should be fine.
http://www.te.com/commerce/DocumentDeli ... ntxt=51943
Ideally we would like a special Termi Foil product made which covers more/entire standard A123 tab area and has more punch points and an option of a screw terminal at the ends. This is a no go they won't consider a new product even for an order of 25,000 connectors.
A group purchase of the special crimping tool may well be a good idea.
From speaking to the company they have no samples available and are searching around for some for me.
The MOQ is 2000 and delivery would be around end July.
Honda Insight MK1 lmpg 131mpg Imp
Lifepo4 40ah HiPower IMA Pack & 20ah A123 IMA Pack
BCM Fooler, BCM Interceptor, BCM Gauge, Li-Ion BMS System, OBDIIC&C, IMAC&C
http://www.150mpg.co.uk
peterperkins
Postby docnjoj » Mon May 07, 2012 3:52 pm
Those things look like they would work but getting info on them is time consuming. I checked Digikey and the 10-12 ga ones are only 1/2 inch wide (12+mm). A123 tabs are 45 mm width. Use 2 per set of tabs? They don't cost a lot but the crimping tool is over 1000 USD. I hope that you can use a block of wood and a hammer to crimp :shock: Anyone else interested? I am waiting for agniusm's kit first but these look like another solution to the tab crimping problem.
otherDoc
Edit: Hello Peter. Your post just beat mine out!
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby 999zip999 » Mon May 07, 2012 6:10 pm
Two may be the easies way to go ? I like the idea but bigger. How many amps will it take ?
999zip999
Postby SlyCayer » Mon May 07, 2012 6:30 pm
miro13car wrote:I am not sure STAPLES are in USA also?
I am from Canada...
miro13car wrote:Slyer
LoL...
miro13car wrote:I don't have time to wait for shipped tools
LoL...
peterperkins wrote:The MOQ is 2000 and delivery would be around end July.
Ouch on MOQ and Delivery time...
SlyCayer
Postby megacycle » Tue May 08, 2012 6:23 am
peterperkins wrote:We are looking at those on the http://www.insightcentral.net forum for our A123 builds.
Hi Peter, have to have a look at your insight thread, i did'nt know you guys were already onto it :D .
Would be a few options, versatile, and what you've come up with sounds great.
i was considering 2x double splice like http://www.onlinecomponents.com/te-conn ... p=10359869, balance wires would just sit in the crutch as it is crimped, trim overlaps off, solder series and parallels, they're only about $0.70 US each so beats bus for me, with battery ends i'd maybe tin and bolt thru lugs.
Are you guys going to solder down the side of the termination, that should be ok, i was thinking across the the top.
With current rating they specify similar to 10/12 AWG, I'm from metric land so this equates 5-6mm2, i would have to say each single termifoil splice would do about 40A.
Would have about the equiv to 3 splices, when one is trimmed 120A which would exceed 20AH tab normal maximum current rating anyways.
With the crimper, they specify a seperate die so its probably fits standard crimping tools. $1000 :shock: sounds like a hydraulic one, how many are you thinking of doing :mrgreen: .
I work as a sparky and the hand tool do'nt look much different to hand crimpers we use for fast on's and the like, it would obviously have a wider jaw, like the larger crimpers and probably a flat looking die.
I'll try and get more info tool or die from my wholesaler here in Oz.
Yeh that would be good to have the manafacturer do a private run,
Shame won't come to the party :( , might have to have to get those samples and a lot of metal sheet hmmm :evil:.
megacycle
Postby pgt400 » Tue May 08, 2012 3:40 pm
It might help
Whats the puncher look like? Hand held or table punch? Thx.
03' Ninja EX250, Agni #95 reinforced, 25S1P 40ah CALB Lifepo4, Mini-BMS.
05' Mongoose 20" BMX, Golden Hub Motor, 48 volts @ 9ah, A123's, Signalab BMS.
http://www.evalbum.com/1955
http://www.evalbum.com/3337
pgt400
Postby 999zip999 » Fri May 11, 2012 12:18 am
I could make a couple out of copper sheet I have found in the corner of the garage. Heavy enough to keep persure and make a jig for the hole and dimple on one side to match. Drop a metal ruler on the tabs oops. Better get that plastic back out. Yes the alumiun took it worse. Couldn't have guess. Very little damage baby corner. Lucky
999zip999
Postby rkosiorek » Fri Jun 01, 2012 11:11 am
The crimper required would not be difficult to produce as a replacement die set for standard ratcheting style crimping handles.
what is required is a swiveling head so that when it is closed it will naturally align itself flat and parallel with the opposing head. although some kind of heat treated tool steel would be best for a production tool. a basic set could be made from some hard but easy to machine steel like 12L14. those should easily last for several hundred crimps.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby megacycle » Fri Jun 01, 2012 3:34 pm
I think your talking about most standard heavy duty crimpers, which do align flat, with a cantilever rachet arrangement.
Is this what you mean :?:
This is a cabac crimper, got a similar cheap $40/50 one in my kit.
An aussie link for purchase at around A$100 new. http://www.aussietradesupplies.com.au/c ... 16mmPosted
Some info i found about tooling for this, i posted on the insight forum, as felt this was hijacking this thread some :?
http://www.insightcentral.net/forums/mo ... ll-12.html.
Sorry bud. how's the kart build coming along :?:
I think with a standard crimper, could just fill with weld a standard crimping lug die and grind to a flat,
would'nt be as hard as the die steel but for this application would it need to be ? not like we would be crimping tonnes.
http://www.futureelectronics.com/en/Tec ... ICS5513395
A couple of hundred dollars for 500 to do 250 connections, build a decent size pack with that.
Group buy 1/2 price somewhere :?: :D
megacycle
Postby SlyCayer » Fri Jun 01, 2012 8:09 pm
megacycle wrote:Sorry bud. how's the kart build coming along :?:
It has came to a halt, doing 12-14 hours days at work right now and still have a Fiance to please... I have about 10 hours left of work of fabrication on the frame and etc and then it will be burnin some rubber :D.
SlyCayer
Postby texaspyro » Fri Jun 01, 2012 11:47 pm
SlyCayer wrote:It has came to a halt, doing 12-14 hours days at work right now and still have a Fiance to please... I have about 10 hours left of work of fabrication on the frame and etc and then it will be burnin some rubber :D.
You go to work... we'll please the fiance and burn some rubber :twisted:
texaspyro
Postby rkosiorek » Sat Jun 02, 2012 2:02 am
you could use regular jaws as a start. but the swivel type anvils i was talking about would be more similar to what is on the tip of these vise grips.
rick
DISCLAIMER:
rkosiorek
Postby megacycle » Sat Jun 02, 2012 5:38 am
Was that the boss indoors, keeping an eye on things page 1 :wink: .
megacycle
Postby megacycle » Sat Jun 02, 2012 5:54 am
rkosiorek wrote:you could use regular jaws as a start. but the swivel type anvils i was talking about would be more similar to what is on the tip of these vise grips.
rick
Would'nt hurt to try, could have well enough clamping force,
obviously i was looking for specified tooling or close to it. So the crimp is similar standard.
megacycle
Postby rkosiorek » Sat Jun 02, 2012 9:41 am
I'm not sure if these will be rigid enough to guarantee a good crimp under all circumstances. but if you check out the instructions for the official tooling, they have this kind of swivel joint tip.
rick
68064.pdf
(153.26 KiB) Downloaded 33 times
DISCLAIMER:
rkosiorek
Postby SlyCayer » Sat Jun 02, 2012 11:54 am
megacycle wrote:Was that the boss indoors, keeping an eye on things page 1 :wink: .
Yep, the boss on the job :D...
SlyCayer
Postby megacycle » Sun Jun 03, 2012 5:08 am
rkosiorek wrote:I'm not sure if these will be rigid enough to guarantee a good crimp under all circumstances. but if you check out the instructions for the official tooling, they have this kind of swivel joint tip.
rick
Apologies rick was'nt considering that the cantilevering action of the hand crimper, means without self aligning faces,
dies do start crimping at a angle, yeh obviously don't don't want this, need to always be parallel,
Now just a press, straight down no issues :D .
Need to find time to getting around to modding that old crimper.
megacycle
Postby thedarlington » Thu Jul 26, 2012 6:56 am
thedarlington
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: gknowes and 11 guests
