Knuckles
I have a theory for Nickel Metal Hydride (NiMH) chemistry that I call Thermal Balancing. This is how I charge my NiMH packs.
I use a cheap 2.5 amp 36V SLA charger. http://cgi.ebay.com/Battery-Charger-Electric-Scooter-Bike-36V-2-5A_W0QQitemZ300200312172QQihZ020QQcategoryZ11332QQcmdZViewItemQQ_trksidZp1742.m153.l1262
It seems to work fine so I figure it’s time to share it.
I prefer to construct a 30-cell NiMH pack using C-size 5000 mAh cells in series. This creates a 36V (nominal) pack with a max voltage of about 42.3 volts
(1.41V per cell is needed to achieve full charge in each cell). I buy Powerizer or Tenergy button-top C cells for about $0.60/Whr on ebay.
http://cgi.ebay.com/12-Pcs-C-Size-5000mAh-NiMH-Rechargeable-Batteries_W0QQitemZ330251292816QQihZ014QQcategoryZ40975QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
I solder them together (a no-no? I say WTF). I often draw up to 30 amps from this pack with only very mild heating of the cells (another no-no?).
And sure, these are cheap NIMH batteries. These are the cheapest NiMH cells I can find.
The 30 cells fit perfect in a $6-RadioShack plastic project box (quite rugged),
http://www.radioshack.com/product/index.jsp?productId=2062284&cp=2032058.2032230.2032276&parentPage=family
(radioshack pic is wrong btw, see project box pic here ... http://98.131.176.65/endless-sphere/GEDC0405.JPG and http://98.131.176.65/endless-sphere/GEDC0404.JPG)
which, in turn, is almost the exact same dimensions of a typical 12V 20AH SLA battery. http://cgi.ebay.com/Battery-Pack-for-RBC11-APC-Replacement-Battery-12V-20AH_W0QQitemZ310066549256QQcmdZViewItem?hash=item310066549256&_trksid=p3286.m14.l1318
The project box fits perfect in my Grubee (4 x 12V-20AH) battery rack or at the bottom of a typical bicycle rear saddle basket (WALD)
(or on the back of my chopper e bike http://endless-sphere.com/forums/viewtopic.php?f=6&t=4160&st=0&sk=t&sd=a#p62316).
During pack construction I install a 50°C (122°F) Klixon thermal switch embedded in the pack. A separate charging lead is connected to the Klixon and the positive terminal of the pack.
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=2911
These packs are my work horses and are MOST reliable and have the best energy density per mass going! So bring it on!
