i have been working on getting a 4 amp ballancer running stabaly over the last couple of months in my spare time and wanted to know what you guys think about it
***EDIT (you should be able to charge at well over 4 amps but that should be the most it will actively balance at)
***EDIT no cut-out for overcharged cells (shrugs) should be fine at 4.1 anyway as it gives you some headway to let other cells catch up
***EDIT can be easily adjusted to charge lifpo4 just swap out the voltage divider feeding the tl431 ref pin with values that will turn on at required voltage (tl431 wants to see 2.5ish volts to turn on)
its based on the tl431 adjustable shunt regulator
schematic
prototype 1
put the 3906 transistors in backwards (still worked for the led for some strange reason c-e swaped?)
proto 1 was only good for 1 amp charging w/o overheating the un-heatsinked power transistors (mounted under board)
proto 2 (working right)
powered up shunting 4 amps of current
and yess that is a cut down pentium 1 cpu heat-sink held in place with a hair elastic on my aluminium angle heat bar (its temporary)
BOM per series + mouser part numbers
cant remember the part number off hand for the insulators for the power transistors
IC
TIP147T
1: $0.775
25: $0.673
100: $0.59
2N3906TAR
1: $0.076
25: $0.066
100: $0.045
TL431BCLP
1: $0.666
25: $0.524
100: $0.46
(CAPASITORS)
REA101M1ABK-0511P (10v 100uf)
1: $0.066
10: $0.06
100: $0.058
C320C104Z5U5TA (0.1uf ceramic)
1: $0.131
100: $0.087
B32529C103J (0.01uf polly)
1: $0.12
50: $0.112
100: $0.106
(RESISTORS)
280-CR25-1.0-RC (1 OHM resistor 25w)
1: $1.19
10: $1.08
100: $0.895
291-120-RC (120 OHM 1/4w)
1: $0.109
10: $0.059
200: $0.021
ERD-S2TJ331V (330 OHM 1/4w)
1: $0.098
25: $0.038
100: $0.029
PV36Y202C01B00 (2ktrim)
1: $1.49
50: $1.01
100: $0.876
291-1K-RC (1k 1/4w)
1: $0.109
10: $0.059
200: $0.021
291-5.6K-RC (5.6k 1/4w)
1: $0.109
10: $0.059
200: $0.021
291-8.2K-RC (8.2k 1/4w)
1: $0.109
10: $0.059
200: $0.021
(OTHERS)
m3 screws and tap
aluminum angle
old cpu heatsink
insolating heat conductive to220 pads
insolating washers for mounting the transistors to the angle
red led 3-5mm
proto board
