Charger problem
ebike11
Charger problem
Post by ebike11 » Jul 23, 2017 1:54 am
Hi guys
I accidently reversed polarity when connecting the charger the battery during my battery assembly.
Charger is just a simple 42V 3A charger.
Now the charger powers up and fan also starts and runs continuously.
There is no voltage reading though when i test the output leads with my multimeter.
I checked and fou d 2 fuses which I replaced but it didnt fix the problem.
Could there be another common thing to check when this happens? Thanks
Inwo
Re: Charger problem
Post by Inwo » Jul 23, 2017 8:40 am
Post some pictures.
Don't know what simple charger means.
Burned traces? Protection circuit?
Did it ever work with no battery connected?
ebike11
Re: Charger problem
Post by ebike11 » Jul 23, 2017 8:58 am
Inwo wrote:Post some pictures.
Ok ill get some pics asap
By simple i meant just a regular 36v charger from online.
It has been working fine until i accidentally reversed polarity when connecting to a battery.
Yes now when i just plug the charger in without being connected to a battery, the fan runs constantly and getting 0Volts at the output connector
peleap
Re: Charger problem
Post by peleap » Jul 24, 2017 3:02 am
I have the same problem with you.
chessir
Re: Charger problem
Post by chessir » Jul 24, 2017 9:43 am
I did that with an IMAX B6 and it stopped working completely.
bikeboy-silence is golden
ezip trailz dual24v10ah sla and/or ductape24v10ah lifepo4
