Doctorbass
I am considering building a battery for drag racing ebikes yes..guys .Another :wink: !
A typical run should be about 16 second on the 1/4 mile in the best hopes.. (I remember i did in the low 19sec with a single X5)
So the battery dont need to have alot POWER and it only need to last about 16 sec full power and 30 sec for the return.
I estimate that the battery current would have to be about 300A for the 16 sec if i use 2WD with dual MAX-E controller ( about 28kW)
I know Luke like these Nano-tech and i'm considering using these... but if some similar performance lipo exist that would be great too..
For the Noan-Tech, i know that they have regular and the A-Spec. i am not sure of the power density if very different and that's what i want to know.
That battery need to be lightweight and have JUST THE RIGHT AMOUNT OF ENERGY for one run and the return ( let say 16 sec at 300A + 30 sec at 30A witch correspond to about 1.33Ah + 0.25Ah = 1.58Ah. That mean if i take only the only required capacity it would have to be 1.58Ah and capable to deliver 300A (about 200C)
The nano tech are 65-130C so for a drag racing " burst" the rated 130C could be ok... so 300A at 130C mean a capacity of 2.3Ah for the C rate but the run would take 1.58Ah witch leave a margin of 0.72Ah witch wold be the discharge state at the end that would remain untouched... to not fall at too low voltage when the Ri raise at the end.
That would be a 22s 300A burst battery for two Max-E Adaptto controller. (24.4kW) and an estimation of 24hp total at the two wheels
Some of will ask why saving wieight when it's only a fractino of the total weight of the bike and me... well i would say .. 1kg less to push to the bike to the finish line is still 1kg less... lol it remove fractin of second during the first 0-60ft witch is also important...
But even if these cells are really capable of 130C.. I have a doubt about how the soldered 10Awg wire are capable of not unsolder from the battery terminal at so high current... and how the battery heat increase lol
So i also wonder f driving it to lower C rate and using higher capacity would be best... It's all a question of power to weight ratio so the voltage sag also is important.
Doubling the battery capacity mean doubling the weight.... but also reduce the voltage sag.. witch mean more power... but is the added power worth the addeed weight to cary on the bike... I know there is an optimum point that can be calculated.. just like i did in 2009 for my A123 cells on the speed record bike...
I have never used yet any Nano tech.. A spec or not... and if you guys have some recommandation i will really appreciate.
