Well, 1 week charging the problematic groups. Incredible, 2 groups "appears" to revive... But the voltage drop much more than the other groups (in fact, the other groups are all in the 3.3v state...)
Facts: I have the original 16s charger and a 12s charger. So, I still think the best idea is to turn this pack a 12s, because I think I will can suck a lot of current from it, and I have the correct charger for 12s...
This is the BMS. Is there a way to test it?
Heathyoung: this small spots near balancing connectors is to convert this BMS to other configs? You told wrote something, hun? Is just bridge the 12s points and ok, turn it to 12s version? Then, I have to start from left to right the balancer wires?
Finally: is there a way to cut off the "low voltage protection" from hyperion 1420? To start the slow charge the bad groups, I need to stay present a lot of time in the begining, starting over and over again after five minutes, because the charger stop the process after 5 minutes, untill the groups reach at least 3.3v
Pics:
- P6130101-001.JPG (157.47 KiB) Viewed 359 times
- P6130094.JPG (41.85 KiB) Viewed 359 times
- P6130098.JPG (70.9 KiB) Viewed 359 times
