replacement battery required
Postby ebent » Sat Jun 02, 2012 11:25 pm
A neighbor has a golf cart. Standard set up. I guess a massive 12v SLA. Can a lithium battery be installed? Is it financially effecient? Thanks for the help.
2005 catrike pocket trike
750 watt hub motor
48v 18ah Lifepo4 electrified 1/2010
ebent
Re: replacement battery required
Postby amberwolf » Sun Jun 03, 2012 1:17 am
There's no specific standard for golf carts. Some are 24V, some 36V, some 48V, etc. Space used for batteries varies, too.
Basically we gotta know all the same things about the cart and it's usage that we'd need to know about an ebike to recommend a battery. ;)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby wesnewell » Sun Jun 03, 2012 1:38 am
Simple answer is yes. Half the AH rating , and about 1/8 the weight of those lead weights will get you more distance. As already pointed out, will need controller info to make battery selection.
Mongoose 26" FS MTB bike $99, yescomusa.com 48V 1000W rear hub kit $276, Hua Tong 72V 40A controller $35, 10ah 24s lipo $275=40+mph, range=45 miles @20mph
wesnewell
Postby dogman » Sun Jun 03, 2012 6:01 am
Yep. I would go with thunderskies or similar prismatic packs of lifepo4. 4 cells per 12v, and monitor with a voltmeter on each cell.
Cost effective? Maybe not, far as I know the golf courses have not adopted them yet in my locale. Definitely the way to go though, if you need more range than possible with the lead. I'd stick with the lead if you are able to charge at frequent intervals after short runs.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby ebent » Sun Jun 03, 2012 7:43 am
This cart will never see a golf coarse. It will be on a 1 acre property. It will be used a little for yard work and also to serve the dock and fishing boat. It is a long dock and and a small hill near the house. Modest amount of ah required. I'll find out about the voltage and controler.
750 watt hub motor
ebent
Postby dnmun » Sun Jun 03, 2012 7:58 am
no, it is not financially feasible. the guy will not know how to maintain the pack, it will die and the huge cashflow outlay will be wasted. they are able to haul the fat ass batteries around so he should continue using them.
dnmun
Postby 999zip999 » Sun Jun 03, 2012 11:44 am
Those fat ass batteries keep that cart from rolling over after a couple of beers.
999zip999
Return to Battery Technology
Who is online
Users browsing this forum: boostjuice, pm_dawn and 7 guests
