Switch mode supply mod
Re: Switch mode supply mod
Postby fechter » Sun Dec 25, 2011 2:11 pm
As far as I can tell, the PA905C4 is rated for 400v, 20A, so should not be a limitation.
datasheet: http://server.oersted.dtu.dk/ftp/database/Data_CDs/Component_data/Fuji_Semiconductor_2003/pdf_2/pdf/F0400074.pdf
fechter
Postby bobale » Sun Dec 25, 2011 3:38 pm
Nice. When I modify it I'll post results here.
RWD 2807 9Continent rolling on Kenda Flame 26x2.125
12S3P out of Turnigy 4S Hardcase 20C (600Wh)
35A 9FET Infineon Controller (Regen, Cruise control, Speed limit)
Top Speed 27mph (31mph@120%)
bobale
Postby MrKang » Fri Jul 27, 2012 4:05 pm
two years ago i modified 2 S350-48 for charging my 24S lipo setup.
I recently got four 200-24 meanwells which i also want to cranck up to 10A instead of 8.4.
But if i look at it i don't see which resistor i have to change.
Does anybody has some experience in modifying this model ?
MrKang E-Scooter : 24V 750W Bosch Motor modified with YK-43 48V 1kW on 12S6P Lipo - top speed 44kmph
Xinling XTD800A : LYEN 4110 72V (modified for safe 100.8V with extra cooling) - 24S4P/100.8V 25Ah Turnigy + CA with Datalogger + SOUNDSYSTEM + USB power outlet + 78km top speed(120%)
MrKang Retro II : in progress.. ** 12FET MKII LYEN + 28S 20AH LifePO4 cells **
Project link [/color]: http://endless-sphere.com/forums/viewtopic.php?f=10&t=13442
MrKang
Postby NeilP » Fri Jul 27, 2012 4:50 pm
YOU seem to be wanting to do the reverse of what the rest of us do to the Meanwells...we all tend to REDUCE the output current, so we do not burn them out, not icnrease the currents
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Previous
Return to Battery Technology
Who is online
Users browsing this forum: ammodave, Google [Bot], Hillhater, J Barrie Wilkinson and 7 guests
