How can I mod this watt-meter?
Postby ian.mich » Mon Jun 04, 2012 5:10 am
http://www.hobbyking.com/hobbyking/stor ... duct=10786
is there any way to mod this to accept 100V 5A? i'm building a 10kW hubzilla setup for a customer running at 88.8v 100A and want to hook this up on the charge port so its only handling the voltage and 5A from the charger
http://www.AtypicalEV.com
Avalanche 3.0
Front and back Weinmann DH39s in 12G,
Motor laced using custom Sapim 12G with linseed oil
24s3p 5ah hardcase LiPo in a FalconEV frame bag, 8A bulk charge
Batt medics
18x4110 controller at 60A
DD hub with 12g inside and 10g outside
Doc's torque arms
ian.mich
Re: How can I mod this watt-meter?
Postby NeilP » Mon Jun 04, 2012 5:39 am
I could be wrong, but I think that has been asked before and no is the answer..
Get a Cycle Analyst
http://www.ebikes.ca/drainbrain.shtml
Or see if patrick ( Methods ) has a second old one for sale, it will do the job you can't afford a new one. OK still more than the meter you linked to, but far better
http://www.methtek.com/2012/05/25/vintage-ca/
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Postby ian.mich » Mon Jun 04, 2012 11:32 am
but why when I can just mod this and save 30-80 dollars, shouldn't be too hard
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby nicobie » Mon Jun 04, 2012 12:14 pm
Why bother when you can get a Harbor Freight one for $4 that will do the job.
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby Ricky_nz » Mon Jun 04, 2012 12:28 pm
ian.mich wrote:but why when I can just mod this and save 30-80 dollars, shouldn't be too hard
1) Change voltage regulator circuit
2) Change input scaling
3) Change software (Reverse engineer or rewrite)
Is it really worth your time?
Latest Projects: High power vector controller for Turnigy 80-100, Keewe Stealth DJ bike with Turnigy 80-100 180.
Youtube channel: http://www.youtube.com/user/rwhitenz?feature=mhum
1) Specialized Hard Rock + surviving 1/2 of Elation 300W + Sick Bike Parts freewheel and sprockets + echo cranks.
2) Commuter bike with 1000W GM rear hub.
Ricky_nz
Postby NeilP » Mon Jun 04, 2012 1:34 pm
If you can, then go right ahead, i would certainly be interested, as I suspect will a lot of others on the forum. Better if you could make it handle slightly larger charge currents, 15, 20, 25 amps.
nicobie wrote:Why bother when you can get a Harbor Freight one for $4 that will do the job.
What ? lets have a link to one of those then, I have had a quick flick and search of their site and came up blank.
180mm disks
100V 20Ah LiPo
NeilP
Postby ian.mich » Mon Jun 04, 2012 2:32 pm
Let's get a link in here, and yeah i've realized that its more work then its worth, probably just get a voltage panel on ebay and forget about a wattmeter if i cant find a "Harbor Freight"
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby NeilP » Mon Jun 04, 2012 2:44 pm
I am no EE myself so have no idea on how a mod like that would be carried out, but I since no one has done it yet, I assume it is not an easy matter.
I did what you just suggested...cheap panel volt and ammeters from e-bay, though they do each need an independent power supply though
180mm disks
100V 20Ah LiPo
NeilP
Postby ian.mich » Mon Jun 04, 2012 4:10 pm
NeilP wrote:I am no EE myself so have no idea on how a mod like that would be carried out, but I since no one has done it yet, I assume it is not an easy matter.
not this one
http://www.ebay.com/itm/170846310527?ss ... 1497.l2649
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby NeilP » Mon Jun 04, 2012 4:19 pm
I did nto use that one, but it looks bettr than the ones I used..powered off the supply it is measuring too..is it waterproof do you reckon> it looks like it is shown working in a bowl of water in the pic
I used these:
http://www.ebay.co.uk/itm/Blue-LED-0-20 ... 2357wt_994
180mm disks
100V 20Ah LiPo
NeilP
Postby NeilP » Mon Jun 04, 2012 4:24 pm
The seller you found seems to sell a fair range
http://www.ebay.com/sch/m.html?_nkw=met ... =shcfstore
..even a single unit that is combined amps and volts, power and time..if the display on the front is accurate
in fact the spec shows it measures Ah
Display resolution: 0.01 V, 0.01 A and 0.01 W, 0.01 AH.
I hve sent them a message to see if I can get a wiring info sheet off them...I may have to buy some of these for my Meanwell chargers
180mm disks
100V 20Ah LiPo
NeilP
Postby ian.mich » Mon Jun 04, 2012 5:03 pm
seems like i made my first real contribution to ES
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby SamTexas » Mon Jun 04, 2012 5:05 pm
+1. What are you talking about nicobie?
SamTexas
Postby NeilP » Mon Jun 04, 2012 5:09 pm
ian.mich wrote:seems like i made my first real contribution to ES
:D :D :D
Already got a guinea pig for two of them...ypedal has put his toe in the water..I posted about them in a new thread
viewtopic.php?f=14&t=40434&p=590861#p590861
180mm disks
100V 20Ah LiPo
NeilP
Postby ian.mich » Mon Jun 04, 2012 5:10 pm
NeilP wrote:I did nto use that one, but it looks bettr than the ones I used..powered off the supply it is measuring too..is it waterproof do you reckon> it looks like it is shown working in a bowl of water in the pic
I used these:
Yes it says in the title it is waterproof
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby ian.mich » Mon Jun 04, 2012 5:13 pm
Nice, i knew my meticulous internet searches would come in handy
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby NeilP » Mon Jun 04, 2012 5:27 pm
Oh yes , totally missed that in the title ... Doh!
180mm disks
100V 20Ah LiPo
NeilP
Postby nicobie » Tue Jun 05, 2012 1:40 pm
SamTexas wrote: What are you talking about nicobie?
Here you go:
http://www.harborfreight.com/7-function ... 69096.html
I have about 5 of them now. I have coupons that get them for free if I buy $10
nicobie
Postby SamTexas » Tue Jun 05, 2012 1:44 pm
Geez Nicobie. That does not even come close to a wattmeter.
FWIW: I have 4 or 5 of them. They are only ok, but not reliable at all. But hey, what can you expect for that price.
SamTexas
Postby NeilP » Tue Jun 05, 2012 1:46 pm
Here you go:
Yea, but they are just volt meters/ammeters DVM's.they are not Watt meters
180mm disks
100V 20Ah LiPo
NeilP
Postby ian.mich » Tue Jun 05, 2012 3:29 pm
Here you go:
Yeah thats not really what we were looking for at all, and if I were to get a workbench voltmeter and ammeter I would want something that cost more than $4.99
we were looking for something that tracks A, V, and Ah and is durable enough to be put on a bike
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby NeilP » Tue Jun 05, 2012 3:43 pm
Although those cheapo ones are poor quality. I have a stack of them, even cheaper I seem to remember. $0.99 on eBay from china
The battery for them is the main cost. I bought .. 10 of them, leave one in the bike, garden shed the boot of the car, give them to mates who keep borrowing yours, hold doors open with them, whatever, they are generally are good for 10 amps or so
As Ian said, not what this thread is about, but none the less worth having a few cheapie a around
180mm disks
100V 20Ah LiPo
NeilP
Postby puddleglum » Tue Jun 05, 2012 11:12 pm
Does anyone know if the watt meter in the first post would work well for a 24v system, just to tell Watt hours used? A CA would be nice, but it's overkill for my purpose.
puddleglum
Postby NeilP » Wed Jun 06, 2012 3:37 am
As long as your system is not drawing more than 100 amps then it is fine
180mm disks
100V 20Ah LiPo
NeilP
Postby ian.mich » Wed Jun 06, 2012 6:55 am
yeah i have the hk-010 for my 12s4p 40a system and it does the job. also useful because its a balancer (cell checker, parallel balance harness is my weapon of choice) very useful to just have everything on the bike that way
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Next
Return to Battery Technology
Who is online
Users browsing this forum: tcervas and 11 guests
