I took my packs apart today.
Is it me, or do the BMS's STINK? I mean SMELL, really, really bad? The 28s3p had a (2) BMS, one on each end (dated 2010), and all three 7s3p had a single BMS (dated 2009). All but one of the 2009 BMS looked thicker and lighter, tacky to the touch, and I had to take them outside because they were stinking up the garage. I wanted to disconnect them anyhow because I didn't know if they were draining current.
The good news is that all of the cells on my 19v pack are the same voltage - bad that they are all low, but good that none are dead. Every cell of every pack has every voltage!
All the the cells were in balance relative to their respective pack. Wonder if it helped that I was a good customer.
I like that the same screws are used to mount the covers and secure the BMS on both types of modules.
I believe that the painted metal seperators are a soft metal cooling fin, so having one side of each cell is enough. The endcaps have nice, big, metal-lined holes through them, providing an excellent mounting points. The 7s have horizontal holes, and the 28s has vertical holes, but I think you can remove the liner and use either set of holes.
- Because of the different metal in each tab, the welds on the negative terminals are gold, and the welds on the positive terminals are silver.
- 1 IMG_1944.JPG (162.46 KiB) Viewed 772 times
- Note the dowels demonstrating the vertical mounting holes on the 28s. Now that I have seen professionally installed balance wires, I feel better about my own work. I do appreciate the design feature of the wiring channel up the center.
- 2 IMG_1943.JPG (89.07 KiB) Viewed 772 times
- Note the dowels demonstrating the horizontal mounting holes on the 7s.
- 3 IMG_1954.JPG (112.62 KiB) Viewed 772 times
- Closeup of a horizontal hole
- 4 IMG_1937.JPG (52.8 KiB) Viewed 772 times
- Side view of a row of welds. You can see the different colors of the cell tabs. A very narrow gap between the buss bars, on the left.
- 4 IMG_1935.JPG (30.64 KiB) Viewed 772 times
- A row of welds. A plastic cap sits on top of each cell pair, the tabs stick through, and the buss bar is welded at the top. The screws that secure the top cover of this pack go into knobs in the foreground, which are part of the plastic carrier. I think the tabs are tensioned between the plastic carrier and the buss bar, and I remember Luke saying the tabs couldn't move around or they'd stress-fail, so I figure that is part of their purpose.
- 5 IMG_1936.JPG (61.09 KiB) Viewed 772 times
- Closeup of a tab, and the weld in the upper left corner.
- 6 IMG_1936_crop1.JPG (56.13 KiB) Viewed 772 times
- closeup on a row of welds, note the silver vs copper color.
- 7 IMG_1936_crop2.JPG (40.69 KiB) Viewed 772 times
- On the left, the 2009 BMS that is normal, on the right one of the 2009 BMS's that STINK, are gooey, you can see the color and sorta matte finish on these.
- 8 IMG_1953.JPG (71.69 KiB) Viewed 772 times
- 7s (2009) vs 28s (2010) BMS, side 1 (click for large picture)
- 7s (2009) vs 28s (2010) BMS, side 2 (click for large picture)
- Top of a 7s3p (click for large picture)
