Victpower A123 pre-made pack review
Re: Victpower A123 pre-made pack review
Postby cwah » Mon Jul 23, 2012 4:34 pm
I'll probably end the voltage at 3V or when the BMS cut-off. For now I've used 800wh and the voltage still was at 65V. I'm waiting for the strong voltage drop to stop. I believe the Lifepo4 are very on their nominal voltage, and when they are not anymore at that voltage, there isn't much power left. And it's time to stop :)
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby cwah » Mon Jul 23, 2012 4:35 pm
thedarlington wrote:id say either no lower than 50 or 52v but it would be interesting to know what that BMS board uses
Yeah, also maybe 50V few time to check the pack capacity. But I wouldn't do it most of the time.
cwah
Postby cwah » Mon Jul 23, 2012 7:20 pm
Tried a full charge today. On my cycle analyst the voltage went up to 73.2V, then go slowly down to 72.7V. On my multimeter I have 71.8V... :?
I almost have 1 V difference between my multimeter and the cycle analyst. Who's right?
cwah
Postby 999zip999 » Mon Jul 23, 2012 8:51 pm
Do you have a second MM ?
999zip999
Postby ohzee » Mon Jul 23, 2012 9:29 pm
Just charged up one of my 20s A123 packs I made from victpower cells. It has a ping high power BMS which evens out all
the cells.. Testing all the cells they are at 3.47 pack voltage is 71.5.
So id say yours is looking good as well.
ohzee
Postby cwah » Wed Jul 25, 2012 5:31 pm
Did a capacity test today... and I'm quite impressed by my pack.
I did 66 km at around 35-40 kph, and a lot of start and stop. So a lot of acceleration.
I use it until 58V under load:
I noticed that under 61V, the pack voltage drop really quickly.
And on my cycle analyst, it says I used 1450wh :shock:
My cycle analyst is probably mis-calibrated, because it would otherwise mean that my pack has over 22AH capacity. I did 66 km at 35-40 kph with good acceleration, so my bike used at least 15 wh/km and my pack has at least 1000wh even if miscalibrated.
It was a bit warm after the ride, but I think I'm going to be happy with my pack.
cwah
Postby cwah » Wed Jul 25, 2012 5:35 pm
999zip999 wrote:Do you have a second MM ?
no, only 1 mm :(
cwah
Postby deVries » Wed Jul 25, 2012 5:47 pm
cwah wrote:Did a capacity test today... and I'm quite impressed by my pack.
Do you have a way to measure temps on your pack? Where is the most heat generated? (Use a laser temp probe. ;) )
What is your controller/motor setup? 20" wheels & tires used & inflation psi?
How did you calibrate your CA?
Thanks. :D
deVries
Postby cwah » Wed Jul 25, 2012 7:02 pm
No, no way to measure temp on my pack yet. Waiting for the laser temp probe from HK that's never in stock.
I have a Lyen 84-132V controller with 16" wheel brompton :)
Inflation to 90-100 psi :)
I just use Rshunt value provided by Lyen for CA calibration.
Anyway, I also noticed that my pack went a little bit bigger. It cracked my polycarbonate box I created for it :lol:
I wouldn't say it would be due to abuse, maybe normal because it's a new pack?
cwah
Postby deVries » Wed Jul 25, 2012 7:23 pm
With some heat involved with discharge there is bound to be some pack expansion. I think it would be hard to stress 20Ah packs on an eBike assuming good pack design for low resistance & low heat buildup.
Did it crack starting at a screw hole? Pic?
What motor are you using? No load rpm?
Thanks. :)
deVries
Postby cwah » Fri Jul 27, 2012 1:38 am
I used super glue for my polycarbonate box :lol:
Now it's fixed, didn't take a picture as the box wasn't glued that strongly anyway.
I'm using conhismotor mini hub, the no load RPM should be around 600 RPM at 66V and 525 RPM loaded, which is roughly 40 kph. :)
cwah
Postby docnjoj » Sun Jul 29, 2012 2:13 pm
Superglue is really brittle and not a great choice for welding polycarbonate. There are Mek type industrial cements that really work well for acrilic and Lexan. I think one os called CtC-16 or Weldbond. I'll look it up.
otherDoc
Here you go. This is the stuff I used for my Lexan battery box. Weld-on
http://www.ridoutplastics.com/adandcem.html
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby cwah » Sun Jul 29, 2012 2:43 pm
The seller gave me some transparent glue, and it wasn't working that well. So I decided to go on industrial super glue. I've put a lot of this glue, and for now it's working quite well.
Will stick check you link and buy them if I need that later.
cwah
Postby deVries » Mon Jul 30, 2012 12:11 am
cwah wrote:I'm using conhismotor mini hub, the no load RPM should be around 600 RPM at 66V and 525 RPM loaded, which is roughly 40 kph.
This is what your intending to power at 100+ volts too??? :razz:
What controller will you use? What controller do you have now?
deVries
Postby cwah » Sun Aug 26, 2012 6:53 pm
Sorry, didn't see your post.
Yes this is what I intend to boost at 100V+.. for now :)
I use Lyen racing controller for that :)
cwah
Postby zzoing » Mon Aug 27, 2012 3:37 am
i always pack my battery in a box made of polyethelene foam sheet i got for solar panel packaging, its kinda rigid and easy to work
zzoing
Postby cwah » Mon Aug 27, 2012 5:30 am
:shock:
Do you only use foam sheet to protect the battery?
I have a polycarbonate box with a layer of foam sheet to protect the pack. It already felt on the floor multiple times so better be sure
cwah
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: gknowes, wesnewell and 7 guests
