by mwkeefer » Sat Feb 20, 2010 3:08 pm
Hyena,
Sorry I've been absent, I would have warned you about turning a 48v down below 33v or so... I have toasted 2 of them doing this and 33v seems the limit for the 48v unit on the low end - I had one I ran at (no BS) 16v but that went up in smoke fast (worked a few hours, I was using it to power my iCharger).
I have on hand 3 of the 24v 320s and one of each of the 350s for experiments + the 48s I use as 5.5A chargers (15S) and about half a dozen other models (mostly S-350 but a few S-145 and so on).
Also, props on the resistor mod for the thermistor - that is probably the simplest mod to get the fan to spin at all times, I have other methods but they are complicated and require an MCU to control them... I like the simple approach.
One note about calibrating the output current, it should be done after:
1.) the resistor mod to get the fan to pop on
2.) the fan lid should be connected
3.) The unit should be run for a moment (not long without heatsinks) but enough that those transistors are hot (not burning but hot) to ensure accurate calibration when unit is in service.
That will ensure trouble free operation - I agree with your observation (I see the same thing) that even without current limiting mods... as long as your not going wildly beyond the shipped range, I have had great success with the 48v units allowing them to run 400-480watts, yea they make noise and sound like bacon in the pan (just a little) but the 48 I have been testing this way has been fine for the last 3 months and I charge about 4-5 packs daily with it (15S2P/1P).
For the price - they are hard to beat, even if 1 in 6 goes bad or is bad on arrival. Where else can you get a 15S 63v 5A charger in a single unit for 25.00? Or for that matter a 20S 10A charger? Exactly.
Regards,
Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
