parajared wrote:Avoid those rediculous 300v, power grid assist panels that people seem to get suckered into. If you have a power outage and you have one of those goofy "assist" pannels on your house you will still end up with no power in an outage.
999zip999 wrote:I think hipower ebikes has a solar blanket that charges at 48v for about 700-900usd. On a 36v solar panal does it go high enough to charge a 36v ping at what 40v ? AW has the easy way, but the cost and the lost of charge energy.
ddk wrote:-
All you need is about 3-12V panels hooked in series or enough solar cells in series for an open-circuit voltage of around 50-55V.
Hook the connection up to your 36V battery and wait until done. (whatever chemistry you've got).
You might wanna undercharge a tad.
If you're an analog electronics kinda guy use a voltage comparator circuit to shunt the panels' output from the battery when the voltage reaches your desired goal.
whatever wrote:I haven't done this but also intend to do a solar system,
this is what I'd do...
sapo wrote:ddk wrote:-
DANGER Do not direct connect a Solar panel to a LI PO battery. If the battery is charge above 4.25 V per cell then CA-BOOM oh damn there goes another dreamliner!!!
Users browsing this forum: Truusje79 and 8 guests
