by Patriot4 » Mon Aug 06, 2012 9:16 am
I want another one too. Added to my wish list, Bookmarked the seller.t The display seems accurate. I use anderson connectors on my battery pack so when I bulk charge there is no possibility of mixing polarity, but have to double check my self when I do cell balancing to make sure I do not reverse polarity. The cell monitor I use on my pack draws form the first 3 cells of my 12s pack so I have to to occasionally have to charge them up to match the other cells. A typical RC charger balances at 100 milli amps. I Charge the cells at 2 AMPS which is 20 times faster! .1 volt difference on such a big pack is about 2 Amp Hours or more which translates to 20 hours+ on a RC charger or 1 hour with the lab supply. Ray
