Which battery charger is worth buying?
Re: Which battery charger is worth buying?
Postby allroads » Fri Jul 27, 2012 10:12 pm
I checked with my buds volt meter, the battery is good at 38 ?, the charger does work and reads 42v, but the charger plug from the battery has a short with no reading. I'll fix this first thing tomorrow. I ended up using a backup 3a charger, which took the better part of the day, about 8 hrs.
Currently the battery box in the floor of the scooter is too shallow for the new height of the lifepo pack. So next week I will be lowering the battery box 3" to accommodate the larger size. This will entail some torching, cutting new steel and welding it to the existing box. I'll also add a key lock the cover.
'06 Schwinn Stealth e1000, new fork w/disc brake, new rear shock, new 36v20ah lifopo ...
allroads
Postby deVries » Fri Jul 27, 2012 10:45 pm
miuan wrote:
deVries wrote:The PS charger I'm so excited about will allow you to drop down anywhere from 9A to 4.45A @ 36v, which is lower than a 5A charger. I think that is plenty safe for direct "bulk charging" at least a 10Ah size battery, imo. ;)
Yes this is correct, I just would never try to charge it at 9A and rely on BMS to cut the current.
I hope "standards" of BMS design would control the rate/amount of current the PS Charger feeds it, since it should be controlling and managing the charge in its circuit/chip design and not letting the Power Supply run wild at whatever amps it can pump out. :shock:
allroads wrote:the charger plug from the battery has a short with no reading.
Any idea how the short was caused?
deVries
Postby dnmun » Fri Jul 27, 2012 11:57 pm
what do you mean a short with no reading?
where did you measure the 38V on the battery and why does the charger voltage only measure 42V?
you need to post up pictures of what you are measuring. if the charger is only putting out 42V then it is the wrong charger, but if you had it plugged into the battery when you measured the voltage then it might make sense.
something else that does not make sense. if you charged the pack for 8hours with a 3A charger. it should only take about a half hour at most for a new pack.
can you expose the BMS too and take pictures of it?
dnmun
Postby John in CR » Sat Jul 28, 2012 2:58 am
miuan wrote:This one. Very cheap, very light and almost silent. Mine holds up well so far.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0739347377
I wouldn't want an "almost silent" charger that does over 2A except some of those open cage power supplies. IMHO you want a nice strong fan cooling your charger and they make noise. The added benefit of noise is if the fan craps out, you'll notice next time you turn it on and may have a chance to save it before the sure failure. In hot ambient conditions, like in a garage or shed during a heat wave even go to the added extent of putting a fan blowing on the outside of the charger that compliments its internal flow direction to help ensure longevity.
Good ventilation is essential. I wanted to strangle my wife when I caught her charging her laptop with the charger stuck down between the cushions on the couch. To make matters worse I see that it was so abused that the brick had exposed copper conductors at both the input and output ends. It was only luck that we dodged the fire bullet on that one, because no telling how long the hot as shit charger stuffed in the couch went on, since she said she did it because it was too hot against her. I won't even let her look at a lipo brick even though I have those 4s packs that match her laptop's 4s battery pack, so I could make a great long use booster pack for her, but no f'ing way. :mrgreen:
John
John in CR
Postby dogman » Sat Jul 28, 2012 5:21 am
Sounds more like an open plug than a short on the charger plug. Wire disconnected at the plug I mean.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby deVries » Sat Jul 28, 2012 6:16 am
deVries wrote:I hope "standards" of BMS design would control the rate/amount of current the PS Charger feeds it, since it should be controlling and managing the charge in its circuit/chip design and not letting the Power Supply run wild at whatever amps it can pump out. :shock:
I did a little research & found this out...
The trashy truth of this seems to be disconcerting, imo... It seems if you have a cheap-ass charger or PS that comes with the typical BMS that comes with your battery, then you are getting no programming charge control over the amount of current applied to charging the battery cells. The charger or PS needs to be more sophisticated to communicate with the programmed chips/software of the "BMS" to control how the cells are charged throughout the charge cycle. I found this from a BMS company: Chargers of this type that can't be controlled by our BMS do not allow control of the charging current and therefore perform somewhat worse as exact optimal current mode cannot be selected as it depends on only how the charger was setup. Non-CAN charger is basically the charger which has no digital data transfer capability over CAN line and can be controlled by only switching it on or off via relay or contactor.
CAN charger is the charger which can communicate and can be controlled via CAN communication bus. There is no unified and widely accepted charger communication specification standard.
So, for optimal charging you need an expensive charger that can *also* communicate with your BMS programming. In this example it's called CAN enabled. When CAN type charge is selected then all communication is done via the CAN bus using special messages compliant to specific charger type. For this type of chargers BMS selects optimal charging current and target voltage for different stages of charging.
I personally would replace these cheap-ass chargers with the one I recommended in this thread upfront, keep the cheap-ass as a spare, BUT you will need to "tune" the current to the right level for your battery & BMS. Not much is digital or programmable for ebikes in a digital charger/bms combo, so analog is where were at but for a very few exceptions that cost a lot more money to implement.
deVries
Postby jana » Sat Jul 28, 2012 11:24 am
What do you think of this charger for 12s lipo?
http://www.ebay.com/itm/400W-48V-8-3A-S ... 2c670276e9
jana
Postby 999zip999 » Sat Jul 28, 2012 3:00 pm
Is shipping and handling 28.00usd. plus 68.00 = 96.00 or free shipping ? What ?
999zip999
Postby deVries » Sat Jul 28, 2012 3:13 pm
jana wrote:What do you think of this charger for 12s lipo?
I highly recommend this one below instead, because it will be much more efficient in the EU at 220v volt charging...
Amazing Charge Efficiency & 5 year Warranty... :D
(Put two of these in parallel if your BMS & Battery can take a 13.4A charge load...)
48v 6.7A 90-93% Efficient 5 Year Warranty $116 PS Charger
deVries
Postby cwah » Sat Jul 28, 2012 3:15 pm
Devrie, the problem with these power supply is that you can't easily adjust the voltage.
I've purchased the one from BMSbattery because they are the only one you can easily tweak the voltage to your needs.
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby deVries » Sat Jul 28, 2012 3:33 pm
cwah wrote:Devrie, the problem with these power supply is that you can't easily adjust the voltage.
This is not correct for voltages between 12v to 54v per charger. The PS charger I recommend can be tuned up/down by 10% of its rated voltage, so, for example, this 48v model can go up to 52.8v or down to 43v. You can adjust this specific model anywhere between 43v to 52.8v. :D
You are correct that these chargers can not do as wide a range of voltage changes, since the total range of adjustment is 20% or 10% up & 10% down.
Still, these are ***incredibly efficient*** w/excellent 5 year warranty. Man, I'm totally sold on this model of charger for the price, quality, warranty, and **amazing** **incredible** **high-efficiency**.
I know of no better overall value or "deal" at this time. The BMS Battery charger you bought is "junk quality" & **terribly inefficient** (w/insanely high shipping charges) vs these PS chargers, IMO. IMO. :twisted: (Though, I have a specification pdf to back-up my opinion as "real".)
(I admit I stupidly bought the 400w & 900w BMS Battery Chargers myself. I would *never* do that again! Ever! :oops:)
deVries
Postby jana » Sat Jul 28, 2012 4:24 pm
Thanks for that info, but with shipping I think this charger will be at least 3 times as expensive as the one I linked to. Do you now the approximate weight of the MeanWell?
jana
Postby 999zip999 » Sat Jul 28, 2012 4:29 pm
One time my vote the aliumiun case http://www.bmsbattery.com 5a. Like Dogman said Ok. All charges have a failure fate. %. King pan is the maker. I think. JUst give them the spec's and hope it comes out allright check befor plug in.
999zip999
Postby deVries » Sat Jul 28, 2012 4:41 pm
jana wrote:Thanks for that info, but with shipping I think this charger will be at least 3 times as expensive as the one I linked to. Do you now the approximate weight of the MeanWell?
If you pay high electricity rates, then the far more efficient PS Charger I recommend will pay for itself in savings with much less electricity usage & faster charging too! :D Man, you can't beat this deal, IMO. :twisted:
You should be able to find an EU supplier for this PS Charger too. It is available from many suppliers. You could probably special order it from someone in the EU. Or, just buy it from Hong Kong.
It will weight less than 1.5Kg.
(Its packing weight is 1.88Kg.)
Really? How is that possible? :?:
deVries
Postby cwah » Sat Jul 28, 2012 5:03 pm
deVries wrote:This is not correct for voltages between 12v to 54v per charger. The PS charger I recommend can be tuned up/down by 10% of its rated voltage, so, for example, this 48v model can go up to 52.8v or down to 43v. You can adjust this specific model anywhere between 43v to 52.8v. :D
The charger from BMSBattery aren't as efficiency. But they are cheap and much much more flexible.
I have multiple configuration with my lipo battery, from 37V to 100V. And I have 4s and 5s lipo I put in serie and parallel.
I don't know how a standard meanwell can ever cater for that, and I can't buy so many of them.
For example, I have now 10 pack of 4s lipo and a 24V meanwell with 10% adjustment. I will never be able to charge my 4s lipo because I'd either need a 16.6V charger (4s*4.15V) or 33.2V (8s*4.15V). I have now the efficient meanwell, but that can't charge my lipo and it's really annoying.
So I prefer to have something less efficient, but much more flexible and cheaper. And electricity isn't expensive, especially to charge an ebike. Charging an ebike shouldn't use much more power than your fridge or your computer.
cwah
Postby deVries » Sat Jul 28, 2012 5:06 pm
999zip999 wrote:One time my vote the aliumiun case http://www.bmsbattery.com 5a. Like Dogman said Ok. All charges have a failure fate. %. King pan is the maker. I think. JUst give them the spec's and hope it comes out allright check befor plug in.
The charger you are voting for is: That's $84 to ship to USA. Only $30 of that is spent for the actual (JUNK) charger. :lol:
I suggest other readers of this thread don't waste your "vote" or purchase on Low Quality Chargers vs much better quality & efficiency choices. :D
(Edits: As I admitted, see my previous post, I will not buy these BMS Battery Chargers again, when I have much better quality & high efficiency options to choose from for about $30 more than the $84 JUNK charger. If shipping could be low cost by Sea/Surface, then that might make the pricing much better too!)
deVries
Postby jana » Sat Jul 28, 2012 5:33 pm
It is possible because of high spipping price and custom fees.
I actually found this charger on a Norwegian site, but the price is 1151 Norwegian kroner = 190.348927 U.S. dollars :D
Then the 65 dollar ebay option seems a bit more interesting.
I am anyway not so much concerned with effieciency, but i am concerned with reliability and safety.Is the ebay one likely to be of low quality and have a very short life? And how likely is a low quality charger to actually start a fire in my garage?
jana
Postby deVries » Sat Jul 28, 2012 5:41 pm
cwah wrote:The charger from BMSBattery aren't as efficiency. But they are cheap and much much more flexible.
cwah, how is your specific BMSBattery charger going to cater for that??? Please explain how you will do this? ;) How "cheap" & "flexible" is this to do? Explain the details, please...
cwah wrote:For example, I have now 10 pack of 4s lipo and a 24V meanwell with 10% adjustment. I will never be able to charge my 4s lipo because I'd either need a 16.6V charger (4s*4.15V) or 33.2V (8s*4.15V). I have now the efficient meanwell, but that can't charge my lipo and it's really annoying.
Really? You say you have a Hyperion charger. Use the same Meanwell you reference above to charge this lipo. You have the solution already! :D Use Hyperion w/Meanwell. :idea:
cwah wrote:So I prefer to have something less efficient, but much more flexible and cheaper.
Explain the details of that "flexibility" & "cheaper" beyond rhetorical theory to your actual application in use now. ;)
cwah wrote:And electricity isn't expensive, especially to charge an ebike. Charging an ebike shouldn't use much more power than your fridge or your computer.
Time is money/savings too. The highly efficient charger I recommend will save you time & money too. I want to charge fast time-wise AND efficiently too. I also don't want to waste time & more money with higher failure rate, lower quality "crap" w/o a 5 year warranty too. :twisted:
IMO, your method of charging is much more expensive overall, and you've given no real world use/proof of greater flexibility too other than "on paper" that is not your actual usage or better alternatives. IMO.
deVries
Postby cwah » Sat Jul 28, 2012 5:54 pm
I actually have a very simple problem:
I want to charge my 74V and 100V lipo with a simple "plug and forget". The hyperion allow a maximum of 14s. So I need to unplug and replug my harness to fit my hyperion everytime I want to charge. That's ok once a while, but doing that everytime is annoying.
With a 74V charger, I can just unplug my pack from my bike, plug it to the charger. Forget it.
And few days after, if I want to change my lipo configuration to 100V, I adjust the same charger, plug the battery. Forget it.
Not a problem at all if it's only 80% efficient as long as it saves my time :lol:
cwah
Postby deVries » Sat Jul 28, 2012 5:57 pm
How much is your Customs Fees for the $65 charger? ;)
To me, once you pay Customs Fees, then you aren't saving much money directly vs your other concerns. I say "hell yes" buy the PS Charger I recommended for your 48v application, and I would *not* buy "the cheaper" charger you ask about. Don't buy that junk, IMO.
deVries
Postby jana » Sat Jul 28, 2012 6:11 pm
HK always set value very low so no fees :) I already have a bulk charging sollution so I will wait and see what new products comes available.
jana
Postby deVries » Sat Jul 28, 2012 6:17 pm
cwah wrote: And few days after, if I want to change my lipo configuration to 100V, I adjust the same charger, plug the battery. Forget it.
IMO, you're wasting A LOT of time doing this, and that piece of crap charger is not designed for you to adjust back and forth as you describe. It will die probably shocking you too (if not always alert) at some point opening the charger to adjust it. (You fried your controller & wiring on Guinness or ? :twisted:)
Still, the charger is not designed to be adjusted often as you intend to misuse it.
Also, please time that entire event of adjustment from 74v to 100v "adjustment" AND back to 74v again. Also measure how accurate your voltage "adjustments" are over time. I promise you that you have wasted time doing this, imo, and the charger is going to fail much sooner with you doing this too. IMO.
Skip the Hyperion. There are better solutions than using the Hyperion too. :idea:
deVries
Postby deVries » Sat Jul 28, 2012 6:22 pm
HK always set value very low so no fees.
Then please do what I suggested and buy the PS Charger I referenced from Hong Kong. ;) :idea:
deVries
Postby deVries » Sat Jul 28, 2012 7:22 pm
jana wrote:I already have a bulk charging sollution...
What is it exactly? Model? Amps? Volts? Brand?
deVries
Postby cwah » Sat Jul 28, 2012 10:25 pm
ok, let say I want to get 2 meanwell to charge at 74V and 100V.
Where can I find such a meanwell?
cwah
PreviousNext
Return to Battery Technology
Who is online
Users browsing this forum: mcintyretj and 9 guests
