How can I mod this watt-meter?
Re: How can I mod this watt-meter?
Postby ian.mich » Mon Jun 04, 2012 5:13 pm
Nice, i knew my meticulous internet searches would come in handy
http://www.AtypicalEV.com
Avalanche 3.0
Front and back Weinmann DH39s in 12G,
Motor laced using custom Sapim 12G with linseed oil
24s3p 5ah hardcase LiPo in a FalconEV frame bag, 8A bulk charge
Batt medics
18x4110 controller at 60A
DD hub with 12g inside and 10g outside
Doc's torque arms
ian.mich
Postby NeilP » Mon Jun 04, 2012 5:27 pm
Oh yes , totally missed that in the title ... Doh!
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Postby nicobie » Tue Jun 05, 2012 1:40 pm
SamTexas wrote: What are you talking about nicobie?
Here you go:
http://www.harborfreight.com/7-function ... 69096.html
I have about 5 of them now. I have coupons that get them for free if I buy $10
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby SamTexas » Tue Jun 05, 2012 1:44 pm
Geez Nicobie. That does not even come close to a wattmeter.
FWIW: I have 4 or 5 of them. They are only ok, but not reliable at all. But hey, what can you expect for that price.
SamTexas
Postby NeilP » Tue Jun 05, 2012 1:46 pm
Here you go:
Yea, but they are just volt meters/ammeters DVM's.they are not Watt meters
180mm disks
100V 20Ah LiPo
NeilP
Postby ian.mich » Tue Jun 05, 2012 3:29 pm
Here you go:
Yeah thats not really what we were looking for at all, and if I were to get a workbench voltmeter and ammeter I would want something that cost more than $4.99
we were looking for something that tracks A, V, and Ah and is durable enough to be put on a bike
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby NeilP » Tue Jun 05, 2012 3:43 pm
Although those cheapo ones are poor quality. I have a stack of them, even cheaper I seem to remember. $0.99 on eBay from china
The battery for them is the main cost. I bought .. 10 of them, leave one in the bike, garden shed the boot of the car, give them to mates who keep borrowing yours, hold doors open with them, whatever, they are generally are good for 10 amps or so
As Ian said, not what this thread is about, but none the less worth having a few cheapie a around
180mm disks
100V 20Ah LiPo
NeilP
Postby puddleglum » Tue Jun 05, 2012 11:12 pm
Does anyone know if the watt meter in the first post would work well for a 24v system, just to tell Watt hours used? A CA would be nice, but it's overkill for my purpose.
puddleglum
Postby NeilP » Wed Jun 06, 2012 3:37 am
As long as your system is not drawing more than 100 amps then it is fine
180mm disks
100V 20Ah LiPo
NeilP
Postby ian.mich » Wed Jun 06, 2012 6:55 am
yeah i have the hk-010 for my 12s4p 40a system and it does the job. also useful because its a balancer (cell checker, parallel balance harness is my weapon of choice) very useful to just have everything on the bike that way
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby nicobie » Wed Jun 06, 2012 12:26 pm
SamTexas wrote:Geez Nicobie. That does not even come close to a wattmeter.
:mrgreen: A x V = Watt :mrgreen:
nicobie
Postby SamTexas » Wed Jun 06, 2012 12:33 pm
OK, no argument from me. But your $4 figure does not work anymore. You need not one, but two DMM. You also need a shunt so you can read the current on the second DMM. And your brain needs work superfast to convert whatever voltage you see on the "A" meter to actual current and multiply with V to get your power. Watch out, here come another truck!
SamTexas
Postby ian.mich » Wed Jun 06, 2012 4:37 pm
and it doesn't measure Ah or Wh.
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby nicobie » Wed Jun 06, 2012 5:53 pm
What can I say...
If you are looking for a cheap way to monitor your system, this will work.
If you are looking for a cheap CA, good luck :P
nicobie
Postby amberwolf » Wed Jun 06, 2012 6:36 pm
You can still use the originally-linked WM for your 100V+ pack, but in a way that doesnt' monitor watts or Wh or voltage quite right (yet is simple to recalculate).
Put a tap for the watt meter to go in on 1/2 your pack, so that it is only reading the voltage from half of it, keeping it under the likely 60V max even when fully charged.
Then just multiply the W, Wh, and voltage readings by two, and you'll have the correct numbers for those, within a reasonable accuracy.
The Amps and Ah will be correct either way.
http://www.endless-sphere.com/w/index.p ... age_System
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby rwaudio » Wed Jun 06, 2012 7:53 pm
amberwolf wrote:You can still use the originally-linked WM for your 100V+ pack, but in a way that doesnt' monitor watts or Wh or voltage quite right (yet is simple to recalculate).
That won't actually work as you describe. The best you could do is measure voltage of half the pack, but all other measurements are not possible. Current needs to flow through the meter so unless the OP is charging the pack with two separate isolated chargers each charging half the pack it doesn't work.
If it was a hall effect based device that could work, but these almost always use a shunt which you can't get in the current path at the 1/2 pack voltage point.
rwaudio
Postby amberwolf » Wed Jun 06, 2012 11:58 pm
Current thru the series-wired system is the same at any point in the system, so regardless of where you put it, it'll still measure current accurately.
Besides, if you are using it on the "bottom" (most negative) half of the pack, the shunt is in the ground wire of most of these meters, so it would still read the full system current, exactly as if you were measuring the full pack--the only difference is that the voltage supply to the meter is only half the pack's voltage, if it's tapped in the middle of the pack.
You could use two meters, one on each pack half, and add the watt-based readings, but multiplying a single meter's results by two is close enough for most purposes, unless you truly need to monitor actual pack voltage sag and the like. Two meters cost nearly twice as much, too (slightly less as usually shipping cost isn't doubled), so depending on price and complication of setup it might wind up easier to buy a CA or something similar.
amberwolf
Postby fivari » Thu Jun 07, 2012 9:06 am
puddleglum wrote:Does anyone know if the watt meter in the first post would work well for a 24v system, just to tell Watt hours used? A CA would be nice, but it's overkill for my purpose.
I've got one like these. It shows current, Voltage, Watt and Ah but does not allow to know how many Wh used. You could multiply the Ah with average voltage, if that is good enough for you.
fivari
Postby ian.mich » Thu Jun 07, 2012 12:00 pm
Avalanche 3.0
Batt medics
Doc's torque arms
ian.mich
Postby Emoto » Sun Jun 10, 2012 3:19 pm
Or buy one of these Image
i had the first metre good but prefer this one.
Just a quick flight http://vimeo.com/30385026
Emoto
Postby Jeremy Harris » Sun Jun 10, 2012 4:03 pm
Emoto wrote:Or buy one of these Image
Won't do what the OP wants, unfortunately. He's looking for a wattmeter that will accept 100V, and the only one that I know of that will do that is the CA, as already mentioned earlier in this thread.
Jeremy Harris
Postby Emoto » Mon Jun 11, 2012 6:31 am
Yes :oops: your right, i should have elaborated, as you know there is a voltage mod for the turnigy but sadly only reads to 75v but working on 100v i think, http://endless-sphere.com/forums/viewtopic.php?f=31&t=17904. Is there a better mod thread jeramy ?
I would love to find a simple/cheaper watt-metre in the 100/120 v.
I wonder if enough of us contacted hobby king and requested a modified version of the turnigy to handle 150v/150amp that would be very popular.
Emoto
Postby Jeremy Harris » Mon Jun 11, 2012 6:42 am
Emoto wrote:Yes :oops: your right, i should have elaborated, as you know there is a voltage mod for the turnigy but sadly only reads to 75v but working on 100v i think, http://endless-sphere.com/forums/viewtopic.php?f=31&t=17904. Is there a better mod thread jeramy ?
I don't know of one, TBH, other than the CA. The main problem with getting up to voltages like this is the power supply for the unit, it would really need a small switched mode supply to run at 100 V plus. The changes to the resistive divider that senses the supply voltage is just a component value change, then the firmware would need to be altered to increase the range indicated. I doubt the volume of sales would be enough to get HK interested, plus there are legal issues as soon as you make something to sell that works at over around 60 V, as it then needs safety certification I believe.
Jeremy Harris
Postby Emoto » Mon Jun 11, 2012 7:04 am
Well the best i can find atm Ian is this volt metre http://endless-sphere.com/forums/viewtopic.php?f=14&t=40616 courtesy of dogman
and a promising volt amp and Ah meter for USD $15 http://endless-sphere.com/forums/viewtopic.php?f=14&t=40434&p=590861#p590861
the latter looks sweet
Emoto
Next
Return to Battery Technology
Who is online
Users browsing this forum: mvly and 6 guests
