def215 wrote:i did want to put it on my handlebars, but all of my electrics are in the bag. ill mainly use this for battery status to determine range and for charging. i just didnt want to keep my wattmeter permanently on this bike just to look at the voltage for those purposes.
i ordered mine on july 19th, and it just got here today. so a bit over 3 weeks. now im waiting for the $15 wattmeter to come in from the same seller.
Thanks, it looks like I may have another week to wait, but I'm also waiting for some other parts also maybe I'll take bets on which parts arrive first.
migueralliart wrote:I bought a couple of those and some plastic enclosures. My plan is to make some easy DIY handlebar install that looks CLEAN. I'll probably start a DIY thread to help others do so as well.
If only I could find a similar AMP meter with external shunt and with the same voltage range that doesn't require power. I could integrate it into the plastic enclosure and it will be perfect for any low budget build.
Nice idea with the DIY thread. Right now my handlebars are a total mess due to having so many things mounted, and wires are everywhere. Maybe getting wider bars would be an idea, but even so a thread with other people's setups would be to use as inspiration.
Also if you need an amp meter with remote shunt, consider going for the turnigy watt meter with the remote shunt mod. I think Jeremy Harris posted a thread on how he managed to do it, it works well as you don't need a separate power supply, you just run 3 wires to your bars and you get volts, amps, watts.
