How do I get a meanwell to run off 72VDC?
Postby flexy » Tue May 01, 2012 2:36 pm
I need to step my 72V pack voltage down to 48V, to run the lights and switchgear on my E-max 110s scooter
see http://www.endless-sphere.com/forums/viewtopic.php?f=10&t=38617.
I bought a 48V 2A meanwell supply for this purpose, but it won't show any signs of life when fed from my pack (79V)
Are there any mods I can do to get it working?
flexy
Re: How do I get a meanwell to run off 72VDC?
Postby heathyoung » Tue May 01, 2012 7:17 pm
Unfortunatly, this is a dual voltage supply (ie. 120/240, hence the switch).
The switch forms a voltage doubler with the caps and bridge rectified when fed with 120V AC - If you can find a dedicated 110V supply (or true multivoltage supply - ie. no switch to change between the two) you may have far better luck. Probably avoid PFC supplies as they often have 'brown-out' protection that may trip to protect the supply.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby flexy » Wed May 02, 2012 3:01 pm
Thanks for the info , the nearest I found so far is this
http://www.wattbits.com/power-supplies/switch-mode-ac-dc/aqf100o-48s.html
Do you think it might work?
flexy
Postby heathyoung » Wed May 02, 2012 6:00 pm
Rated with that range, I would be pretty confident that it would.
LED lighting rated probably means it is current limited as well, which is useful.
heathyoung
Return to Battery Technology
Users browsing this forum: mark5, Secret1511, swbluto and 7 guests
