michaelplogue
OK, I've got two LiPo packs (each with BMS) that will have their output leads connected in parallel. Each pack has it's own charging leads. With the way the BMS is set up, connecting a charger to one of the packs will charge both (via the connected output leads), but at half the speed. So, here's the dumb question: Can I connect both packs to their own chargers while they are still connected in parallel via their output leads, or is this a really bad thing (like billowing smoke and flames, and all kinds of havoc)?
Thanks!
Thanks!
