Ossielocal wrote:Hi guys,bit of a noob when it's comes to Serial/Parallel Connection .At the moment i have a ping 48v 10ah battery i'm looking at getting 4 of those ZIPPY Flightmax 8000mAh 6S1P 30C would be worth getting and would i get longer ride out of these batteries ! How would i wire them up to make it 44.4 16ah . Cheers
wesnewell wrote:Ossielocal wrote:Hi guys,bit of a noob when it's comes to Serial/Parallel Connection .At the moment i have a ping 48v 10ah battery i'm looking at getting 4 of those ZIPPY Flightmax 8000mAh 6S1P 30C would be worth getting and would i get longer ride out of these batteries ! How would i wire them up to make it 44.4 16ah . Cheers
Your 10ah ping charges to close to 60v while the 12s lipo will charge to a ~50v. To compare riding time, you need to know the watt hours of each pack. Ping is 528wh and zippy is 710wh, so you should get about 30% more range with the zippy. To wire, simply stack 2x2.wire bottom 2 together black to red, top 2 together black to red. Then parallel the open ends on each side.
motomech wrote:wesnewell wrote:Ossielocal wrote:Hi guys,bit of a noob when it's comes to Serial/Parallel Connection .At the moment i have a ping 48v 10ah battery i'm looking at getting 4 of those ZIPPY Flightmax 8000mAh 6S1P 30C would be worth getting and would i get longer ride out of these batteries ! How would i wire them up to make it 44.4 16ah . Cheers
That's what I do. Since the majority of my rides are local and I don't need much range, I use just one 12S/5Ah pack, which is 2) 6S/5Ah bricks taped together and wired in series. Why carry way more battery than you need, especially if that space can be used for groceries?
If I think I might need more range, I parallel 2) of the 12S/5Ah packs to get 12S/10Ah using these;
Which are the standard HK parallel adapters[left]which I have replaced the "common" leg with 12Ga.
So each "leg" is ;
12S/5Ah14Ga.
.......................12S/10Ah
12Ga.
controller[s]
12S/5Ah14Ga.
That's as much as can be wired up at one time, but a really long ride, I carry 2) more 12S/5Ah packs which can be swapped out in a minute or so.
I like the "building block" approach, but I don't do daily long commutes on my bike.
Also, the 50V[hot] packs don't tax the 14Ga. wire of the HK adapter.
O.P. I understand your attraction to the 8Ah packs, it seems a simple and elegant approach, but you pay dearly for those extra 3000mAh's. I'm in the process of chaNging over from Zippy 15C's to Turnigy 20C's and I'm very impressed with the Turnigys. I'm only seeing a 1V sag pulling over 1000 Watts on a fresh 12S/5Ah pack, compared to 2V's with the Zippy 15C's.
And at $44 per 6S/5Ah brick, you could have 20Ah's of 12S for less than you will spend for 16Ah's of Zippy 8Ah's.
motomech wrote:O.P. I understand your attraction to the 8Ah packs, it seems a simple and elegant approach, but you pay dearly for those extra 3000mAh's. I'm in the process of chaNging over from Zippy 15C's to Turnigy 20C's and I'm very impressed with the Turnigys. I'm only seeing a 1V sag pulling over 1000 Watts on a fresh 12S/5Ah pack, compared to 2V's with the Zippy 15C's.
cwah wrote:motomech wrote:O.P. I understand your attraction to the 8Ah packs, it seems a simple and elegant approach, but you pay dearly for those extra 3000mAh's. I'm in the process of chaNging over from Zippy 15C's to Turnigy 20C's and I'm very impressed with the Turnigys. I'm only seeing a 1V sag pulling over 1000 Watts on a fresh 12S/5Ah pack, compared to 2V's with the Zippy 15C's.
I've seen in Hobby king the 6s 15C zippy, they do seem quite good on the specs. They top at 163wh/kg, which is much higher than the 20C Turningy. Zippy 15C are a little bit more expensive, but they remain really cheap and you won't find any battery at this price at 162wh/kg! If you have too much sag, just double your pack and increase the AH. The sag will be lower and you'll have a high capacity pack with one of the lowest weight possible.
Gday Motomech, i was going to go 5000mah batteries but i would still need 6 of them and it would of come to the same price...
[/quote]Is 12awg wire good for my setup being the batteries 8000mah ?
motomech wrote:Well, i never weighed the individual bricks, but I just weighted one of each of the Turnigy 20C and the Zippy 15C 12S/5Ah packs and I got;
Zippys-22.55 Oz[my scale only does oz.s]
Turnigys-24.8 Oz.
So there is a substanial weight difference of 1 1/4 Oz.s per brick, but not the 2 Oz.s per brick that the HK spec.s would indicate.
So, a sm. pack of Turnigy 20C would weigh a 1/3 of a pound more than the same 12S/5Ah of Zippy 15C. Given that my Ebike weighs 56 lb.s and my batteries are well placed in the frame, that difference is inconsequential. And if I felt I had to add more 15C just to mitigate voltage sag[in reality, 2V sag is nothing, especially for someone who came from LiCoMg and was used to seeing sag in the 3 to 5 V range!], how does that save weight?
But we are nit-picking. But there is one factor that I.M.O., makes the Turnigy to one to go with and that is US warehouse availability. We here in the States greatly prefer to get our batteries from the US warehouse and for the last 6 months or so, the 15C Zippy 6S/5Ah's have been real spotty, where the Turnigy's have been steadily available.
Since I'm using both, time will tell, but my gut feeling is the Turnigy is the better battery for the money.
Are you talking about these Turningy pack?
http://www.hobbyking.com/hobbyking/stor ... ouse_.html
And I suppose it's these Zippy 6s?
http://www.hobbyking.com/hobbyking/stor ... oduct=7639
At 22.55Oz/pack, it's lighter than what is advertised. So maybe not the right pack
Users browsing this forum: Bing [Bot] and 7 guests
