Sutho wrote:
- 12 units were in the correct voltage range (around 23V) with minimal damage
- 6 units have 1 group of dead cells
- 1 unit has the negative terminal burnt off (shorted)
- 1 unit has been partially stripped (missing BMS internal wiring, cover, etc.)
- 2 units are severely damage and would not be safe to use
JRP3 wrote:For what reason? We know how they are assembled and what's inside.
Ypedal wrote:JRP3 wrote:For what reason? We know how they are assembled and what's inside.
Are the cells glued or adhered to eachother ? or just held together with the straps under compression ?
how difficult is it to seperate the 3P groups... i would have zero need for a 60ah pack.. from the looks of it it's best to order up single cells vs these modules and all the work involved to split them.. if you want 20ah ..
deVries wrote:I would suggest asking to use photos or Skype & video to show the defective parts. It seems an incredible waste of effort to return what is worthless. Obviously, paying for the return shipping is just too expensive, since these modules should have been in much better condition when shipped. I can understand one or two failures, but this really is ridiculous, imo.
This is very disappointing from my POV.![]()
How many modules were shipped per crate?
Sutho wrote:They were packaged 2 modules per crate. Some crates were well in tact and hard to open. Others fell apart.
Ypedal wrote:so.. someone is eventually going to have to rip one of these apart.... come on now.. or someone in canada pls sell me a dead unit cheap and i'll do the honors.
yet no one bothered to test their pack and post results?
isn;t anyone a bit curious if their 7s3p can put out at least 54aH ?
flathill wrote:The power backup apps all use cyclindrical cells from what I've seen. These are likely recall cells from all their prismatic customers including fisker and smith van. Also just older bad packs sent to the recyclers. Do all the newer cells say made in USA? That will tell you the answer if they are part of the recall. I'm guessing victpower has connections to the usa official recycler
I imagine they were handled as junk and were damaged before shipment in many cases. Victpower is relying on the fact it is so expensive to ship. Pretty shady but maybe you can salvage some cells. Now we know where the cut tab cells were coming from last year...no need for them to cut cells out of packs now given new recall cells with full tabs sell for more and they found a market for the modules
Sutho wrote:Oh.....and I will make a sacrifice and disassemble an A123 module if no-one else is keen....?
It is obvious that Victpower are aware that many/most of the modules are faulty, damaged goods and, despite numerous promises and assurances that the modules would be good or would be replaced, I have now been forced to submit a dispute with PayPal to recover at least half of my money.
Sutho wrote:I have now been forced to submit a dispute with PayPal to recover at least half of my money.
I have emails clearly stating that modules are New, Undamaged and Voltage Tested
Sutho wrote:Yes...can claim on international PayPal payments.
Yes....I would document the disassembly. I would attempt to repair a module with dead cells.
deVries wrote:Ok, Sutho, no one is going to stop you. You volunteered.![]()
Thanks for attempting to do the module repair too. At least you have a few to repair. Sorry.
So, just to be clear in my understanding:
Will PayPal also refund your shipping cost for the defective modules too?
competitions wrote:Sutho wrote:I have now been forced to submit a dispute with PayPal to recover at least half of my money.
Technically you could claim the whole lot back on PayPal.Sutho wrote:Oh.....and I will make a sacrifice and disassemble an A123 module if no-one else is keen....?
If you end up with something working with at least 10AH 24V(ish) then keep me in mind!
pgt400 wrote:Thats the part most disapointing to me...they stated them as new when they CLEARLY are not. They said the single cells were new, and they are. I was going to order a 7S3P pack...now I definately won't. If they said as is then fine...but instead they chose to lie.
Sutho wrote:At least some of the ones I received are from Fisker as they were labeled as such. I reckon there is a mix of sources as one has white heat transfer paste, one has pink plasticine type gunk, and the others have none. Most have grey aluminium cell surrounds and some have black. Some have a bar linking the terminals at each end and others don't.
Sutho wrote:It is by pure luck, not by careful selection, that I have 12 modules that are in reasonably good condition. It is obvious that Victpower are aware that many/most of the modules are faulty, damaged goods and, despite numerous promises and assurances that the modules would be good or would be replaced, I have now been forced to submit a dispute with PayPal to recover at least half of my money.
Sutho wrote:Xin Wang and the owners of Victpower have no morals and do not stand by their claims, assurances and promises.
I'd bet donuts to dollars that VictPower is the middleman in the transaction, and has little control over the supply.
Users browsing this forum: Google [Bot], mushymelon and 8 guests
